Post by guitfiddler on Aug 26, 2019 12:36:56 GMT -6
For those of you who have your Apollo’s cascaded...Do you have them in the rack together? They get pretty warm, should I be concerned about them being on top of each other in the rack?
Post by kcatthedog on Aug 26, 2019 13:32:07 GMT -6
Yes: one space between each is recommended
Post by drsax on Aug 27, 2019 6:26:01 GMT -6
For those of you who have your Apollo’s cascaded...Do you have them in the rack together? They get pretty warm, should I be concerned about them being on top of each other in the rack? I have 3 apollos (an 8 and two 16’s) with no space between them for the past 2 years with no problems at all. The top unit has one space above it. But if you have the space, it’s preferable to leave gaps between each unit though. I don’t have enough rack space to do it that way.
Post by Drew @ UA on Aug 27, 2019 10:27:59 GMT -6
We do recommend a space above in the manual to be safe, but as drsax noted, many users stack them without issue.
It's really up to each user's comfort level.
Post by kcatthedog on Aug 27, 2019 11:13:40 GMT -6
Heat kills electronics, so why have no space, if you can have space?
Post by Drew @ UA on Aug 28, 2019 10:10:29 GMT -6
Official recommendation is still 1 space, but we do test no space and half spaces! Attachments:
Post by kcatthedog on Aug 28, 2019 10:21:20 GMT -6
Who invited him anyways ??
Post by hio on Aug 29, 2019 4:34:59 GMT -6
Official recommendation is still 1 space, but we do test no space and half spaces! Your i/o will most likely get you there but 68 SHARCs will be your bottleneck and I find it hard to believe it would be sufficient for even a full album project.
