Post by Martin John Butler on Sept 24, 2019 17:28:50 GMT -6
I just put this together only to find out the BV-12 has been replaced by the CV-12 BLA, ha! I'll have to try that new mic out at AES next month.
Post by Vincent R. on Sept 24, 2019 18:07:37 GMT -6
The BV-12 never quite took off in popularity as the brighter CV-12. Is that the REDD?
Post by Martin John Butler on Sept 24, 2019 20:09:48 GMT -6
Can't say ;-) I didn't want the other mic to become the discussion. Avantone new mic, the CV-12 BLA is a major redesign and seems like it might be something special at a really great price. They discontinued the BV-12 because they felt the CV12 BLA was just way better. I'm looking forward to trying it at AES.
Post by johneppstein on Sept 24, 2019 20:19:48 GMT -6
"Better" means "Different".
I don't always agree that "different" is actually better.
Generally speaking, of course.
Post by chessparov on Sept 24, 2019 21:35:46 GMT -6
I bet it'll be ripe, for modding. Paging Chad @ Signal Arts. Chris
Post by Vincent R. on Sept 24, 2019 22:10:40 GMT -6
The original CV12 was nearly part for part identical to the TNC ACM1200. I had two of those TNC mics at one point. Had Advanced Audio modify one into their CM12 and the other into their CM251. I thought the AA mods were nice and better sounding over all than the TNC stock mics, but I also made a couple of really nice recordings with the ACM-1200 stock mic. There is a reason Taylor Swift used the CV12 on her early albums, it's a solid mic if you're going for a bright yet intimate sound. The TNC won a few shootouts over my U87ai. I'm curious about the new revamp of it, but there are probably better mics out there.
Ha ha Martin. Fine. Personally, I don't really think the BV12 compares well with the 5k mic. I think if I heard it on its own I might not mind it, but next to the other mic I really think it sounds cheap.
Post by Vincent R. on Sept 24, 2019 22:11:32 GMT -6
I bet it'll be ripe, for modding. Paging Chad @ Signal Arts. Chris There are cheaper donor options for that.
Post by Martin John Butler on Sept 25, 2019 8:42:20 GMT -6
I think the BV-12 was interesting, but a bit sibilant and needed more clean gain. With the upgrades Avantone have done with the new CV-12BLA, it probably addresses those issues and may actually be one of the best deals under 1k. So I'll see if I can get one to try out. I'm friendly with the guys at Avantone. They were a great help when I chose the Avantone Abbey's as monitors. Unfortunately I needed to sell them to pay bills.
Part of my reasoning for putting up that video was to remind those with less mic experience than many of us have to look around. The latest flavor of mic may not necessarily be their best choice. When I eventually have a real tracking room and can mic a band, I'll look around to see if there's any instrument the BV-12 just happens to be a good fit for. With Black Lion Audio involved now, I expect the newer model could be noteworthy.
I'm always interested in hearing as many new mics as I can. I keep an inventory in my head for future needs. There's a cool little $50 ISK mic that I like on acoustic bass for instance. I'd take the Lewitt 640 over any 414 I've heard except maybe the early ones with the original capsule. I would love to have a pair of Soyuz 0-13 FET's as overheads.
I'm beginning to appreciate FET's more than I used to. Plug and play, no power supply and all the accompanying cables to power and connect it.
Post by svart on Sept 25, 2019 8:44:25 GMT -6
"Better" means "Different". I don't always agree that "different" is actually better. Generally speaking, of course. Everything new always has to be "better" or else nobody would feel the pressure to "upgrade".
Post by Martin John Butler on Sept 25, 2019 8:49:17 GMT -6
Yep! I wouldn't mind an SM7B in my stable too, just for those moments that it's the only choice, if you know what I mean.
Post by Cyrus Melchor on Sept 25, 2019 13:26:22 GMT -6
Aw shoot this reminds me that I guess I kinda liked the CV12. I tracked this with one several years ago
It does the breathy style very well. Naama loved that mic and was bummed when she found out I sold it for a Peluso 2247 (which I really dig). But I feel you on appreciating FET options more nowadays and solid state in general.
Post by popmann on Sept 25, 2019 15:40:59 GMT -6
You don't think the Avantone is about 4-5db louder in the mix?
Post by tkaitkai on Sept 25, 2019 17:17:47 GMT -6
Thanks for sharing Martin!
This seems pretty consistent with my own comparisons between various low and high end mics. The Avantone doesn’t sound terrible — in fact, it’s a perfectly usable sound — but compared to the $5k mic, it sounds brash, smeary, and washy, whereas the $5k mic has a noticeably cleaner midrange and much broader soundstage overall. There’s some weird funk in the BV-12’s midrange that I don’t think EQ could fix.
Still, though, you could do a lot worse than the Avantone. Great video!
Post by drbill on Sept 25, 2019 17:57:33 GMT -6
The original CV12 was nearly part for part identical to the TNC ACM1200. I had two of those TNC mics at one point. Had Advanced Audio modify one into their CM12 and the other into their CM251. I thought the AA mods were nice and better sounding over all than the TNC stock mics, but I also made a couple of really nice recordings with the ACM-1200 stock mic. I did a huge shootout on GS in 2009 with the 1200, a K H 47, an M49, an MJ 47, U87, UM71S, MJ 319 and a few others I think. I forget. I kind of posed it as "contenders vs classics" both FET and Tube. For quite awhile the 1200 was doing REALLY well in the polls. The U87 dominated the FET's, with the MJ modded 319 coming in 2nd. The Gefell did poorly, because it really needs the vocalist close, and I did all mics up at once for the FET's and Tubes - 1 take for FET's, one for Tubes. On the Tubes, the MJ modded 460 (same essentially as the 1200) won the most votes. M49 second, stock TNC1200 close behind in 3rd, and the K H U47 in last. LOL K H did say that that mic had not been in for service in years, but the rental company I rented it from said it was a favorite of many clients. You CAN do a lot with a little it seems.....
Post by Martin John Butler on Sept 25, 2019 19:09:35 GMT -6
popmann, the Avantone was definitely not louder on my end. I may have hit the first word or two harder, but after that, if anything the other mic was louder. Maybe it's pushing frequencies that seem louder?
I've become interested in the newer CV-12 BLA. I'l see if I can get my hands on one to try at AES
