Post by matt@IAA on Jan 17, 2018 19:48:37 GMT -6
The panel is pre-cut for a DB25 at the "expander" port. So DB25 it is.
Post by matt@IAA on Jan 21, 2018 22:16:18 GMT -6
Got the opamps all done today. My mill-max pins and the two 47k resistors I miscounted will be here tomorrow. Almost done soldering...
Post by matt@IAA on Jan 27, 2018 13:01:57 GMT -6
Post by matt@IAA on Feb 3, 2018 14:37:11 GMT -6
There are two R66s on the schematic. Hahaha. That took me a while.
Post by matt@IAA on Feb 3, 2018 16:09:24 GMT -6
Fired her up... new sum bus is oscillating. Sigh. Time to start troubleshooting.
Post by matt@IAA on Feb 5, 2018 14:34:03 GMT -6
Well, good news is I figured out why it was oscillating and everything seems to be out together right. Bad news is it’s oscillating because of insufficient power supply capacity on startup. If I isolate the startup of the board vs the box I can get up to two opamps working fine. Or four opamps by themsleves. But if I bring up the four and then add the rest of the box, they oscillate. I felt like the NASA engineers trying to get the startup sequence right on Apollo 13. Need to figure out my next move...
Post by matt@IAA on Feb 10, 2018 19:31:34 GMT -6
Ok,Its working. I hooked up a scope and noticed even with only two op amps and no signal there was a 3.5 Hz 165 mV oscillation. On a hunch I added a separate ground wire from the ACA board power common... low frequency oscillation gone. Added back all op amps.. everything fine.
The problem? Cheap DB25 cable! The cable has 6 ohm resistance per wire! I tripled up all the power and grounds on the spare pins. And now I need to get a better cable.
Post by matt@IAA on Feb 14, 2018 14:38:17 GMT -6
Time to wrap this up. It's all done, and doing a quick sweep with RMAA shows that the output is consistent with both the direct and track outs (i.e., no huge frequency shifts or anything). I replaced the mystery brand bargain bin cable, and also tripled the number of ground, +V and -V pins being used. No significant voltage drop through the cable now. I also added an additional unbalanced leg from each side of the booster output for metering. Since the balanced outputs are on a floating ground, you can't feed them back into the existing metering or monitor section on the board (without using another transformer to unbalance them, that is). The 2503s are 1:1+1+1 and in the booster output they're configured for 1:2+1. So I took the extra 1:1 output (-6dB) and fed that back into the board for metering and monitoring. To isolate the original post-fader booster op amps, I removed their load resistors (R66 - be careful! there are two R66's! The one you're looking for is the 47R right next to the J6 jumper NOT the 22k R66 near the transistor!) and fed into the metering circuit from the other side. In case anyone is wanting to do this, all you need in addition to the CAPI ACA-BO kit is: - a small board to land your channel bus resistors
- (24) 47k resistors
- (2) DB25 connectors
- (2) TRS connectors to replace the original RCA outs
- some wire to make the connections
- A box for the CAPI ACA.
The only loss of functionality in doing this is that if you're monitoring your track outs for some reason, the 2 track out monitoring is 6 dB below that level. However, you could easily adjust this by manually setting each the monitor feed pots (R42) so that they're hitting the monitor section at the same level. Someone mentioned they were thinking about doing this - if you have any questions, let me know.
Post by wiz on Feb 14, 2018 15:53:49 GMT -6
Fantastic stuff and thank you for sharing...
so....
whats it sound like?
Cheers
Post by matt@IAA on Feb 14, 2018 17:00:04 GMT -6
Haha. It sounds great on the limited testing I can do the in the lab. My AD/DA and all the rest of my gear isn't set up right now, because some folks are living in my studio while their house gets rebuilt after flooding during Hurricane Harvey last August.
They should be back in their home this month. It was supposed to be January... I'm getting antsy.
Post by jamessw on Dec 3, 2018 15:15:35 GMT -6
- Replace electrolytic capacitors. Increase all capacitance by 10x except for C3 and C7 which are timing caps for the solo circuit
Control Room Card | Existing: |
| Replace with: | | Cap | uf | V | uf | V | C1 | 22 | 16 | 220 | 35 | C2 | 22 | 16 | 220 | 35 | C3 | 1 | 50 | 1 | 62 | C5 | 10 | 25 | 100 | 35 | C6 | 10 | 25 | 100 | 35 | C7 | 1 | 50 | 1 | 62 |
- Replace electrolytic capacitors (*C10 is a radial all others axial). Increase all capacitance by 10x
I/O Card | Existing: |
| Replace with: | | Cap | uf | V | uf | V | C3 | 10 | 25 | 100 | 35 | C9 | 22 | 16 | 220 | 35 | C10* | 10 | 25 | 100 | 35 | C11 | 22 | 16 | 220 | 35 | C12 | 10 | 25 | 100 | 35 | C13 | 10 | 25 | 100 | 35 | C14 | 22 | 16 | 220 | 35 | C19 | 22 | 16 | 220 | 35 | C20 | 22 | 16 | 220 | 35 |
I'm looking to recap my 1280b only. Can I recap with these larger values without any other mod? Will this be safe and will it be better than using the same stock values?
Post by matt@IAA on Dec 3, 2018 20:28:44 GMT -6
Yeah, you can use the higher values or not without any other mod.
