Post by dok on Jan 18, 2021 22:23:46 GMT -6
As it says on the tin. I have a Daking Mic Pre II already that I am absolutely in love with, and I have about $1k to play with. Very happy with the U87ai other than the fact that it occasionally gets sibilant on my voice. I've always been super interested in a good tube mic and have had some cheap modded ones before that were fine but got sold off to fund various other upgrades along the way. Is the Innertube mod more likely to scratch that itch than whatever tube pre I might find for that same price?
Not really interested in a different $1k tube mic, I'd rather sweeten up the U87ai that I already have. A stereo tube pre is not completely necessary but I do require a high pass filter in any event.
Another reason I'm leaning toward the Innertube mod is I only have 1u of rackspace, but I am open to suggestions... Thanks!
EDIT: I guess I should consider the Max Mod U67 as well.
Post by EmRR on Jan 18, 2021 23:55:38 GMT -6
A tangent idea because you mention the occasional sibilance with the 87: lots of people are dumping TLM67 guts when they move to the ioaudio (Max Mod) U67 recreation, so a couple hundred $ would get you an alternately voiced amp for your 87ai head. Ty Ford's review of the TLM67 is pretty much on, it's not that it sounds much of anything like a tube mic, but:
It's got a bit of a pseudo-fuzz thing to it that I guess is supposed to be the tube part; it's pretty mild. Comparing a TLM67 to a U67 does it a disservice, it's really it's own 67/87 variant.
The Max Mod as you said, once you get a decent transformer in it, every Max transformer I've heard is much darker than it should be. The Neumann is apparently no longer available, the Moby is a great option. I've installed both and they're both very good. Add $450ish to the Max Mod once you get that work done.
The innertube as I understand it is a bright option, doesn't sound like what you'd want in terms of direction with the 87. The continuous polar pattern it adds is a cool option.
Not sure what I'd recommend in a 1RU tube pre with a hpf, that can't leave many options, and within 'tube pre' there are a lot of different sounding and behaving types. The combos I have that'll do something like a tube mic sound from a SS mic into a tube pre are giant old 1940's tube preamps, there's nothing you'll buy within your constraints that'll make sounds like that.
Post by bricejchandler on Jan 19, 2021 5:13:36 GMT -6
I have a TLM67 and a U87ai.
The TLM is darker than the U87ai. I like the TLM for some drums and some acoustic instruments, it's a nice option to have. I also like it on guitar amps, mixed with a 57 it's cool. For vocals I still like the U87ai better, it sounds less congested though I agree it can be a bit hard sometimes.
I've been looking into getting the maxmod or innertube too.
Hearing EMRR talk about it is one of the reasons I looked into the maxmod but all the demos I've heard of the original transformer are just so dark I was a bit surprised, then I read that he'd upgraded the transformer but by the time I do that, Financially I might as well sell the 87ai and buy a used 67 reissue which I've used and it sounds great.
I personally would go for tube mic into solid state preamp over SS mic into tube mic preamp for vocals, there's just something about tube mics on vocals that just hits the right spot for me.
Here's a great video I've referenced a couple of times, I think both the Innertube and the maxmod sound nice here though I'd probably pick the Innertube for this genre.
Post by brenta on Jan 19, 2021 8:29:02 GMT -6
Did Neumann stop selling all spare parts?
Post by bricejchandler on Jan 19, 2021 9:16:57 GMT -6
Did Neumann stop selling all spare parts? Yes ! You have to send it in for repair now, you can't just buy a capsule and switch yourself.
Post by drbill on Jan 19, 2021 9:46:47 GMT -6
The InnerTube IS bright. In a really great way, but brighter than a stock 87. Bear in mind, I'm using one on a vintage 87, not an Ai. Really great mic. In my hands on experience, I do not believe you can get the same sound from an 87 + tube mic pre.
Post by brenta on Jan 19, 2021 9:54:58 GMT -6
Did Neumann stop selling all spare parts? Yes ! You have to send it in for repair now, you can't just buy a capsule and switch yourself. Ahhh that sucks! I should've bought some capsules when I had the chance.
Post by bricejchandler on Jan 19, 2021 10:15:57 GMT -6
Yes ! You have to send it in for repair now, you can't just buy a capsule and switch yourself. Ahhh that sucks! I should've bought some capsules when I had the chance. Yeah, I actually bought a used 2019 TLM67 for cheap recently just because it was simpler and pretty much the same price as sending it in and having Neumann install a new capsule on my U87ai. And bonus I've got a different sound to work with.
Post by guitfiddler on Jan 19, 2021 10:20:22 GMT -6
I have the max mod and you have to use a very clean pre with high headroom. I’m using the si pre. Sounds splendid! It also sounds great with my Oram mws!
Post by dok on Jan 19, 2021 10:53:53 GMT -6
Very much appreciate the feedback! The Max Mod plus transformer is probably a bit more than I'm looking to spend. maybe it's time to try out the old pencil trick and maybe a dbx 263...
I like the idea of finding some TLM67 innards on the cheap as well - none available at the moment but I will stay vigilant.
