Post by kcatthedog on May 6, 2021 13:27:50 GMT -6
A very revealing look at Jacquire King setting up the 102 in a mix, he goes into a lot detail explaining his settings choices and plays demos, each time.
Post by javamad on May 7, 2021 4:18:46 GMT -6
I just add it in default to get that extra low octave on bass and subs on the kick on drums … :-D
Only got it a while back … I will definitely take a look at this and maybe create my own presets … using some of the UA ones only bugs me because of the added tape hiss ….
which is why I wish there was a master setting in my UA account to say … NEVER add tape hiss or Lexicon “system noise” …. EVER :-D
Post by kcatthedog on May 7, 2021 4:46:22 GMT -6
Default does sound great too: easy to turn off hiss, just open it up.
Post by javamad on May 7, 2021 10:33:50 GMT -6
Default does sound great too: easy to turn off hiss, just open it up. Its just a bug bear of mine …. I don’t want to open it up and have to check if preset x or y has the hiss
Post by kcatthedog on May 7, 2021 11:06:58 GMT -6
Two clicks is too much trouble, how do you ever get a mix done ?
Post by javamad on May 7, 2021 16:48:02 GMT -6
Two clicks is too much trouble, how do you ever get a mix done ? I can click for hours on what matters :-)
Post by kcatthedog on May 7, 2021 17:29:28 GMT -6
To hiss or not to hiss, that is the question. Bill was so ahead of his time !
Post by Johnkenn on May 7, 2021 17:34:27 GMT -6
I just add it in default to get that extra low octave on bass and subs on the kick on drums … :-D Only got it a while back … I will definitely take a look at this and maybe create my own presets … using some of the UA ones only bugs me because of the added tape hiss …. which is why I wish there was a master setting in my UA account to say … NEVER add tape hiss or Lexicon “system noise” …. EVER :-D Dude - that's EXACTLY what I do...then I close my eyes and toggle real fast and chose the one that sounds better
Post by javamad on May 7, 2021 17:43:21 GMT -6
I just add it in default to get that extra low octave on bass and subs on the kick on drums … :-D Only got it a while back … I will definitely take a look at this and maybe create my own presets … using some of the UA ones only bugs me because of the added tape hiss …. which is why I wish there was a master setting in my UA account to say … NEVER add tape hiss or Lexicon “system noise” …. EVER :-D Dude - that's EXACTLY what I do...then I close my eyes and toggle real fast and chose the one that sounds better I have a sub in my room ….. no amount of closing my eyes is going to hide when its in or out … I can feel in the short hairs ha ha … it is not subtle!
Post by Johnkenn on May 7, 2021 18:10:50 GMT -6
Dude - that's EXACTLY what I do...then I close my eyes and toggle real fast and chose the one that sounds better I have a sub in my room ….. no amount of closing my eyes is going to hide when its in or out … I can feel in the short hairs ha ha … it is not subtle! So do I, but I keep it really low.
Post by Martin John Butler on May 8, 2021 8:02:56 GMT -6
javamad, "what matters"? For heaven's sake, just take 5 seconds, open it up, turn hiss off and save. You'll never hear the hiss again.
I've used the ATR-102 permanently on my 2 bus since the first day of the first Apollo, and I don't love plug-ins. That thing might as well be call the Betterizer.
I think it's simply the most useful plug-in ever made. I can do an album with the ATR-102 alone and sound great.
I've tried every preset, before watching long tutorials, try this, compare the 30 ips mastering preset to the Smooth Vocal preset on the 2 bus. Pick one, tweak levels to taste, save, and you'll have a great sound instantly.
Good luck!
Post by Mister Chase on May 8, 2021 9:26:58 GMT -6
The ATR 102 plug is such a finisher for me. I play with each tape type, width and speed. Something in there will usually work. u-he Satin is amazing for this, too. But many times I get the sound much closer to a record with that ATR plug...
Post by Deleted on May 9, 2021 12:55:41 GMT -6
The ATR 102 plug is such a finisher for me. I play with each tape type, width and speed. Something in there will usually work. u-he Satin is amazing for this, too. But many times I get the sound much closer to a record with that ATR plug... Satin is more advanced and sounds better than ATR built up over every track in a mix but more of a chore to setup and gainstage. ATR has the wow factor. I like the Fuse tape for that too but again it’s not instant and must be played with.
Post by kcatthedog on May 9, 2021 13:28:58 GMT -6
ATR isn’t supposed to be on each track? Guess, you have to try studer and atr ?
Post by wiz on May 9, 2021 19:07:26 GMT -6
I use it on the two buss on every mix...
Post by Johnkenn on May 10, 2021 1:17:27 GMT -6
Yeah - finisher is the right thing to call it maybe. This is where Luna has taught me a lot...In Luna, the instance comes after the “summing” - which isn’t where I’ve (admittedly very rarely) used real tape in the mixing process. Usually at the end. But anyway - drop that thing in the slot and there’s an audible bump on the low end and little sheen on the top - at least with the default 15ips. I’ve tried other ips, but 15 works for me as a betterizer. Ther have been times I didn’t prefer it - I always toggle to check. But more often than not, I like it on.
