Post by mrholmes on Apr 13, 2020 9:38:03 GMT -6
RGOs.
It's some kind of wiered.
With some music I think it's a real bad idea to de-humanize a performance.
I am working on a modern rock ballad and I do think it fits the song to tighten the players timing up. To my ears it just sounds better.
No one is early or late it ... helps the arrangement / song.
Opinions please???
Post by christopher on Apr 13, 2020 10:26:01 GMT -6
its tricky, but I think 99% don’t understand. I’ll try to explain.
Musicians who have bad cue mix’s or aren’t developed all the way often will be a little sloppy in the time domain, so when you slide them to grid they sound tighter, cleaner, better etc. Most of the sloppiness is probably cue mixes IME.
Musicians who ARE developed AND have good cue mixes.. can push and pull within the tempo to create emotional impact. They can do this over the course of a few measures even with a click, decelerating and accelerating similar to heart rate.. nobody’s heart and mind is a robot, so that motion is a high level artistic choice. Think classical. It’s also difficult to pull off, and if failed won’t sound right, so it’s not always great. Many engineers simply always choose quantizing, eliminating that in the process while also leveling the field so the bad musicians and great ones all sound the same.
Lastly, production choices: quantized music is tight, boxy, packaged sounding. I call it mall music, because it’s awesome music to go shopping to. So if your target market is people who love to shop, with lots of credit cards... just not a care in the world.. quantized is the way to go.
If you are an angry or moody rock band and all your fans are depressed and poor, quantized is a DUMB thing to do.. (not always.. but usually IMO)
Post by Bob Olhsson on Apr 13, 2020 10:46:12 GMT -6
I'm sorry, "humanization" is and always has been bullsh!t.
The beginning of a sample is often not the beginning of a note. Good musicians know where the time is and often play with tension against even time. Adding slop is simply adding slop. I suppose it can sometimes improve things because it allows for sloppier overdubs but why would anyone pay to hear such garbage?
Post by tkaitkai on Apr 13, 2020 11:02:04 GMT -6
Modern music is almost always damn near perfect with regards to timing and pitch. I like that sound, so I have no issue time aligning and tuning as necessary.
There's usually a sweet spot between too loose/natural and too robotic/overdone. That's what I aim for.
YMMV.
Post by drbill on Apr 13, 2020 11:14:10 GMT -6
Completely depends on the music / genre. It took me years to really realize / feel that there is GOOD slop - and bad slop. Knowing which is which, and how MUCH to remove is the secret. I've got zero problems doing it, but I'll try not to go too far.
Post by soundintheround on Apr 13, 2020 11:43:45 GMT -6
There's no right or wrong....but depends on the music.
Personally, I think you can certainly ruin a vibe with quantization.
If you are doing overdubs to a track that was done with perfect MIDI or perfect samples, you really have no choice. But if you make an effort to capture good parts along the way and don't quantize, its amazing how much you can get away with, and how much it effects the feel of a song.
Post by christopher on Apr 13, 2020 11:46:45 GMT -6
This topic finally I think helped me make a breakthrough in understanding this whole thing, so thanks for posting Mr Holmes. I personally now think being tight to steady clock goes well with activities involving endorphins: Excercise, shopping, amusement parks, extreme sports, sex/uppers, loving life, being happy, and on and on. Mozart and bach I would fit into the cateogory. I've long had an absense of endorphins in my life, so all that music annoys the hell out of me! It does not match with me at all, only on rare occasions.. Example.. 80s music is awesome for those times when I do feel great, at the bar having a few drinks with friends, watching sports. Its some of the best endorphin music there is.
I grew up shopping at the thrift stores, nothing had sharp defined edges, everything wasn't perfect, couldn't afford paint to make the walls look nice, cars were falling apart, clothes with holes. I need music that isn't packaged neat and sharp with edges all perfect. I look at nature and there are no squares or grid anywhere. I gravitate toward debussy or vivaldi. I need accerleration and decay. Blues legends all used it, Rock did too until protools. Anyway,.. its probably my mental imbalance that I just deal with that has always made me a little off the path. Now though I can see where the masses probably love all this stuff I just don't get at all.
Post by mrholmes on Apr 13, 2020 12:41:55 GMT -6
Completely depends on the music / genre. It took me years to really realize / feel that there is GOOD slop - and bad slop. Knowing which is which, and how MUCH to remove is the secret. I've got zero problems doing it, but I'll try not to go too far. There's no right or wrong....but depends on the music. Personally, I think you can certainly ruin a vibe with quantization. If you are doing overdubs to a track that was done with perfect MIDI or perfect samples, you really have no choice. But if you make an effort to capture good parts along the way and don't quantize, its amazing how much you can get away with, and how much it effects the feel of a song.
