Post by johneppstein on May 16, 2017 14:46:16 GMT -6
Thanks Mac, I'll have a look. I do not know the type of rubber, all I do know is it dates to the late 1950's or early 1960's. I'm guessing that it's some sort of synthetic, I believe they tend to last longer than natural rubbers. The question is, which one?
Post by EmRR on May 16, 2017 15:06:13 GMT -6
I need to find the right document, or a volunteer rubberologist. : )
Post by tasteliketape on May 25, 2017 20:52:23 GMT -6
You might try an "o" ring supply house where they make o rings What they use would take pressure. Only draw back might be will it bond to your material, but I think would be similar.
Post by johneppstein on May 25, 2017 21:31:17 GMT -6
You might try an "o" ring supply house where they make o rings What they use would take pressure. Only draw back might be will it bond to your material, but I think would be similar. What's needed takes tension, not pressure.
Post by tasteliketape on May 25, 2017 23:01:14 GMT -6
O rings get stretched being put over shafts if being installed in a groove on the shaft or you can just pull on one they will take quite a bit of stretch (tension) I've even seen some mic shock mount made of o rings, my Korby shock mount had two large o rings But hey don't try it if you don't think it will work
Post by johneppstein on May 26, 2017 1:50:29 GMT -6
O rings get stretched being put over shafts if being installed in a groove on the shaft or you can just pull on one they will take quite a bit of stretch (tension) I've even seen some mic shock mount made of o rings, my Korby shock mount had two large o rings But hey don't try it if you don't think it will work Well, it's more a question of the properties of the glue in this case. I've seen O rings used in shock mounts, but here they need to have those arms connected. And most of the O rings I've had experience with tend to fail under tension if they get nicked...
