Post by wiz on Oct 8, 2020 17:17:48 GMT -6
Has anyone upgraded from RX7 Standard to RX8 Standard?
Most interested in the DeBleed Plug In? Used it?
Cheers
Post by EmRR on Oct 8, 2020 18:56:46 GMT -6
Yes, have only tried rebalance so far, that’s an enormous step up from 7.
Post by mrholmes on Oct 9, 2020 3:25:30 GMT -6
Has anyone upgraded from RX7 Standard to RX8 Standard? Most interested in the DeBleed Plug In? Used it? Cheers Wiz
BTW in that other thread you talked about denoising acoustic guitars. Thought about it but I don't get the point... Can you elaborate a bit?
Post by kcatthedog on Oct 9, 2020 4:28:39 GMT -6
A good funny review of 3 denoiser plug ins,
Post by wiz on Oct 9, 2020 4:35:46 GMT -6
Sure you grab a section of dead air and Judiciously de noise it you can add to depth and clarity
Post by stormymondays on Oct 9, 2020 6:55:38 GMT -6
I'm also wondering if the upgrade is worth it. I'm not a heavy user.
Post by nudwig on Oct 9, 2020 10:15:38 GMT -6
I upgraded from RX6 to RX8 Advanced. Also wasn't sure if I needed it but the guitar module alone is what got me, super handy. The rebalance was also nice to pull a touch of vocal bleed out of OH's from a live session.
Post by EmRR on Oct 9, 2020 13:05:54 GMT -6
Rebal is so improved it will make you rethink when to apply de-bleed.
Post by Deleted on Oct 9, 2020 13:31:05 GMT -6
Is there a discount for the upgrade from RX7 to RX8 ?
I think i may have missed it somewhere on their website.
Post by stormymondays on Oct 9, 2020 15:14:58 GMT -6
Is there a discount for the upgrade from RX7 to RX8 ? I think i may have missed it somewhere on their website. There is, still good for 3-4 days I think. It's on your Izotope account, but I can see it in other stores. So you can shop around for the best upgrade price, just make sure you pick the correct versions.
Post by wiz on Oct 9, 2020 17:30:04 GMT -6
Rebal is so improved it will make you rethink when to apply de-bleed. (sound of light bulb going off) aha!!! yes, that might be the ticket Cheers Wiz
Post by stormymondays on Oct 10, 2020 3:01:11 GMT -6
Rebal is so improved it will make you rethink when to apply de-bleed. Maybe I need the upgrade after all... I've been sent a finished track that has some existing programmed drums (light brushes) to overdub real drums on top of it, mix it and "master" it. It turned out great, but if you know what the original track was, you can probably hear some of the old drums here and there. Would you confidently use rebalance here to turn down those drums a little bit? Or would it turn "artifacty" and lose the quality?
Post by EmRR on Oct 10, 2020 14:49:17 GMT -6
Rebal is so improved it will make you rethink when to apply de-bleed. Maybe I need the upgrade after all... I've been sent a finished track that has some existing programmed drums (light brushes) to overdub real drums on top of it, mix it and "master" it. It turned out great, but if you know what the original track was, you can probably hear some of the old drums here and there. Would you confidently use rebalance here to turn down those drums a little bit? Or would it turn "artifacty" and lose the quality? I took a mono audience omni mic of a club show, and turned the vocals and guitars OFF, leaving drums and bass. I can turn the bass OFF. I can turn the drums OFF. I can turn OFF a guy yelling in my ear who's louder than the music, leaving minimal artifacts. This was not possible in RX7. If you want to remix Beatles stems, you can mostly do that now.
Post by the other mark williams on Oct 10, 2020 15:03:55 GMT -6
Maybe I need the upgrade after all... I've been sent a finished track that has some existing programmed drums (light brushes) to overdub real drums on top of it, mix it and "master" it. It turned out great, but if you know what the original track was, you can probably hear some of the old drums here and there. Would you confidently use rebalance here to turn down those drums a little bit? Or would it turn "artifacty" and lose the quality? I took a mono audience omni mic of a club show, and turned the vocals and guitars OFF, leaving drums and bass. I can turn the bass OFF. I can turn the drums OFF. I can turn OFF a guy yelling in my ear who's louder than the music, leaving minimal artifacts. This was not possible in RX7. Wow, that sounds amazing. Thanks for the heads up, Doug. It wasn't obvious to me how much that's been improved in 8.
Post by stormymondays on Oct 10, 2020 15:46:30 GMT -6
Well, that's going to cost me some money then!
Post by wiz on Oct 11, 2020 17:14:13 GMT -6
I bought it.... and.... the one plug I wanted to try... De Bleed... Doesn't show up in Logic... LOL
Its not there in the plug in manager....
I can see it if I load RX8 Standalone...
Tried all the usual fixes... no go.. have a ticket in with Izotope.
Anyone using RX8 In logic.. can you see if you have the De Bleed plug in available?
Cheers
PS the Music rebalance thing is quite remarkable...really...
Post by the other mark williams on Oct 11, 2020 18:26:03 GMT -6
I bought it.... and.... the one plug I wanted to try... De Bleed... Doesn't show up in Logic... LOL Its not there in the plug in manager.... I can see it if I load RX8 Standalone... Tried all the usual fixes... no go.. have a ticket in with Izotope. Anyone using RX8 In logic.. can you see if you have the De Bleed plug in available? Cheers Wiz PS the Music rebalance thing is quite remarkable...really... Looking at the iZotope website, it looks to me like De-Bleed isn’t available as a plugin, wiz. There’s no asterisk next to it.
Post by wiz on Oct 11, 2020 18:49:28 GMT -6
I bought it.... and.... the one plug I wanted to try... De Bleed... Doesn't show up in Logic... LOL Its not there in the plug in manager.... I can see it if I load RX8 Standalone... Tried all the usual fixes... no go.. have a ticket in with Izotope. Anyone using RX8 In logic.. can you see if you have the De Bleed plug in available? Cheers Wiz PS the Music rebalance thing is quite remarkable...really... Looking at the iZotope website, it looks to me like De-Bleed isn’t available as a plugin, wiz . There’s no asterisk next to it. www.izotope.com/en/products/rx/features/de-bleed.htmlif you read there it says plug in....?
Post by EmRR on Oct 11, 2020 19:02:05 GMT -6
Wow, it does, but it's not in the online manual as a plug-in, and I don't have it on the plug list in DP.
