Post by Deleted on Dec 16, 2016 10:40:00 GMT -6
I designed the NT-2 and NT-1, much better mics from what I've read. I wish I read all this stuff before buying
Post by Deleted on Dec 16, 2016 10:41:05 GMT -6
I designed the NT-2 and NT-1, much better mics from what I've read. I wish I read all this stuff before buying Believe d-essers are sometimes used in mastering too?
Post by scumbum on Dec 18, 2016 11:36:07 GMT -6
I've had constant sibilance problems forever . Just sick of mix time and having to do all these tricks to make it work .
I've found compression seems to always add it and condenser mics . So things might change , but for now I barely use compression and I started to use an SM58 . SM58's don't seem to have sibilance problems . SM57's are sibliant for me .
Try an SM58 , EQ "before" the compressor , use just enough compression to tame it a little , automate the fader for volume .
Thats where I'm at today .
Obviously not the greatest vocal sound with the SM58 but it works and I don't have to worry about sibilance anymore for now . I wanna try the M80 soon though .
Post by scumbum on Dec 18, 2016 15:45:28 GMT -6
I built this 251, and I'm getting what for me seem to be some spectacular and inspiring vocal sounds, really got me going right now. This mic makes me sound like a better singer. The problem is I seem to need a De-Esser on almost any given performance. I don't consider myself a particularly sibilant singer, in fact my voice is actually probably better described as somewhat dark. I am using an ADK GK-12d capsule. I am fairly certain that if I changed my capsule to a Heiserman, Campbell, or BeezNeez, the presence boost would move into the air regions and give that flatter darker mid you'd expect from a CK12 microphone. I've done some intensive internet research, and I do believe this particular ADK capsule to have some of that spittiness or edginess to it. I love the low end on it though. I'm getting a very 'warm' sound in the mids and bottom. I had some similar issues with my similarly of Chinese provenance Peluso capsules which are long gone. Also not a true CK-12. I have yet to try out a properly made CK12, by that I mean historical correctness of the complex acoustic chamber in the backplates. This is ADK's brightest capsule, and you can hear it. I could also consider the ADK GK-251d capsule, which might give a similar but somewhat darker tonality. This reminds me of my Peluso 2247 SE, which always seemed to need some little EQ, so it fell out of favor. I know EQ is very common, de-essing is probably fairly common, I just for some reason expect a vocal mic to sound nearly ideal when recorded flat. I do have a couple mics that sort of work like that. I don't know if that is a realistic expectation or if I should think more of a 'perfect vocal chain' involving these other elements as a standard practice. It's just a little nerve-wracking because it's so close, and there's not a whole lot of DIY kind of work left to do at this point. I've darkened the top and boosted the lows as much as I comfortably can, the problem zone is in that tricky high-midrange area. With a little de-essing and avoiding top end boosts, the vocals sound great, and sit in a good place in the mix. Well, way up front. A couple DIY options I haven't experimented with are lowering the capsule polarization voltage, and/or using the second half of the tube as a buffer to lower THD and tube coloration. Backing off the mic seems to help some, my natural tendency is to get right up on it. Maybe I just need to practice better engineering depending on what mic is set up. I don't know if I've been lazy, sloppy, or lucky, but I have very rarely had to use de-essing on most of the mixes I've done in the past 15 years. To suddenly need it all the time seems kind of strange to me. I was looking around the net, and it seems like a lot of people use it somewhat to very frequently as a matter of course. I guess I'm curious what people think about de-essing in general. If it comes up a lot and you just do it, or if you put in all kind of setup to completely avoid it? I'll probably end up with a different capsule. If you had a mic with sibilance problems would you think it was a bad mic? I forgot to mention in my last post I use that Lower- Z Microphone Impedance Reducing Adapter that bill recommended with my SM58 . BUT!!!!! And thats a big hairy smelly BUT........ I've found when using it with all mics it seems to reduce sibilance , even condensers . I would pick up one of those adapters and try it with your mics . Can someone explain why that adapter reduces sibilance ?? What its doing to the sound ?
Post by Guitar on Dec 18, 2016 15:50:22 GMT -6
I should give that a try, I have two of those lying around. I believe presenting a different load impedance to the microphone changes the frequency response, and for some reason I think dynamic mics are especially sensitive to this. There was a Peterson Goodwyn video about this on YouTube where he interviews an engineer from Shure and they talk about this phenomenon in some detail.
I also ordered a DBX de-esser just for the hell of it.
Also I found that a simple EQ cut about 2 dB at about 6K really helps a lot with this mic in particular, and FabFilter de esser is great.
Thanks for all the feedback, it has been very helpful.
Post by stormymondays on Dec 18, 2016 16:49:06 GMT -6
I use the very affordable Hornet Sybylla de-esser. I listened to a few comparisons and I liked it. I have been using it without giving it much thought though...