The point to me is that the song feels tighter / stronger / when guitars and e-base are quantized against the rest. The technology is there... why not?
Post by Deleted on Apr 13, 2020 13:02:46 GMT -6
Some music just needs to vibe and it doesn’t matter if it’s sloppy as hell to the point of not finishing the song at the same time. Snapping to a grid kills the feel and groove. If your music has no vibe and feel, what’s the point? We’re in an age where popular rappers have worse flow than Puff Daddy and are quantized. The lowest common denominator audience can’t tell the difference but who wants to make music for a supermarket intercom?
I pretty much exclusively do metal. Bathory and Beherit will always be cooler and sound better than anything proclaiming itself “technical” or “sophisticated.”
Post by Deleted on Apr 13, 2020 13:13:05 GMT -6
Sometimes the drummer needs to push the band or lag behind in the pocket. Quantizing this ruins the feel. In many bands, the drummer is the primary songwriter and band leader. Why not let him push forward or hold and constantly pull his band mates back together verse by verse if it’s his band and everyone knows it?
In metal, often there’s one guitarist who writes everything whom the less technically adept drummer ends up playing to for most of the song. Why change that if it works and that’s how they play it?
Why make the recording of the band the platonic ideal of the written material as it would appear on a page rather than a captured as well as possible passionate performance of the band? Most of these artist can’t even read music. With overdubs, this has always been somewhat possible but records like The Stooges’ Fun House have always been realer than real performances that work better than 80s drum machine music’s abstracted visions of what everyone knows is an impossible reality. It’s like practical effects aging better than cgi. Don’t be Spinoza.
Post by drbill on Apr 13, 2020 13:25:13 GMT -6
it's all perspective. The reason "why not" is that it's very easy to distill the soul and vibe out of the music. It's often difficult to pull back far enough and have enough perspective during mixing / production. If you listen to 60's music, there is slop all over the place. Vocals are out of tune. Drummers are choking. And yet, we love it. But in 2020 they wouldn't even be considered acceptable demo's. Finding that balance is key. For certain styles like EDM or Techno based musics, yeah, they have to be 100% quantized, and then even tweaked further to tighten things up. But for blues or soul, if you go there, you're going to kill the soul. It's a fine line. A delicate balance. Generally, it comes with the experience of screwing up music.
Post by Deleted on Apr 13, 2020 14:06:12 GMT -6
60s and 70s have the best sounding drums and drum performances. Even classical music now is often a race to the bottom of who can play the most robotically. Major and well-distributed labels pretty much only release new music that might as well have been written by robots too.
Post by howie on Apr 13, 2020 14:27:02 GMT -6
This topic finally I think helped me make a breakthrough in understanding this whole thing, so thanks for posting Mr Holmes. I personally now think being tight to steady clock goes well with activities involving endorphins: Excercise, shopping, amusement parks, extreme sports, sex/uppers, loving life, being happy, and on and on. Mozart and bach I would fit into the cateogory. I've long had an absense of endorphins in my life, so all that music annoys the hell out of me! It does not match with me at all, only on rare occasions.. Example.. 80s music is awesome for those times when I do feel great, at the bar having a few drinks with friends, watching sports. Its some of the best endorphin music there is. I grew up shopping at the thrift stores, nothing had sharp defined edges, everything wasn't perfect, couldn't afford paint to make the walls look nice, cars were falling apart, clothes with holes. I need music that isn't packaged neat and sharp with edges all perfect. I look at nature and there are no squares or grid anywhere. I gravitate toward debussy or vivaldi. I need accerleration and decay. Blues legends all used it, Rock did too until protools. Anyway,.. its probably my mental imbalance that I just deal with that has always made me a little off the path. Now though I can see where the masses probably love all this stuff I just don't get at all. Interesting posts on this quantization. I came to recording late in life - through the back door - being a visual artist - Photoshop was my intro to computers around 2000 - I did not know how to work a mouse before I needed Photoshop - and I still use a Wacom graphic pen for Logic X (and everything else). I play banjo/guitar/bass and am a master of none so quantization in theory looks tempting - but when I set it up, I don't know, dunno - I like to play to the Logic drummer app which is a quantized thing. I don't make my living through music... and my ears are not what they used to be, that is for sure. I dislike music when shopping - don't want to hear someone's pop passions when I'm buying toothpaste at CVS, or any store. I don't like most modern genres - Hip Hop, EDM - and any those heavily 'perfect?' quantized forms - they leave me cranky- and looking for exit door. (Did like Kraftwork, though, back in 1977 - amusing). I grew up like most of us (now) 65 year olds from NY on Rock & Rock & Rock. Discovered old time music in 1971, and 5-string banjo (long story about my crappy NYC pownshop banjo. Banjo can be played robatically - but hopefully not.) You mention Mozart and bach - Ha. Why does bach not get to be capitalized? A Bachian slip? (I love Bach - oddly enough, perhaps - Bach became my favorite music: I NEVER would have expected that in my teen years) (I ran on a bit - being a rank amateur on a pro blog)
Post by bricejchandler on Apr 13, 2020 14:33:43 GMT -6
Whatever works! I'll often have quantized drums and leave everything else a little loose indie rock stuff. Some styles like punk rock sound weird to me when guitars and bass aren't pushing a bit... Modern metal is basically electronic music now, quantized midi drums, quantized guitars. It really depends on the genre and I've often destroyed the vibe of a song over quantizing...
