Post by Johnkenn on Dec 29, 2020 20:44:02 GMT -6
Anyone do this? I’ve used a compressor in M/S to bring up the side for a little more width, but it’s never really occurred to me to do it with something like Pro-Q3. I’m gonna play around with this, but can you roll off a little bottom on the sides to make the center pop?
Post by seawell on Dec 29, 2020 21:15:57 GMT -6
I like to do it on synth pads that are really full range. Keep the lows up the middle and eq highs to the sides.
Post by EmRR on Dec 29, 2020 21:30:52 GMT -6
can you roll off a little bottom on the sides to make the center pop? Sure. The native plug in DP has a sweepable HPF on the side signal, I use it on ambient stereo room pickup a lot to shape the bass focus.
Post by the other mark williams on Dec 29, 2020 21:35:37 GMT -6
Anyone do this? I’ve used a compressor in M/S to bring up the side for a little more width, but it’s never really occurred to me to do it with something like Pro-Q3. I’m gonna play around with this, but can you roll off a little bottom on the sides to make the center pop? yeah, I use EQuilibrium to do this fairly often.
Post by wiz on Dec 29, 2020 22:37:06 GMT -6
Absolutely, dipping the mid at say 180 hz and you’ll get a great idea of how this helps
Post by schmalzy on Dec 29, 2020 23:42:59 GMT -6
I do a bit (as appropriate and necessary) of what the cats in this threat have already mentioned.
I'll often hi-pass the sides of drum overheads to keep the shells more "at home" while grabbing a little more width. This works especially great on X/Y overheads and is less common for me on ORTF or spaced pair overheads. I'll do something similar in the midrange of a room mic pair looking to accentuate the spread of whatever - probably the snare - and de-accentuate something else - probably the cymbals.
Distorted electric guitar pairs will sometimes benefit from a reduction in upper mids in the middle channel and low mids on the side channel. Just a little bit of EQ in these sorts of ways can make a world of difference to keep the guitar feeling huge without overpowering a vocal
I also do some m/s EQ on ambience channels that need to be loud but shouldn't be distracting. EQ the distracting/masking stuff out from the locations you hear it and leave it in the other channel.
Post by drbill on Dec 30, 2020 10:43:49 GMT -6
I've tried many times. I can never get it where I really like it MORE than traditional approaches. Always sounds a little "unreal" to me - for lack of a better term.
Post by ericn on Dec 30, 2020 16:45:26 GMT -6
I've tried many times. I can never get it where I really like it MORE than traditional approaches. Always sounds a little "unreal" to me - for lack of a better term. Yeah, even with a linear phase EQ you have to be careful. It’s kind of like a steer by wire car with a bug, sure you point it slightly left, but your doing hard donuts to the right.
Post by nomatic on Dec 30, 2020 20:23:09 GMT -6
If you don't go more than 1/2 a bd it can be fine. Try a touch of 400 HZ in the side...
Post by nick8801 on Dec 30, 2020 21:38:00 GMT -6
Dig it on tracks, but you have to be careful on a mix.
Post by EmRR on Dec 30, 2020 22:04:32 GMT -6
If you don't go more than 1/2 a bd it can be fine. Try a touch of 400 HZ in the side... Yeah 1/4-1/2 dB is the territory on mixes many times.
Post by mitchkricun on Jan 1, 2021 11:19:54 GMT -6
If you don't go more than 1/2 a bd it can be fine. Try a touch of 400 HZ in the side... Love this! Thanks! Side note... I picked up Waves Factory Spectre on sale and it does Stereo and M/S frequency dependent saturation. Really worth checking out. Just a touch of hi shelf in M/S can really add some subtle life to stereo sources, including mix bus.
