Post by nomatic on Dec 7, 2019 14:17:58 GMT -6
Wasn't there a software hack to get old mac pros able to upgrade to current OS?
Post by drbill on Dec 7, 2019 14:37:51 GMT -6
Wasn't there a software hack to get old mac pros able to upgrade to current OS? Mojave or Catalina? I took my 5,1's (2) and upgraded them to Mojave from Yosemite last month. It was tricky. First, I had to boot into Sierra and flash the hardware. Then I had to put the computer and put in a newer video card, and re-boot into Sierra and Flash the hardware again when installing Mojave. Then it worked. It was also tricky, because I couldn't flash from an external drive. Had to be "inside" the Mac. Had my Mac tech guy send me a drive set up to do it. Then ultimately put in my own drives after all the hardware flashing. If you need someone to walk your thru it or provide the correct drives / video cards / etc., I can put you in touch. PM me. It's not something I'd do without guidance. But that's me....
Post by nomatic on Dec 7, 2019 15:47:16 GMT -6
Thanks!
Post by Blackdawg on Dec 7, 2019 20:31:45 GMT -6
Just follow this: dosdude1.com/mojave/I used this on a 3,1 pro and it worked fine. Just need to get a better you since Mojave takes more power.
Post by sirthought on Dec 9, 2019 15:25:37 GMT -6
Yes, you have use the dosdude1 software.
Post by mrholmes on Dec 9, 2019 16:52:13 GMT -6
I hacked my old 1.1 to run El-Capitan but this is the end of the line.