Post by matt555 on Dec 18, 2016 17:05:07 GMT -6
So much useful info here thanks guys. I think I am going to pull the trigger on a DBX520 also. I do a lot the recordings/live sound for my brother. We both have naturally "essy" voices so I always end up using de-essers for live work, or for non live work going through and drawing down each "ess" the required amount in DAW. Like said previously this is slightly time consuming, but I feel it yeilds the best results. For his voice, an SM58 yeilds better results with less "esses" than an SM57 smiliar as mentioned above.
Ive built a few diy mics now, and I also built a ELAM 251 E with a tim campbell capsule and its slightly "essy", not on every singer, but on some, yes. However I feel the over-all sound, other than esses, is so much nicer to my ears than my other mics, I live with that and just work on the esses after the recording. Hopefully in the future I will have an U87 or U67 style mic available that I can use on those singers with worse esses for studio work.
One thing I will say is that I decided to do a recording without my AML EZ1073 pre in the chain and instantly regretted it. Now I understand when people say they miss peices of gear/sound they get from a bit of gear, that they have either sold or no longer have.
Appreciate everyones input! Thanks Matt.
Post by jakeharris on Dec 18, 2016 20:16:35 GMT -6
I built this 251... The problem is I seem to need a De-Esser on almost any given performance. Which cathode bypass cap are you using? You can drastically modify the character of a 251 build just by changing brands.
Post by Guitar on Dec 19, 2016 7:11:24 GMT -6
I believe it's a Nichicon Gold at the moment.
Post by ChaseUTB on Dec 19, 2016 11:42:41 GMT -6
Had to pull out
Ren De esser X 4 UAD precision de esser x 2 Waves DeEsser x 2 Waves c6 x2 TDR Nova eq x 2
For 2 out of the 3 members vox on one mix.... I'm talking clipped vox/ Chinese ldc/ clipped ic mbox pre/ MP3 beat clipped and squashed... Great weekend 😂😭
Post by EmRR on Dec 19, 2016 12:17:33 GMT -6
I forgot to mention in my last post I use that Lower- Z Microphone Impedance Reducing Adapter that bill recommended with my SM58 . BUT!!!!! And thats a big hairy smelly BUT........ I've found when using it with all mics it seems to reduce sibilance , even condensers . I would pick up one of those adapters and try it with your mics . Can someone explain why that adapter reduces sibilance ?? What its doing to the sound ? This? reverb.com/item/1402020-shure-sm57-lower-z-microphone-impedance-reducing-adaptorAppears to be a pile of mis-information for one thing, the seller in question don't seem to know what they are talking about. It has to be a 620 ohm resistor across pins 2-3 to present a lower impedance to the mic than the preamp does naturally. The comment that preamps were designed as 600 ohms is absolute non-sense. Preamps were virtually always bridging impedance as they are today, with a few exceptions. It's reported in audio magazines for several decades that a Shure 57 or 58 sounds better at 600 ohms, giving them flatter response with a reduced treble peak in the sibilant area. As to the effect on other mics, any time you present a lower Z load than expected, you roll off the highs in a dynamic mic. In a condenser you lower it's headroom and increase it's distortion, depending on the type you may also reduce it's treble content.
Post by jakeharris on Dec 19, 2016 13:03:26 GMT -6
I believe it's a Nichicon Gold at the moment. Have you already tried an Elna Silmic instead? At least for me, it's a big step up from the Nichicon (FG, SW, KZ all sound sub-par in that position). Worst of all on cathode are the Nichicon VR and VZ, all my builds turn shrill and sibilant when I try them. Great clarity in the lows and mids, better than the Muse series, but the highs are trash. The Elna's also increase apparent bass, so if you've gone much higher than 100M on the grid, you might have to cut that back. For the same reason, a 22uf Elna can easily replace a 47uf Nichicon or Panasonic, and keep the same apparent bass level, but with the better clarity of a smaller bypass. But mainly, the mids/highs sound great with the Elna, and low-end goes deeper (Bock 251 uses Elna too).
Post by Guitar on Dec 19, 2016 13:15:59 GMT -6
I believe it's a Nichicon Gold at the moment. Have you already tried an Elna Silmic instead? At least for me, it's a big step up from the Nichicon (FG, SW, KZ all sound sub-par in that position). Worst of all on cathode are the Nichicon VR and VZ, all my builds turn shrill and sibilant when I try them. Great clarity in the lows and mids, better than the Muse series, but the highs are trash. The Elna's also increase apparent bass, so if you've gone much higher than 100M on the grid, you might have to cut that back. For the same reason, a 22uf Elna can easily replace a 47uf Nichicon or Panasonic, and keep the same apparent bass level, but with the better clarity of a smaller bypass. But mainly, the mids/highs sound great with the Elna, and low-end goes deeper (Bock 251 uses Elna too). Wow that's some really specific feedback! I'll have to give the Elna a try. I really like the Silmics in my mic preamps. I had no idea that particular cap could make that much difference! My grid to ground resistor is up to 60 Megaohms, 30M was just way too thin and shrill with this capsule.
Post by EmRR on Dec 19, 2016 13:28:44 GMT -6
Cathode bypass cap types will make the largest difference in a mic circuit. Much less so to none at all in a preamp circuit.
