Post by gravesnumber9 on May 8, 2021 12:43:40 GMT -6
And… fill in the blank. Or maybe the answer is “plug-ins do equally well/poorly regardless of what they’re trying to do.
For example, I have often heard “software EQs are great, no need for hardware” or “at this point compression modeling is fantastic.” But then I also hear “nobody can really capture a pushed limiter properly” or whatever.
So. If there was only ONE type of processing you could use hardware for, what would it be? And if there was ONE type of processing you were forced to do with only software, what would that be?
Post by gravesnumber9 on May 8, 2021 12:45:27 GMT -6
Here’s another wrinkle. Maybe mix in a cost factor. “Yeah hardware EQ’s are great but you need to drop $4k per channel to hear the difference. Better off with a $1k compressor.”
Just giving examples. No idea if that’s accurate.
Post by jeremygillespie on May 8, 2021 12:47:39 GMT -6
The B3 / Leslie combo VI’s just don’t do it for me. I can hear it a mile away. Same with Pianos if it’s a wide open piano / vocal tune.
Eq’s are pretty darned close imo. The only reason I’d want more hardware eq’s is so I can take care of it on the way itb instead of afterwards.
Post by matt@IAA on May 8, 2021 13:06:01 GMT -6
I think you can do just about anything ITB but not in the same way. Multiple plugins may be needed to do what one knob on an analog piece can do. I’d say heavy distortion would be the only thing you really can’t do perfectly ITB.
Post by gravesnumber9 on May 8, 2021 13:15:29 GMT -6
I think you can do just about anything ITB but not in the same way. Multiple plugins may be needed to do what one knob on an analog piece can do. I’d say heavy distortion would be the only thing you really can’t do perfectly ITB. A good friend of mine with a nice studio in town put it like this. “When used as intended, plug-ins and hardware are basically the same. But if you want to f*** s*** up, hardware will sound way better.”
Post by Johnkenn on May 8, 2021 13:27:40 GMT -6
Still think hardware compression is better. EQ is a toss up.
Post by Deleted on May 8, 2021 13:35:10 GMT -6
IMO mastering limiters, I've come across some of the old TC's etc. and nothing I've come across OTB can touch modern plugins. Shows how far we've come because the old ITB mastering limiters I first used really sucked.
I have to admit some bespoke plugins that aren't trying to emulate something else tend be pretty awesome, not all of them of course but it's like creating a mic. Some get it right, some don't and some stand in the middle..
Post by stormymondays on May 8, 2021 13:35:13 GMT -6
Let’s see. I have hardware compressors, EQs, reverbs, delays, exciters, transient designers, and “color boxes” (Black Box, Chroma.) Also a truckload of guitar pedals and amps. Plus Hammond+Leslie, Wurlitzer and a Yamaha U1 upright.
Maybe I’m a sucker for knobs, switches and VU meters. In my experience, most things are nicer and easier to use in hardware, and can also be approximated ITB, with far easier recall.
I think only brickwall limiter is definitely better ITB.
P.S. the answer you are looking for is: but a Weight Tank compressor for single sources or a SSL-style compressor for the master buss ;-)
Post by kcatthedog on May 8, 2021 13:54:30 GMT -6
I think the hardware on the way in and then itb works, and sometimes you just know, a nice ob comp would just add a little (pick preferred adjective!) to describe preferred, ephemeral sonic quality:)!
Post by gravesnumber9 on May 8, 2021 14:01:20 GMT -6
I think the hardware on the way in and then itb works, and sometimes you just know, a nice ob comp would just add a little (pick preferred adjective!) to describe preferred, ephemeral sonic quality:)! That’s the type of workflow I’m moving towards.
Post by drbill on May 8, 2021 14:22:23 GMT -6
To get a traditional sound - IMO - you need hardware on the way in and hardware on the way out. That's how it was always done, ,and that's what will get you there. A single comp or EQ or line level device does not get you all the way to the traditional "gold standard" that so many aspire to. As mentioned earlier - IMO - the only plugin that is BETTER than hardware is a high end plugin brick wall limiter. I used to think EQ's were comparable. Until I got high end EQ's which are amazing that I've not heard a plugin touch. Comps are not even close for me. Saturation - same. SOME software verbs are almost equivalent to the hardware suspects - except for the Bricasti, which has a life that it brings to whatever you pass thru it.
