Post by Johnkenn on Mar 13, 2014 9:09:00 GMT -6
Post by Martin John Butler on Mar 13, 2014 9:26:35 GMT -6
Not much info though. I have Superior Drummer, and hope they've made improvements and that any upgrade isn't expensive. "On the fly percussion" interests me a lot.
Post by Johnkenn on Mar 13, 2014 9:42:17 GMT -6
I'm sure SD3 is right around the corner...
Post by jazznoise on Mar 13, 2014 9:52:17 GMT -6
I used and enjoyed the first version, but the inability to save presets on the version I used would drive anyone dotty. However adding "percussion" (I'm hoping gueros, shakers, tamborines, tamborines mounted to hi hats?) would step it up a level again. Having all your percussion in one program certainly would streamline things.
And for whatever reason that final flam around 1:20 reminded me of the theme tune to That 70's Show..
Post by levon on Mar 14, 2014 0:51:04 GMT -6
I used and enjoyed the first version, but the inability to save presets on the version I used would drive anyone dotty. However adding "percussion" (I'm hoping gueros, shakers, tamborines, tamborines mounted to hi hats?) would step it up a level again. Having all your percussion in one program certainly would streamline things. And for whatever reason that final flam around 1:20 reminded me of the theme tune to That 70's Show.. This has been around for a long time: Latin Percussion
Post by mobeach on Mar 14, 2014 10:09:14 GMT -6
Is this program similar to Battery where you have to give each drum sample it's own MIDI channel?
Post by jazznoise on Mar 14, 2014 10:24:48 GMT -6
Yeah but surely then you're running two instances of EZ and 2nd might just be for a tambourine or a shaker or a (god forbid) guero??
Post by Johnkenn on Apr 19, 2014 23:03:37 GMT -6
Wow...this is actually pretty impressive from a songwriter's stance.
Post by lolo on Apr 19, 2014 23:11:26 GMT -6
This will be great for songwriting. Looking forward to this.
I saw Chris Whitten posted on the purple site that he knows SD3 is not in the near future.
Post by cowboycoalminer on Apr 20, 2014 7:12:17 GMT -6
Can you bounce out audio from EZ Drummer 2?
Post by Johnkenn on Apr 20, 2014 10:27:22 GMT -6
You mean like route multiple channels? yes...I always route parts to Audio channels and then render it to audio so I can effect it like I would a normal drumset. The thing that has me excited it the "tap to find" feature. You can tap out a rudimentary kick and snare part and it will search through all the midi files and find all relevant midi patterns. I'm not a drummer, so I always seem to have trouble with what a real drummer would do with cymbals and hats. This would be SUCH a time saver to me. At the end of the video it shows how you can find the groove you want, but if you like the hats from a particular one, you can paste those over...Basically, you find the groove you want and then you can adjust it, make it more complicated, change where the right hand is playing...all sorts of stuff.
Post by wiz on Apr 20, 2014 15:15:30 GMT -6
John
you probably have no interest in switching DAWs but LOGIC PRO X's new DRUMMER, is quite amazing at doing what you are chasing. In a very simple way. Have a look at some videos about it.
Wz
Post by Johnkenn on Apr 20, 2014 16:14:44 GMT -6
Yep. I've got Logic X...but I haven't used it that much because it's in Logic .
Post by wiz on Apr 20, 2014 16:58:57 GMT -6
I use it as a click track mostly, its brilliant for that, the ability to easily push and pull timing for starting a session is great ... so if you are starting a song on acoustic guitar, you can lay down against a timing reference that swings or pushes and pulls, but is in time..and is quickly and easily adjustable to fit your playing, rather than the other way around.. its wonderful for that
Post by cowboycoalminer on Apr 21, 2014 5:36:22 GMT -6
It would be great if they could do these upgrades to the Superior line.
Post by kcatthedog on Apr 21, 2014 6:05:26 GMT -6
John you probably have no interest in switching DAWs but LOGIC PRO X's new DRUMMER, is quite amazing at doing what you are chasing. In a very simple way. Have a look at some videos about it. cheers Wz Hey wiz, Could you describe this a bit more ? I now MJB uses LOGX and is digging the drums . I use SSD and really like the sound of the drum samples but struggle with the perfect click track as I write on acoustic and then record to click. thx !
Post by wiz on Apr 22, 2014 0:32:17 GMT -6
John you probably have no interest in switching DAWs but LOGIC PRO X's new DRUMMER, is quite amazing at doing what you are chasing. In a very simple way. Have a look at some videos about it. cheers Wz Hey wiz, Could you describe this a bit more ? I now MJB uses LOGX and is digging the drums . I use SSD and really like the sound of the drum samples but struggle with the perfect click track as I write on acoustic and then record to click. thx ! Sure.... 8) Pick a Tempo you think you will like. Instantiate Drummer, and pick a basic, basic groove. I just usually have Hi Hat Snare and Kick. Simple as can be. Then I adjust the push and pull and swing controls, within drummer .... until it fits with how I am playing the core rhythm of the tune. Almost always for me, its on acoustic guitar. I tweak the drummer to match me, not the other way around. Its brilliant, and fast. Drummer also has the ability to generate its kick pattern, by following any other track in the project. So you could get it to follow a bass part you have played for instance. Might go something like this. Set tempo to 120bpm Find pattern, push, swing to suit what I am doing on acoustic. Lay down acoustic guitar. Play bass line that has the feel i want, now set drummer to "Follow" the bass track, kick now works off bass line, I could edit the bass line to make the kick drum do exactly what I want, mute that track then recut the bass. spice season and stir 8) cheers Wiz
Post by kcatthedog on Apr 22, 2014 8:26:35 GMT -6
Thx Wiz: that sounds very interesting.
Is drummer only available within LogX, not a stand alone app/player ?
Post by wiz on Apr 22, 2014 15:43:17 GMT -6
only with Logic Pro X.
Post by Deleted on Apr 22, 2014 16:12:20 GMT -6
I love AD - a bit OT.
I only use the raw samples played back and multi-tracked out to audio. I then mix it like a real kit
I'm looking forward to their new version.
Post by lolo on Apr 23, 2014 5:25:52 GMT -6
Post by Deleted on Apr 23, 2014 6:01:18 GMT -6
Interesting bits from the review: Chuck Ainley and Neve Gretsch and Yamaha Adjustable Ghost notes
Has my attention for sure.
Post by Johnkenn on Apr 23, 2014 8:08:47 GMT -6
Yeah - I'm definitely gonna pick up.
Post by Johnkenn on May 6, 2014 7:42:27 GMT -6
I'm about to pick this up...I'll report back...
Post by warren on May 6, 2014 9:24:48 GMT -6
me too haha
