Post by johneppstein on Sept 17, 2020 13:05:41 GMT -6
Doug, would it be a big deal to include a light showing signal present at the input of the device? That's my only beef with pre's that don't have metering. A detector/indicator circuit like that still requires a separate power supply section for SS circuit voltages, plus the detection and LED driver circuit itself. In this sort of case I'm not sure that you don't have to have a parallel preamp circuit to raise mic level high enough to drive a detector circuit successfully. I don't know how cheaply it could be done, it certainly raises production costs, changes internal design, etc. No, I don't believe it does, at least in most cases. LEDs are generally very low voltage devices and you could just rectify a tap off the heater line in a tube unit.
Post by Guitar on Sept 17, 2020 13:43:09 GMT -6
A detector/indicator circuit like that still requires a separate power supply section for SS circuit voltages, plus the detection and LED driver circuit itself. In this sort of case I'm not sure that you don't have to have a parallel preamp circuit to raise mic level high enough to drive a detector circuit successfully. I don't know how cheaply it could be done, it certainly raises production costs, changes internal design, etc. No, I don't believe it does, at least in most cases. LEDs are generally very low voltage devices and you could just rectify a tap off the heater line in a tube unit. Thanks I might try that in my Selmer tube amp. I am trying to convert the lamp power indicator to an LED, that's a great idea.
Post by Quint on Sept 17, 2020 19:32:10 GMT -6
I wish somebody would make a stereo V72 or V76 clone in a 2u chassis. 1u would be even better, but I realize that it's tough to fit all of those tubes in that small of a space, especially when considering heat.
Post by tkaitkai on Sept 17, 2020 20:15:40 GMT -6
I wish somebody would make a stereo V72 or V76 clone in a 2u chassis. 1u would be even better, but I realize that it's tough to fit all of those tubes in that small of a space, especially when considering heat. Mercury does a stereo V72 in 2u — the M72s MKIII and M72s CSV. I almost bought the mono version years ago before I bought my Wunder. I still want one, though. And one of the Weight Tanks, too.
Post by johneppstein on Sept 17, 2020 23:08:22 GMT -6
No, I don't believe it does, at least in most cases. LEDs are generally very low voltage devices and you could just rectify a tap off the heater line in a tube unit. Thanks I might try that in my Selmer tube amp. I am trying to convert the lamp power indicator to an LED, that's a great idea. Most pilot lights in guitar amps already run off the 6.3 VAC heater line. For an LED you'll probably want a resistor in series with the LED.
Post by johneppstein on Sept 17, 2020 23:10:24 GMT -6
I wish somebody would make a stereo V72 or V76 clone in a 2u chassis. 1u would be even better, but I realize that it's tough to fit all of those tubes in that small of a space, especially when considering heat. You might try hanging the tubes out the back, like they did with rack gear in the old days. Good ventilation!
Post by Ward on Sept 18, 2020 5:20:05 GMT -6
I wish somebody would make a stereo V72 or V76 clone in a 2u chassis. 1u would be even better, but I realize that it's tough to fit all of those tubes in that small of a space, especially when considering heat. Like the Mercury?[/font][/url] Well, it's considerable more than DOUBLE the cost of the Weight Tank. $4500 list with street price at $3800 (1900 a channel) versus less than 1/2 that per channel for Eric's 72. Does it have the same 'girth' as Mercury's fat-bottomed girl? Well, nobody has said otherwise yet . . . and I'll let you know my thoughts. Although I have used a Mercury, I do not own one. Buutttt... I have a pretty good memory for sound. So I can give you a tiny bit of weight in on how they compare, and thus we could always lobby Eric for a stereo/dual version of it if it seems like a sellable product.