These threads often seem like justification confirmation. I don't have the room, I can't access and original, it's too much heat, I don't have the money, I need 15 instantiations, etc.. IMO, plugin tech is coming along, but has a long way to go - and on the esthetic front - it will never get there, cause hardware is hardware, and plugins are just fancy graphics on your monitor screen.
Post by gouge on May 8, 2021 14:34:44 GMT -6
Plugs are slowly getting there but i agree there is something missing in the sound. Like comparing good mics v mid level mics.
For me the thread is back the front tho. The question i ask is
"this effect really cant be done well with hardware"
The list is just as long. Celerbrate what it is plugs bring to the table. They are great tools.
Post by gravesnumber9 on May 8, 2021 14:41:49 GMT -6
To get a traditional sound - IMO - you need hardware on the way in and hardware on the way out. That's how it was always done, ,and that's what will get you there. A single comp or EQ or line level device does not get you all the way to the traditional "gold standard" that so many aspire to. As mentioned earlier - IMO - the only plugin that is BETTER than hardware is a high end plugin brick wall limiter. I used to think EQ's were comparable. Until I got high end EQ's which are amazing that I've not heard a plugin touch. Comps are not even close for me. Saturation - same. SOME software verbs are almost equivalent to the hardware suspects - except for the Bricasti, which has a life that it brings to whatever you pass thru it. These threads often seem like justification confirmation. I don't have the room, I can't access and original, it's too much heat, I don't have the money, I need 15 instantiations, etc.. IMO, plugin tech is coming along, but has a long way to go - and on the esthetic front - it will never get there, cause hardware is hardware, and plugins are just fancy graphics on your monitor screen. This is helpful. I'm actually coming from the opposite perspective. Not trying to justify not buying hardware, trying to think of where the money is best spent. So, for example, it seems like EQ might not be the right way to invest in hardware if it's a zero sum game (which it kind of is for me). Why spend $1k for one channel EQ if it's only marginally better (if at all) than my UAD plugins? Especially if that $1k can be used for something that makes a bigger difference. I'm in the process of upgrading my space as we kind of move out of lockdown stage here in central Texas. Doing a few projects in the last month or so I'm realizing that some hardware workflow could be helpful. I'm also starting to get more into committing on the way in anyway, so why not do it with analog gear? But... I have limited physical space (really, that's more of a limitation than money for me... although money isn't free) and a big part of my value proposition is being able to record myself, sometimes at the same time as the client. So I'm always going to be mostly ITB. I can't envision myself ever patching in racks of gear to mix in a 11x15 space. Tracking is a different question though.
Post by Tbone81 on May 8, 2021 14:48:52 GMT -6
I think really good saturation isn’t quite there yet.
Post by seawell on May 8, 2021 15:03:30 GMT -6
I started with the areas that the most tracks would hit. 2 Buss comp and effects. I know most people have comfortably moved on to ITB reverbs but man I love my Lexicons. At a bare minimum I like to have a summing mixer, 2 buss comp, effects and one really great comp for the lead vocal(usually vari mu). I've never shot out a plug in compressor, eq, or anything really that has beaten its analog counterpart. I really wish that weren't the case. How much of a difference is where I think each person has to decide if it's worth it or not.
Post by gravesnumber9 on May 8, 2021 15:20:26 GMT -6
I started with the areas that the most tracks would hit. 2 Buss comp and effects. I know most people have comfortably moved on to ITB reverbs but man I love my Lexicons. At a bare minimum I like to have a summing mixer, 2 buss comp, effects and one really great comp for the lead vocal(usually vari mu). I've never shot out a plug in compressor, eq, or anything really that has beaten its analog counterpart. I really wish that weren't the case. How much of a difference is where I think each person has to decide if it's worth it or not. This seems like a sensible approach. Hardware reverbs aren't a thing for me since I'm generally fairly light on reverb use to begin with, but on the rest... makes sense. Kind of a "bang for your buck" type approach. So in your DAW, are you just using your bus comp as an insert? Or is it only coming into play when you're doing a final mix down? I'm seriously considering the SSL SiX as a way to check some of these boxes. Plus it gives me some additional cue mix possibilities which is something I also need. Only problem is that while the super analogue preamps are great, I'm not really in need of any extra preamps and I hate the mental weight of feeling like "well, I paid for these preamps now I need to find ways to use them."