Post by bricejchandler on Jan 19, 2021 11:24:42 GMT -6
Very much appreciate the feedback! The Max Mod plus transformer is probably a bit more than I'm looking to spend. maybe it's time to try out the old pencil trick and maybe a dbx 263... I like the idea of finding some TLM67 innards on the cheap as well - none available at the moment but I will stay vigilant. Soothe2 is your friend! Actually recently on extremely sibilant vocalists, I've found that a combo of Soothe, Gulfoss and a little bit of the Deesser on the Scheps channel strip gets me some great results. Soothe is amazing for taming some of those nasty resonances that you get on an 87 with some singers
Post by dok on Jan 19, 2021 11:47:58 GMT -6
Thanks! I have good luck with FabFilter Pro DS when I really need it, but I record to tape sometimes and really want to get in the goldilocks zone when using that medium.
Post by chessparov on Jan 19, 2021 11:49:39 GMT -6
Got Ribbon? Maybe AEA R84 or KU5A, among many other options like Samar AL-95/4038/Sontronics Sigma2/NoHype. Chris
Post by bricejchandler on Jan 19, 2021 12:11:14 GMT -6
Got Ribbon? Maybe AEA R84 or KU5A, among many other options like Samar AL-95/4038/Sontronics Sigma2/NoHype. Chris While I really like AEA mics, I don't find they work that well on vocals. I've used the R84, KU5A a ton and owned the R44 for a few years and while I think they sound great on drums, egits, horns, vocals is always a bit meh for my taste. The Coles through a nice tube preamp followed by a Pultec adding some sizzle is my favorite ribbon on vocals. Not to derail the thread too much but Here's a memo I recorded with a Coles 4038, I used plug ins to open up the high end and it was heavily deessed but you can hear the mics character. www.dropbox.com/s/etaq3gczpjvjzj7/4038.mp3?dl=0
Post by chessparov on Jan 19, 2021 13:23:56 GMT -6
I'll catch up, by tonight. But...
With the Samar AL-95, Mark Fouxman and I were very surprised, it sounded right "as is", with no EQ on my voice (when singing,/testing it). Chris
Post by bricejchandler on Jan 19, 2021 14:05:47 GMT -6
I'll catch up, by tonight. But... With the Samar AL-95, Mark Fouxman and I were very surprised, it sounded right "as is", with no EQ on my voice (when singing,/testing it). Chris That's what I've heard. Emrr used the Samar on a folk album and I really liked the sound of the vocals. I hope to try one out some day! They're not very common here in Europe.
Post by Ward on Jan 20, 2021 6:54:16 GMT -6
Vote: Tube preamp. An 87 into a Weight Tank WT72 is far more versatile than an overly bright inner-tube. And should you come across a vintage U87 at a good price and wish to sell your 87ai, it will be a lot easier than trying to sell the 87ai and innertube. So, better investment. JMHO, YMMV. And thanks to bricejchandler for sharing this: Is it an advert for the Heiserman 47? If not, it sure could be. WOW . . . perfect microphone for this young man's voice. dok, maybe you should save up your money for a Heiserman H47T. I use mine every day. It gives me weird feelings inside, like I'm in the presence of greatness. I'm not being hyperbolic, I'm serious. tskguy wave mdmitch2
Post by ChaseUTB on Jan 20, 2021 8:36:08 GMT -6
Wow ... why did Neumann stop?
Customers want to take care of their mics w/o shipping all over the place. Mic techs rely on these parts to run their business.
Does Zen Pro still have Neumann parts for sale ? They had K870 capsules last month. Idk about transformers.
There is a Serrano 87 modeled off the 87i that’s getting some live around here. Maybe he can sell you a transformer but it won’t be authentic Neumann part obviously.
Post by ChaseUTB on Jan 20, 2021 8:53:04 GMT -6
To me the Max Mod & Innertube stood out here. The Heiserman was nice & had the pro level sound but not as finished as the MM & IT. Pearlman didn’t do much for me & that’s the revered TM1 model. Odd cuz I have heard that version TM1 crush it before.
For the H47T & the pearlman to have the most ideal mic/ capsule related to singer placements, the MM & IT87 really sounded balanced but exciting, highlighting nuances of the performers voice.
I could be wrong but the guitar sounds mono. I would have duplicated & panned hard L & R to leave a more room for the vocals to be displayed. Or a spaced pair capture of the guitar.
Post by m03 on Jan 20, 2021 10:26:20 GMT -6
Wow ... why did Neumann stop? Because a bunch of people abused their good will and bought up their spares for use in DIY/project mics. Remember, for every one person posting about how they picked up an OEM transformer/capsule/whatever, there are probably 50-100 other people doing the same thing that didn't post about it. If they go from selling 45 U67 transformers a year to 450 out of the blue, they're going to notice that something is amiss. Given the buyers in question, some of those people are going to screw up the installation, ruin the OEM part, and want a refund under the claim that it was defective. Again, for a professional company that was used to only dealing with experts when selling spare parts to suddenly have a glut of returns from people who clearly weren't experts, they're going to take notice. I'm honestly surprised that it took this long.
Post by EmRR on Jan 20, 2021 10:28:40 GMT -6
The endless stream of km84 capsules certainly got their attention. I wonder if you can even send them a km85 and get a km84 back.
Post by drbill on Jan 20, 2021 13:27:29 GMT -6
I liked the Heiserman and Innertube. I didn't think the Innertube came off bright at all.
