Post by Johnkenn on Dec 16, 2020 12:46:27 GMT -6
I can't figure it out. I just can't. I give up. I know how to calculate, but for some reason when I use inserts, I'm not getting a delay, I'm getting a pre delay. like the effected signal is being placed BEFORE the original when it's recorded. So, I can record that, measure the difference in samples and then enter it in Time Adjuster and it's in time...but I'm also not getting any metering on my AUX. Would I not be able to use any plugs AFTER the insert? Isn't that the point of the insert?
Post by kcatthedog on Dec 16, 2020 12:47:57 GMT -6
Have you staggered your inputs 2 up due to Apollo using 1-2 as main outs?
Post by kcatthedog on Dec 16, 2020 12:50:31 GMT -6
Gannon posted this at UA forum a few years ago:
delay comp PT
Hi all,
There are actually two things to be aware of when using hardware inserts with Pro Tools and third party interfaces such as Apollo.
First - you do need to make sure your inserts are lined up. With Apollo, you need to go to I/O Setups in Pro Tools, select the inserts tab and drag the entire set over one pair so that Insert 1-2 is using I/O 3-4, Insert 3-4 is using I/O 5-6 etc. Apollo's MON out uses output pair 1-2, so you have to make this adjustment to line up your hardware inserts. (PT mode only aligns the Inputs and Outputs list, not Inserts.)
Second - you have to manage Delay Compensation in Pro Tools on a track by track basis - not just turn it on and off globally. It's easiest to describe it with an example, so try this:
1) Create three stereo audio tracks. 2) Set the output of Audio 1 to Bus 1-2 3) Set the Input of Audio 2 to Bus 1-2 and Input enable it 4) Create a Stereo Send on Audio 1, send it to Bus 3-4 and set it to unity gain 5) Set the Input of Audio 3 to Bus 3-4 and Input enable it 6) Insert a hardware pair on Audio 3 (you can use a patch cable between outputs and inputs to pass audio)
Now, look at the Delay Compensation numbers in the Mix Window. You'll see Audio 1 and Audio 2 are all 0 and Audio 3 shows 2351 in the top slot (Delay Indicator).
Drop a piece of audio onto Audio 1 and play it. You'll hear a delay between the two tracks. This is because Audio 2 is not being delayed to match the hardware insert on Audio 3.
Now, Control + Command Click on the bottom number of Audio 2 (Track Compensation Indicator). You'll notice it turns blue and goes to 2351 (the same number as Audio 3).
What you've done is isolated Audio 2 from the delay comp scheme so that Audio 2, which has no hardware inserts on it, has the same amount of delay compensation as Audio 3, which does.
This is a bare bones example, but you can use the same principles as your routing schemes become more complex with busses and other audio tracks.
Just keep in mind where your delays are and which elements need to be delayed and go from there.
I hope that helps!“
Post by Deleted on Dec 16, 2020 12:54:47 GMT -6
You have to enter the delays in manually in Native because AVID wants to get you to pony up for HDX, which does it automatically. That’s the main “benefit” of HDX over Reaper besides sharing Pro Tools sessions. Logic and Reaper have had easy, one click hardware insert pings for a long time. Logic is bad about plugin latency, good about hardware.
Post by Johnkenn on Dec 16, 2020 13:07:09 GMT -6
I’ve done all that. The Gannon example works but what does that have to do with how I want to use it?
Post by Johnkenn on Dec 16, 2020 13:07:49 GMT -6
I’m not getting a delay, it’s recording early.
Post by Blackdawg on Dec 16, 2020 13:16:20 GMT -6
hmm That might be a recording and latency setting. Like low latency can't be on or something.
Post by ragan on Dec 16, 2020 13:21:44 GMT -6
I can't figure it out. I just can't. I give up. I know how to calculate, but for some reason when I use inserts, I'm not getting a delay, I'm getting a pre delay. like the effected signal is being placed BEFORE the original when it's recorded. So, I can record that, measure the difference in samples and then enter it in Time Adjuster and it's in time...but I'm also not getting any metering on my AUX. Would I not be able to use any plugs AFTER the insert? Isn't that the point of the insert? You’re using the Time Adjuster plugin? So you’re delaying all the other tracks that don’t have the HW insert on them? I’ve always entered the figure into the I/O settings menu for hardware inserts.