Post by seawell on May 8, 2021 15:54:11 GMT -6
I started with the areas that the most tracks would hit. 2 Buss comp and effects. I know most people have comfortably moved on to ITB reverbs but man I love my Lexicons. At a bare minimum I like to have a summing mixer, 2 buss comp, effects and one really great comp for the lead vocal(usually vari mu). I've never shot out a plug in compressor, eq, or anything really that has beaten its analog counterpart. I really wish that weren't the case. How much of a difference is where I think each person has to decide if it's worth it or not. This seems like a sensible approach. Hardware reverbs aren't a thing for me since I'm generally fairly light on reverb use to begin with, but on the rest... makes sense. Kind of a "bang for your buck" type approach. So in your DAW, are you just using your bus comp as an insert? Or is it only coming into play when you're doing a final mix down? I'm seriously considering the SSL SiX as a way to check some of these boxes. Plus it gives me some additional cue mix possibilities which is something I also need. Only problem is that while the super analogue preamps are great, I'm not really in need of any extra preamps and I hate the mental weight of feeling like "well, I paid for these preamps now I need to find ways to use them." I go 16 channels out into a Dangerous 2 Bus and then the stereo output of the Dangerous goes into a Focusrite Red 3. The output of the Red 3 goes back into 2 channels on the Avid HD I/O so I print the mix back into the session. I start every mix running through that so the mix gets built from the ground up going through that chain.
Post by lpedrum on May 8, 2021 16:00:10 GMT -6
To get a traditional sound - IMO - you need hardware on the way in and hardware on the way out. That's how it was always done, ,and that's what will get you there. A single comp or EQ or line level device does not get you all the way to the traditional "gold standard" that so many aspire to. As mentioned earlier - IMO - the only plugin that is BETTER than hardware is a high end plugin brick wall limiter. I used to think EQ's were comparable. Until I got high end EQ's which are amazing that I've not heard a plugin touch. Comps are not even close for me. Saturation - same. SOME software verbs are almost equivalent to the hardware suspects - except for the Bricasti, which has a life that it brings to whatever you pass thru it. These threads often seem like justification confirmation. I don't have the room, I can't access and original, it's too much heat, I don't have the money, I need 15 instantiations, etc.. IMO, plugin tech is coming along, but has a long way to go - and on the esthetic front - it will never get there, cause hardware is hardware, and plugins are just fancy graphics on your monitor screen. Justification confirmation possibly. But that door can swing both ways as some folks think just buying gear will give them a leg up. I like analog gear and I like plugins, and at times I have to shut off my inner bias that says outboard should sound better and just A/B the track and go with what sounds best at that moment. I will say I've yet to hear any plugin that does what the Silver Bullet does.
Post by gravesnumber9 on May 8, 2021 16:05:57 GMT -6
This seems like a sensible approach. Hardware reverbs aren't a thing for me since I'm generally fairly light on reverb use to begin with, but on the rest... makes sense. Kind of a "bang for your buck" type approach. So in your DAW, are you just using your bus comp as an insert? Or is it only coming into play when you're doing a final mix down? I'm seriously considering the SSL SiX as a way to check some of these boxes. Plus it gives me some additional cue mix possibilities which is something I also need. Only problem is that while the super analogue preamps are great, I'm not really in need of any extra preamps and I hate the mental weight of feeling like "well, I paid for these preamps now I need to find ways to use them." I go 16 channels out into a Dangerous 2 Bus and then the stereo output of the Dangerous goes into a Focusrite Red 3. The output of the Red 3 goes back into 2 channels on the Avid HD I/O so I print the mix back into the session. I start every mix running through that so the mix gets built from the ground up going through that chain. So you're monitoring through that chain and then just printing the mix on two dedicated channels. Are you putting anything on the two bus in PT? Currently I've got a few things that sort of sit on my bus that I mix into (a touch of UAD Fairchild, like barely any DB reduction... a really lightly tweaked Chandler EQ... the Townhouse bus comp... and then the UAD Ampex). Let's say I got a hardware bus comp, would it be impactful to route everything out after the Chandler and back in before the Ampex? Feel free to tell me I'm thinking about this all wrong btw. Also, I'm limited to four outs right now with my Apollo X4 so I can't do true summing like you're talking about, but I could do a couple sub mixes out as well. I already mix this way anyway, everything boils down to a "band bus" and a "vocal bus" which then goes to the mix bus.