Post by wiz on Apr 13, 2020 15:45:30 GMT -6
I once downloaded and quantised Old Man by Neil Young. It was amazing how it sounded.
Worth the time and effort to learn.
Cheers
Post by mrholmes on Apr 13, 2020 17:04:40 GMT -6
it's all perspective. The reason "why not" is that it's very easy to distill the soul and vibe out of the music. It's often difficult to pull back far enough and have enough perspective during mixing / production. If you listen to 60's music, there is slop all over the place. Vocals are out of tune. Drummers are choking. And yet, we love it. But in 2020 they wouldn't even be considered acceptable demo's.Finding that balance is key. For certain styles like EDM or Techno based musics, yeah, they have to be 100% quantized, and then even tweaked further to tighten things up. But for blues or soul, if you go there, you're going to kill the soul. It's a fine line. A delicate balance. Generally, it comes with the experience of screwing up music.
Well that's a good point drbillLive and learn - it never ends ... I sure did screw up things in my musicians live... But its part of the journey...
Thanks for your reminder not to be too picky.
Post by mrholmes on Apr 13, 2020 17:07:47 GMT -6
I once downloaded and quantised Old Man by Neil Young. It was amazing how it sounded. Worth the time and effort to learn. Cheers Wiz
LOL
Post by drbill on Apr 13, 2020 20:48:01 GMT -6
Well that's a good point drbill Live and learn - it never ends ... I sure did screw up things in my musicians live... But its part of the journey...
Here's a tip that might help.... When you're analyzing the rhythmic aspect of a song, THAT;s when you need to be careful, cause it's easy to keep pushing deeper and deeper into the correction thing. So be careful, when you're in that zone. But.... When you're just casually listening or mixing or doing other production things, if there's something that KEEPS pulling you out of the zone of getting into the song - THOSE - are the things that you should fix. Anything that consistently pulls me out of listening gets fixed.
Post by bricejchandler on Apr 14, 2020 0:58:25 GMT -6
Here's a tip that might help.... When you're analyzing the rhythmic aspect of a song, THAT;s when you need to be careful, cause it's easy to keep pushing deeper and deeper into the correction thing. So be careful, when you're in that zone. But.... When you're just casually listening or mixing or doing other production things, if there's something that KEEPS pulling you out of the zone of getting into the song - THOSE - are the things that you should fix. Anything that consistently pulls me out of listening gets fixed. 100%. When I'm working on a song I'll usually start the day by listening to it while doing my morning run. I don't analyze it, I just put it on a couple of times and my mind kind of drifts off. And the things that are wrong with the groove, or balances always seem really obvious because they stick out, and like you say they pull me out of the zone.
Post by mrholmes on Apr 14, 2020 3:45:55 GMT -6
Most of your tips come from decades of experience.
I love it. Thanks ....
In Logic there is a function that lets me correct single notes by hand.
This is a great thing if only one or two notes stick out because something distracted me. Distraction can happen easily with my ADD brain.
It saves time instead of doing a punch in. Big thanks to the staff at Apple for this....
Post by Ward on Apr 14, 2020 6:58:43 GMT -6
Sometimes the music calls for that hard quantized rigid robotic 80s sound, very common in EDM, Rap, Hip-Hop, Pop, country-pop, Pop-Rock, you know... 95% of the world's music. It's the other 5% we live for! Where natural humanization occurs, like Uncle Bob Bob Olhsson told us.