Post by thehightenor on Dec 19, 2016 13:29:43 GMT -6
Tracking through a Retro STA Level has reduced my need to De-ess on own vocals and what's left I go the extra mile and de-ess manually as I prefer the result.
When I'm working with a client on a more limited budget then I'm use a de-esser plugin usually the Fab filter one.
Post by jakeharris on Dec 19, 2016 14:20:09 GMT -6
Wow that's some really specific feedback! I'll have to give the Elna a try. I really like the Silmics in my mic preamps. I had no idea that particular cap could make that much difference! My grid to ground resistor is up to 60 Megaohms, 30M was just way too thin and shrill with this capsule. Brand differences aside, not only capacitance but also voltage rating makes a difference in this position. Went through all sizes and types until finding my favourites (pic of some of them w/ FG, SW, KZ, Silmic, Panasonic FC). Probably cost me $5 total in parts to try out two dozen caps. If ever, a simple method to audition all of them is with a 1p/12p rotary switch. Connect all +ve legs to the switch, -ve legs to ground, and wire the switch input to tube cathode. With this setup you can switch through the different caps with the mic powered on. Same method can be used for coupling caps, plate to ground LPF, etc. But I'd also try out 100M for the grid with a 22 or 47uf cathode cap, tilting the response a bit more towards the low-end. 60M is still very conservative (C12 uses 250M). Attachments:
Post by Guitar on Dec 19, 2016 14:28:28 GMT -6
wow thanks a lot jakeharris looks like I've got some tweaking to do!
Post by scumbum on Dec 20, 2016 0:02:28 GMT -6
I forgot to mention in my last post I use that Lower- Z Microphone Impedance Reducing Adapter that bill recommended with my SM58 . BUT!!!!! And thats a big hairy smelly BUT........ I've found when using it with all mics it seems to reduce sibilance , even condensers . I would pick up one of those adapters and try it with your mics . Can someone explain why that adapter reduces sibilance ?? What its doing to the sound ? This? reverb.com/item/1402020-shure-sm57-lower-z-microphone-impedance-reducing-adaptorAppears to be a pile of mis-information for one thing, the seller in question don't seem to know what they are talking about. It has to be a 620 ohm resistor across pins 2-3 to present a lower impedance to the mic than the preamp does naturally. The comment that preamps were designed as 600 ohms is absolute non-sense. Preamps were virtually always bridging impedance as they are today, with a few exceptions. It's reported in audio magazines for several decades that a Shure 57 or 58 sounds better at 600 ohms, giving them flatter response with a reduced treble peak in the sibilant area. As to the effect on other mics, any time you present a lower Z load than expected, you roll off the highs in a dynamic mic. In a condenser you lower it's headroom and increase it's distortion, depending on the type you may also reduce it's treble content. Yeah thats the one. Reduce the treble content......thats probably what its doing . It changes the tone of every mic I've tried it with and it always seemed less sibilant . You know with digital and condensers , less treble content might not be a bad thing .
Post by rowmat on Dec 22, 2016 17:35:20 GMT -6
I've fitted output transformer 620 ohm load resistor switches and 1200/300 ohm input transformer impedance selector switches to my SCA N72 and J99 preamps.
Depending on the source, mic and mix choosing the 'wrong' impedance can often be sonically more pleasing to the ear.
Using the 300 ohm input transformer setting can add weight, body and reduce sibilance of a thin vocal.
Post by ericn on Dec 22, 2016 18:10:24 GMT -6
I designed the NT-2 and NT-1, not the A versions that are surface mount. I've rebuilt a lot of dbx 902's but I've never had a reason to use one in the last 40 years. Pick the mic and preamp carefully and those things will collect dust. Sibilance is acceptable and necessary for a natural sound. Over use that stuff and the singers get a lisp and sound gay. Funny I think heavy need for Dessing, I think John Mayer, that boy anything but gay!
Post by jazznoise on Dec 22, 2016 18:28:56 GMT -6
Put the mic between 6 to 12 feet from the singers mouth, pointed down.
That's most plosive and sibilence issues sorted. The real problem is people eating the mic.
Post by Guitar on Dec 23, 2016 7:52:11 GMT -6
Put the mic between 6 to 12 feet from the singers mouth, pointed down. That's most plosive and sibilence issues sorted. The real problem is people eating the mic. I don't know if that's a typo or not, but that's hilarious!
Post by Ward on Dec 23, 2016 7:59:10 GMT -6
I also assumed it was a typo, and was going to suggest just putting the microphone in a different room to the singer and solving the problem that way. But look at jazznoise there, all standard and defying the EU and their Metric Laws!!
Post by jazznoise on Dec 23, 2016 8:18:26 GMT -6
Sorry I meant 1.5e+8 - 3.0e+8 nM.
Post by Ward on Dec 23, 2016 10:38:22 GMT -6
Sorry I meant 1.5e+8 - 3.0e+8 nM. What the hell is that? First svart and now you?
