Post by mrholmes on Dec 25, 2020 9:41:04 GMT -6
RGOs.
In real life as well as In The Box I only know The SSL-E.
I asked my buddy if he ever used an SSL-G but no. My mentor also no.
They seem to make a very similar impression - layout? I ask because the G is dirt cheap at Brainworx today.
Do they sound different?
Merry Xmas again. A.
PS: I remember when my Waves SSL was still running that the G sounded less harsh, aggressive in the top end.
Post by jcoutu1 on Dec 25, 2020 9:48:18 GMT -6
I've worked on both consoles before. For some reason, I always preferred working on the E. Could be a million different factors. The room itself. The E was 32 vs 56 on the G. Something about the E, I just connected with. YMMV.
Post by Guitar on Dec 25, 2020 10:10:51 GMT -6
Yeah I think they sound a little different in the EQ curves. I haven't done in depth comparisons but the G could be a little more pokey maybe. I've used the E a lot, not the G as much so I can't speak about it very much.
The 9000 J is the one I'm trying to get a handle on now. People keep talking about it so I feel like I should learn it.
Post by mrholmes on Dec 25, 2020 11:46:01 GMT -6
I've worked on both consoles before. For some reason, I always preferred working on the E. Could be a million different factors. The room itself. The E was 32 vs 56 on the G. Something about the E, I just connected with. YMMV. Yeah I think they sound a little different in the EQ curves. I haven't done in depth comparisons but the G could be a little more pokey maybe. I've used the E a lot, not the G as much so I can't speak about it very much. The 9000 J is the one I'm trying to get a handle on now. People keep talking about it so I feel like I should learn it.
Anyone who knows tech facts about the two?
Post by mrholmes on Dec 25, 2020 12:10:46 GMT -6
Post by jcoutu1 on Dec 25, 2020 12:28:23 GMT -6
So in summary,
E is more accurate freq wise (no over/undershoot).
G has a proportional q on the mid bands (a la API).
E has smoother slopes.
Post by mrholmes on Dec 25, 2020 13:07:45 GMT -6
So in summary, E is more accurate freq wise (no over/undershoot). G has a proportional q on the mid bands (a la API). E has smoother slopes.
The rest of the technology is the same?
Post by mrholmes on Dec 25, 2020 13:19:37 GMT -6
The other blue board had the answer:
Post by jeremygillespie on Dec 25, 2020 14:39:57 GMT -6
The eq curves are different in the 2 mid band sections.
On the J and K series you can switch between both of those curves. Can’t remember if you can do that on the Duality or not, it’s been a while since I’ve worked on one of those.
When I was assisting different engineers a lot on the 9000kXL, the majority of the would always switch the eq into “E” mode. They seemed to like that better.
I feel like it was more or less noticeable depending on what you were trying to eq and If you were mostly boosting or mostly cutting.
Post by mrholmes on Dec 25, 2020 15:00:06 GMT -6
The eq curves are different in the 2 mid band sections. On the J and K series you can switch between both of those curves. Can’t remember if you can do that on the Duality or not, it’s been a while since I’ve worked on one of those. When I was assisting different engineers a lot on the 9000kXL, the majority of the would always switch the eq into “E” mode. They seemed to like that better. I feel like it was more or less noticeable depending on what you were trying to eq and If you were mostly boosting or mostly cutting.
For a strange reason I can't demo brainworx stuff. I had to buy blind now, that's also the reason why I asked.
To my ears the G sounds fatter and less in your face.
The E has a lot of this ice pick coldness which I know by CLA mixes.
Post by jeremygillespie on Dec 25, 2020 15:37:05 GMT -6
Maybe they modeled an E that was in need of a re-cap 😁
Post by ragan on Dec 25, 2020 15:54:02 GMT -6
[This is all referring to the Brainworx plugins] Before getting the 9000J, I used the E more, though I liked to switch it to the G dynamics. The G is a little more aggressive in the mids. The E is gentler sounding. The G tends to sound slightly mid-pushed. The 9000J is (switched to E EQ) is my favorite. I use it on almost everything.
Post by bentley on Dec 25, 2020 16:04:43 GMT -6
Thought this was a pretty good demo of the plug ins:
Post by mrholmes on Dec 25, 2020 16:59:30 GMT -6
[This is all referring to the Brainworx plugins] Before getting the 9000J, I used the E more, though I liked to switch it to the G dynamics. The G is a little more aggressive in the mids. The E is gentler sounding. The G tends to sound slightly mid-pushed. The 9000J is (switched to E EQ) is my favorite. I use it on almost everything. Jupp E pushes hi mids g low mids. That’s my impression the 9000 is in between? I think for some tasks I like the G more. Future template will be mix out of E and G☯️🧘
Post by theshea on Dec 26, 2020 2:30:50 GMT -6
i went for the brainworx E after comparing it with the waves ssl strips and the brainworx G. the E seems more „focused“ to me and „smoother“ in the highs than the waves. altough the waves had a bit more tightness in the lows ... so, gibe and take, the brainworx E is now my go-to channelstrip. did you buy both? E and G?
Post by mrholmes on Dec 26, 2020 8:13:58 GMT -6
Yes I bought the G too because I thought it's tighter in the lows and mid. Cant help myself E has that HF splat which I know from some records which I not always like. But maybe this is because I also track on the DELTA which can be similar focussed in the same frequency region.
Post by Guitar on Dec 26, 2020 8:17:14 GMT -6
For me the E totally excels at rock style music, just a genius strip for that kind of mixing. Even in the plugin, not a console, you can sense why it's become a classic. On every track in a mix just about.
Post by subspace on Dec 26, 2020 9:29:52 GMT -6
I bought the J before X-mas, it's now $80 with today's sale plus voucher. I skipped the E and G, as I use CLA MixHub. Plan on using the J as my default AAX DSP strip and swapping in MixHub or Lindell 80 for flavor at mix.
Post by ericn on Dec 26, 2020 15:23:38 GMT -6
There is a reason that so many of the latter 4K refurbs had both EQ’s. Both are very useful but having both options is really the way to go. Personally I can never remember witch one I would rather have.
Post by mrholmes on Dec 26, 2020 17:37:14 GMT -6
Thanks for that link I did try the tag with the orange G Orange EQ on Acoustic Guitars. That was an interesting outcome I can boost top end, and it never sounds harsh or like the guitar is jumping into my face. Truly a unique EQ curve.
Are there any diagrams off the different SSL EQs where I can see how the bands work or overlap??