Post by ragan on May 8, 2021 16:24:42 GMT -6
I still like hardware for damn near anything. I don't have the budget for a ton of channels of it but I print tracks a lot. But I like plugs too. They're fun and useful.
Post by guitfiddler on May 8, 2021 16:42:45 GMT -6
I started with the areas that the most tracks would hit. 2 Buss comp and effects. I know most people have comfortably moved on to ITB reverbs but man I love my Lexicons. At a bare minimum I like to have a summing mixer, 2 buss comp, effects and one really great comp for the lead vocal(usually vari mu). I've never shot out a plug in compressor, eq, or anything really that has beaten its analog counterpart. I really wish that weren't the case. How much of a difference is where I think each person has to decide if it's worth it or not. I remember asking you what effects you used on a vocal recording on one of your great reviews. Great work on those reviews btw, and I don't think you can match that with a plug in. When I heard it I had a feeling it was something like analog effects, and that's why I asked you about it. I had to know what you used because I really liked the result. I have searched and searched for a Lexicon pcm 81 everywhere, and they always come up for sale when I don't have the cash at the time. I had a chance to get one for a really good price and decided that it wasn't in good enough shape, but you used to be able to get these things serviced. Lexicon no longer services them. I had my PCM 70 serviced when Lexicon was still servicing them, it's ready for another 30 years of service! I like my analog Effects rack and tried to use plugins after using the Bricasti, H3500, and even my cheesy little Yamaha Rev500, and even my old Roland units have a sound and are super useful! I really like using my pcm70 in my guitar rack! I wish I had 2!
Post by rowmat on May 8, 2021 16:45:46 GMT -6
We tried completely working ITB with plugins but couldn’t get the the organic early 1970’s vibe that kind of became our studio’s trademark with our clients.
The most used plugins were Soundtoys for some echo, Fabfilter usually only for subtractive EQ and occasionally some Valhalla verbs if we needed more than the EMT140 and both the 480L’s stereo processors during mixdowns.
Any additional high passing or selective peak limiting I did manually in a wave editor typically on individual tracks during mix prep. (Where was my underpaid assistant to do this stuff? Oh yeah it was me!)
Personally it’s not just the tone but also the workflow that often gets you where you need to be.
Treating the DAW simply as a recording device while tracking bands and, apart from monitoring levels and running cue send mixes from the console (zero latency), not spending entire takes staring at plugin settings on a computer screen meant you could concentrate better on the performance.
We never used plugins during tracking.
I cannot overstate how important good cue mixes are for artists especially in a live band tracking situation. This is where hardware rules as you can get levels and sounds quickly without latency especially with a console.
Yep and hardware during tracking AND during mixdown. Ever wondered why vocals were often tracked using an 1176 and then an LA2A during mixdown?
Real transformers, tubes, inductors and ending up with an actual EMT140 was a game changer and whether or not you can get the same thing in a plug-in the EMT definitely brought us clients simply due to word of mouth.
And the KM84’s and Coles 4038’s also made a huge difference.
Post by guitfiddler on May 8, 2021 16:55:48 GMT -6
I still struggle with ITB. I remember pulling up a fader to unity and it was all there, and it just sounded right! It's taking me a lot longer to adjust to the ITB game. The most difficult thing is getting in and out without latency, or some bs-ing thing in the software or hardware configuration. I guess I would have to talk to the guys that say they can do anything ITB without hardware. I've experimented more than I should've, a lot of wasted time and money...ugh, but came to my own conclusion that I can't work without good hardware.