Post by Ward on Dec 16, 2020 13:23:21 GMT -6
I’m not getting a delay, it’s recording early. in the mixer window, delay compensation . . . can that fix it?
Post by Johnkenn on Dec 16, 2020 13:45:32 GMT -6
I have no idea what’s going on...I can take say - drums - send them to a drum bus. Add hardware insert and it’s going to the Hw. But when I play back with the rest of the tracks, it’s AHEAD of the other tracks...and It no Longer shows as coming through the AUX (meters show nothing). So - I can actually use the trim delay before the Insert and get it right, but I’m still not seeing anything in the meters. My understanding would be the HW insert should be the channel that’s delayed...so you record it, calculate the delay and then add it into the HW insert compensation page. That does absolutely nothing on my end. Somewhere, something it’s askew.
Post by Blackdawg on Dec 16, 2020 14:03:46 GMT -6
This sounds like you don't have the apollo setup right if you're not seeing a return on the aux track.
Post by ragan on Dec 16, 2020 14:08:53 GMT -6
I have no idea what’s going on...I can take say - drums - send them to a drum bus. Add hardware insert and it’s going to the Hw. But when I play back with the rest of the tracks, it’s AHEAD of the other tracks...and It no Longer shows as coming through the AUX (meters show nothing). So - I can actually use the trim delay before the Insert and get it right, but I’m still not seeing anything in the meters. My understanding would be the HW insert should be the channel that’s delayed...so you record it, calculate the delay and then add it into the HW insert compensation page. That does absolutely nothing on my end. Somewhere, something it’s askew. What does your delay comp show on the I/O settings page for that HW insert?
Post by schmalzy on Dec 16, 2020 15:15:59 GMT -6
Things I've done a couple times when I had a similar problem:
1. I was monitoring the inputs in Console and didn't have input monitoring on in the DAW. 2. Monitoring my insert outputs rather than my master bus on the way back in. 3. Had the wrong inputs armed.
I'm sure you've checked those but that's all the info my experience can lend at this moment.
Good luck! Let us know if you figure it out (and how you fixed it)!
Post by indiehouse on Dec 16, 2020 15:27:44 GMT -6
I think I’ve made similar threads before about HW inserts in PT’s, especially on auxes, doing the EXACT same thing. Drives me insane, to the point of frustration and abandonment. I have no answers, only sympathy.
Post by ragan on Dec 16, 2020 15:54:42 GMT -6
I can't figure it out. I just can't. I give up. I know how to calculate, but for some reason when I use inserts, I'm not getting a delay, I'm getting a pre delay. like the effected signal is being placed BEFORE the original when it's recorded. So, I can record that, measure the difference in samples and then enter it in Time Adjuster and it's in time...but I'm also not getting any metering on my AUX. Would I not be able to use any plugs AFTER the insert? Isn't that the point of the insert? You should definitely be able to see signal after the HW insert, and put any further processing you want there, as long as you've got the complete loop in your analog gear and signal is getting back to the DAW. Also, it's worth noting that I haven't been manually entering HW insert delay for quite awhile. I don't know when but PT started automatically doing it. I haven't checked it with a transient loop/calculation because it seems to work correctly (nothing getting unsynced). But like, right now on my new machine, I never entered any HW insert delay in the I/O settings but when put a HW insert on, it comes up with delay on its own and shows it in the delay comp window at the bottom of the track.
Post by drbill on Dec 16, 2020 16:00:12 GMT -6
Geez. Sorry to hear all that John. ANY amount of this BS would drive me to buy HDX immediately, although I completely understand some not wanting to go there. I have had 0 issues with delay compensation and HDX over a decade, with (now) 112 insert points and an equal amount of hardware to patch in. It's perfection. Consider HDX.
Post by Blackdawg on Dec 16, 2020 16:07:02 GMT -6
Geez. Sorry to hear all that John. ANY amount of this BS would drive me to buy HDX immediately, although I completely understand some not wanting to go there. I have had 0 issues with delay compensation and HDX over a decade, with (now) 112 insert points and an equal amount of hardware to patch in. It's perfection. Consider HDX. Especially since the new hybrid engine is coming to HDX users too. That's going to be game changing. But yeah. Fellow HDX user here. Once I went to it, never looking back. Bulletproof.
