Post by iamasound on May 7, 2020 13:32:23 GMT -6
This picture shows that only the top of the mic is playing the part of "Lady In Red". The base of the mic looks to be turned steel like a Beyerdynamic of sorts. Perhaps the red plastic jacket broke from live handling a d they continued to use the perfectly good mic as is bunched up with that Unidyne (?) that was probably used to send to an effect like a voice box.
Post by m03 on May 7, 2020 14:54:51 GMT -6
Perhaps the red plastic jacket broke Isn't that just more tape wrapped around the base?
Post by EmRR on May 7, 2020 16:00:38 GMT -6
you can see metal in the other videos too, under the clips. just more visible with the Capt.
Post by geoff738 on May 7, 2020 17:51:16 GMT -6
The metal is quite visible on the MC5 clip, particularly when Tyner takes the mic out of the clip. Appears to be a slim black ring just below the red bit. Which undoubtedly has the mics make and model. Not sure that helps?
Cheers, Geoff
Post by iamasound on May 7, 2020 19:36:02 GMT -6
Perhaps the red plastic jacket broke Isn't that just more tape wrapped around the base? Yup.
Post by geoff738 on May 11, 2020 18:08:46 GMT -6
Can anybody ID the mics in the Fanny clip that’s in the Beat Club compilation I linked a few posts back? They look to me like they might be the same mic without the red bling.
Cheers, Geoff
Post by EmRR on May 11, 2020 19:14:58 GMT -6
Different grill shape, but maybe that too....
Post by oliviadolphinjohn on May 14, 2020 21:17:48 GMT -6
I've been curious about those forever, but never bothered to ask. Here's another.
Post by timcampbell on May 15, 2020 2:18:06 GMT -6
I've been thinking about this and the red part might be a sleeve slipped over a mic to alter the polar pattern.
Post by geoff738 on May 1, 2024 13:20:04 GMT -6
Mystery solved
I can’t believe I remembered posting about these given how long ago it was. Cheers, Geoff
Post by ericn on May 1, 2024 14:31:26 GMT -6
I've been thinking about this and the red part might be a sleeve slipped over a mic to alter the polar pattern. 4 years later or someone painted the windscreen to easily ID it, seen some very bad attempts over the years.