Post by seawell on May 8, 2021 17:29:53 GMT -6
I started with the areas that the most tracks would hit. 2 Buss comp and effects. I know most people have comfortably moved on to ITB reverbs but man I love my Lexicons. At a bare minimum I like to have a summing mixer, 2 buss comp, effects and one really great comp for the lead vocal(usually vari mu). I've never shot out a plug in compressor, eq, or anything really that has beaten its analog counterpart. I really wish that weren't the case. How much of a difference is where I think each person has to decide if it's worth it or not. I remember asking you what effects you used on a vocal recording on one of your great reviews. Great work on those reviews btw, and I don't think you can match that with a plug in. When I heard it I had a feeling it was something like analog effects, and that's why I asked you about it. I had to know what you used because I really liked the result. I have searched and searched for a Lexicon pcm 81 everywhere, and they always come up for sale when I don't have the cash at the time. I had a chance to get one for a really good price and decided that it wasn't in good enough shape, but you used to be able to get these things serviced. Lexicon no longer services them. I had my PCM 70 serviced when Lexicon was still servicing them, it's ready for another 30 years of service! I like my analog Effects rack and tried to use plugins after using the Bricasti, H3500, and even my cheesy little Yamaha Rev500, and even my old Roland units have a sound and are super useful! I really like using my pcm70 in my guitar rack! I wish I had 2! I really appreciate that! The crazy thing is the only one I have that would remotely be considered a classic is the PCM 70. It definitely is special but I still also love the 80 and 91. So even though they aren't the "best" of outboard FX I still find them to be really great. It helps that 99% of the time I'm using them on the same settings so no recall hassle...doing my best Andy Wallace impersonation with a tiled room, large chamber and large hall of some sort. I also have a couple of Yamaha SPX 90ii units that are great for what they do(again thank you Mr. Wallace haha). I mixed entirely ITB for years and got results I was very happy with but I personally get faster and overall better results incorporating the hardware that I do have. I like being able to reach out and touch real knobs and faders. I even have a D-Control so I can EQ/Compress with physical knobs(controlling software). I'm really happy with my set up and just look forward to adding more special pieces of hardware as quickly as I can afford them(Highland Dynamics BG2 is next on the list).
Post by Tbone81 on May 8, 2021 19:38:55 GMT -6
To get a traditional sound - IMO - you need hardware on the way in and hardware on the way out. That's how it was always done, ,and that's what will get you there. A single comp or EQ or line level device does not get you all the way to the traditional "gold standard" that so many aspire to. As mentioned earlier - IMO - the only plugin that is BETTER than hardware is a high end plugin brick wall limiter. I used to think EQ's were comparable. Until I got high end EQ's which are amazing that I've not heard a plugin touch. Comps are not even close for me. Saturation - same. SOME software verbs are almost equivalent to the hardware suspects - except for the Bricasti, which has a life that it brings to whatever you pass thru it. These threads often seem like justification confirmation. I don't have the room, I can't access and original, it's too much heat, I don't have the money, I need 15 instantiations, etc.. IMO, plugin tech is coming along, but has a long way to go - and on the esthetic front - it will never get there, cause hardware is hardware, and plugins are just fancy graphics on your monitor screen. This is helpful. I'm actually coming from the opposite perspective. Not trying to justify not buying hardware, trying to think of where the money is best spent. So, for example, it seems like EQ might not be the right way to invest in hardware if it's a zero sum game (which it kind of is for me). Why spend $1k for one channel EQ if it's only marginally better (if at all) than my UAD plugins? Especially if that $1k can be used for something that makes a bigger difference. I'm in the process of upgrading my space as we kind of move out of lockdown stage here in central Texas. Doing a few projects in the last month or so I'm realizing that some hardware workflow could be helpful. I'm also starting to get more into committing on the way in anyway, so why not do it with analog gear? But... I have limited physical space (really, that's more of a limitation than money for me... although money isn't free) and a big part of my value proposition is being able to record myself, sometimes at the same time as the client. So I'm always going to be mostly ITB. I can't envision myself ever patching in racks of gear to mix in a 11x15 space. Tracking is a different question though. I would highly recommend that whatever you get, make sure you can use for both tracking and mixing. More bang for your buck, less space, less money, more mojo (on the way in and out) etc.