Post by seawell on Dec 16, 2020 16:10:58 GMT -6
I used to get things coming back early like that when I had an Antelope Orion 32 HD, it drove me nuts! I'm on HDX with Avid HD I/O now and it works perfectly!
Post by adamjbrass on Dec 16, 2020 17:50:21 GMT -6
You could easily solve this by patching into a summing box instead
It’s also easy to solve by using a plug in.
Post by Johnkenn on Dec 16, 2020 18:00:59 GMT -6
Geez. Sorry to hear all that John. ANY amount of this BS would drive me to buy HDX immediately, although I completely understand some not wanting to go there. I have had 0 issues with delay compensation and HDX over a decade, with (now) 112 insert points and an equal amount of hardware to patch in. It's perfection. Consider HDX. Well, I just don't see the point in paying several thousand for something I can do in Cubase, Logic and soon Luna for free...This is just another reason to make me permanently move from PTs...I was hoping I could figure it out in PTs, because it was tracked in PTs and Luna doesn't have the capability yet. Cubase can do it at the moment, so maybe I'll mix in there.
Post by Johnkenn on Dec 16, 2020 18:06:24 GMT -6
Things I've done a couple times when I had a similar problem: 1. I was monitoring the inputs in Console and didn't have input monitoring on in the DAW. 2. Monitoring my insert outputs rather than my master bus on the way back in. 3. Had the wrong inputs armed. I'm sure you've checked those but that's all the info my experience can lend at this moment. Good luck! Let us know if you figure it out (and how you fixed it)! Let me ask - say I'm sending every drum channel to a drum bus and want to put a HW comp on the drum bus. Should I click the input monitoring on for each individual drum track? The AUX doesn't have an input monitoring clicky thing. (This is how technical I am)...I can hear the effected drums, they're just out of time with the rest of the track...I guess I AM monitoring inputs in console because if I mute that, I get nothing. Oh - does Low Latency mode have to be off? I bet that's it - it's the reason I'm not hearing anything when I mute console... Gonna go try.
Post by Johnkenn on Dec 16, 2020 18:10:34 GMT -6
Geez. Sorry to hear all that John. ANY amount of this BS would drive me to buy HDX immediately, although I completely understand some not wanting to go there. I have had 0 issues with delay compensation and HDX over a decade, with (now) 112 insert points and an equal amount of hardware to patch in. It's perfection. Consider HDX. Especially since the new hybrid engine is coming to HDX users too. That's going to be game changing. But yeah. Fellow HDX user here. Once I went to it, never looking back. Bulletproof. I mean, I guess it comes down to which brand you go with...I am already heavily invested in the UAD brand with it's own HDX like products...So - I guess I'm either waiting for Luna to get HW inserts or buying HDX. Drew @ UA Just wondered if there was anything I might be NOT doing with Apollo. I've moved my inserts over by one. I know I had some Cue issues in Luna because I had my I/O jacked in Console. I believe it's set to PT 32 Default now...so that shouldn't be any issue, right?
Post by Johnkenn on Dec 16, 2020 18:11:59 GMT -6
You could easily solve this by patching into a summing box instead It’s also easy to solve by using a plug in. Would you like to elaborate? You mean a $2000 D Box that has inserts and/or Time Adjuster?
Post by Deleted on Dec 16, 2020 18:29:59 GMT -6
Could automatic delay compensation be turned off?
Post by drbill on Dec 16, 2020 19:01:33 GMT -6
Geez. Sorry to hear all that John. ANY amount of this BS would drive me to buy HDX immediately, although I completely understand some not wanting to go there. I have had 0 issues with delay compensation and HDX over a decade, with (now) 112 insert points and an equal amount of hardware to patch in. It's perfection. Consider HDX. Well, I just don't see the point in paying several thousand for something I can do in Cubase, Logic and soon Luna for free...This is just another reason to make me permanently move from PTs...I was hoping I could figure it out in PTs, because it was tracked in PTs and Luna doesn't have the capability yet. Cubase can do it at the moment, so maybe I'll mix in there. I get it. The Delay Comp would be enough for me, but that's not the ONLY thing that HDX brings to the table. It's very powerful, and far more than a native version of Cubase, etc.. Hope you figure it all out!