Post by bricejchandler on Apr 14, 2020 7:27:21 GMT -6
Sometimes the music calls for that hard quantized rigid robotic 80s sound, very common in EDM, Rap, Hip-Hop, Pop, country-pop, Pop-Rock, you know... 95% of the world's music. It's the other 5% we live for! Where natural humanization occurs, like Uncle Bob Bob Olhsson told us. Yeah definitely. And I feel it's a bit of a vicious circle, people started to over produce things and now the ear of the general public is tuned to everything sounding perfect. I had a younger musician that I produced who at first thought the Who recordings sounded small and badly played when I introduced him to it, now he's really come around on it but it took time. I think another problem is, most bands now record in small studios and record everything separately, and a lot of them don't play that well so gridding is kind of a necessity and sometimes one of the reasons some bands don't evolve. I've had it happen a couple of times, I get a band in, they can't play for shit, I end up spending most of the session just editing. They end up being happy about the product, though I warn them that what they're hearing isn't real, it's not what they really sound like but that it gives them a base to go out find gigs, and also hear how it's supposed to sound, and that if they work on their instruments, and everybody is disciplined with tempo work at home, they'll end up sounding a lot better than the gridded version. But unfortunately a lot of the time, they come back a year later and nothing's changed and I actually wonder sometimes if I'm doing them a disservice because I remember my first recordings as a teen were on the tail end of the tape era, no editing and we sucked and our first recording was humiliating and a wake up call. I didn't record for almost 2-3 years after that but when I did I was ready. It's a fine line, because I know that had I not edited, some of these bands would've been really unhappy with my work and I would've been unhappy too because my recordings would come out sloppy compared to the guy next door who quantizes everything... I don't work with those kind of clients anymore as most of my work is my own music production and the few bands I do work, I record all the basics live and I'm much happier with the results.
Post by mrholmes on Apr 14, 2020 7:48:09 GMT -6
I stress my guitar classes to use the metronome to learn how to play around the click (forgot the English terms for it)
For them it's a hobby and not a profession - in 95% of the cases I only hear excuses....
Post by drbill on Apr 14, 2020 10:52:18 GMT -6
Sometimes the music calls for that hard quantized rigid robotic 80s sound, very common in EDM, Rap, Hip-Hop, Pop, country-pop, Pop-Rock, you know... 95% of the world's music. It's the other 5% we live for! Where natural humanization occurs, like Uncle Bob Bob Olhsson told us. True anecdotal story that applies here I think. So...I had to do an arrangement / takedown / production of a Sinatra song for a Sinatra impersonator. I did the song, and orchestrated it exactly like the recording. But the impersonator kept telling me it was wrong. I went over and over it with a fine tooth comb and it was perfect. And I do mean perfect. Tempo changes, voicing, everything. Well...except one tiiiiny thing. (Keep in mind, this dude was beyond insanely fanatical. He'd literally sung over this song thousands of times. He had every inflection, etc. down perfect.). Finally after going back and forth with him, I got the guy in to the studio, imported the Sinatra song into the session to put it up against the programmed band / orchestra - and low and behold, there was a section in the song where Hal Blaine (RIP Hal, miss seeing you around) had a little bobble on one fill in the song. (I know, heresy, right?? haha). But I had programmed it in and auto corrected the fill to be "right" - cause it was a mistake in a live vocal / orchestra / band take that got overlooked cause the rest of the take was.....well....legendary. Well, this dude didn't want right, he wanted it with the warts. So I f'd it up exactly like Hal did, and he was happy. (It wasn't a huge deal, just a little timing bauble that most would never notice.) Sometimes, we get used to the inconsistencies in older songs that we know, and we grow to love them. In new stuff we're producing, the danger is to sanitize and iron out all inconsistencies until all humanity is gone. That can be a crime, and coming back years later can be quite a disappointment after you have some perspective. But yeah.....for the other 95%....
Post by Deleted on Apr 14, 2020 11:09:04 GMT -6
I won't do it. I'll fix obvious mistakes of course, but I won't take a performance and alter it to a grid. If not just because it's SO boring and tedious to do, but mostly, I just can't stand that level of perfection. I wouldn't tell a band they are "wrong" for wanting that and will happily refer them to someone I know that is proficient with that style of production. Just not what I like to do. I suppose if this were my day job, I wouldn't be in a position to say "no" so easily.
