Post by Johnkenn on Apr 16, 2016 16:54:18 GMT -6
Yeah - I'm gonna attempt another build at some point.
Post by NoFilterChuck on Apr 16, 2016 21:53:43 GMT -6
I was talking with tony about your build you sent him. he said he noticed right away somethin' really simple and small. He said the DOA sockets didn't have enough solder on 'em and were probably cold solder joints, which would explain why your build didn't work. No DOAs, no sound! I haven't heard anything since, but if that's all it was to make 'em work, you should be happy that you did a solid job on the rest of the build! So, get back to buildin'!!!
Post by tonycamphd on Apr 16, 2016 22:21:35 GMT -6
I was talking with tony about your build you sent him. he said he noticed right away somethin' really simple and small. He said the DOA sockets didn't have enough solder on 'em and were probably cold solder joints, which would explain why your build didn't work. No DOAs, no sound! I haven't heard anything since, but if that's all it was to make 'em work, you should be happy that you did a solid job on the rest of the build! So, get back to buildin'!!! JK did a pretty solid job for a just starting out noob! I went through this thing as much as i could, i reflowed the entire thing and pretty much believe it's a final output transformer issue? I was going to switch it out with one of mine, but Jeff said he'd take care of it, so I'm sending it back failing to fix the problem. For me, the most difficult thing is there is no schematic for referencing while trying to chase things down, and i'm not a good enough of an electronics guy to go beyond what i've done without one, so.... off she goes...., i am very curious to find out what the problem actually is.
Post by noah shain on Apr 17, 2016 13:53:18 GMT -6
Looks like I'll be building 10 of these. Holy crud.
Hey someone fill me in on Fix. What is it?
Post by noah shain on Apr 17, 2016 13:57:51 GMT -6
And this looks like a WAY easier/faster build than the LC
LOOKS like....
Post by ericn on Apr 17, 2016 14:58:19 GMT -6
Looks like I'll be building 10 of these. Holy crud. Hey someone fill me in on Fix. What is it? Paul Wolf Who used to own API & Tonelux and Designed most of the modern API, has designed a new board modules are on API 500 series spacing the frame is completely modular the master section control room section is the controller he designed for Slate. Check it out at Fix Audio designs. It looked nice at NAMM!
Post by noah shain on Apr 19, 2016 11:37:10 GMT -6
Looks like I'll be building 10 of these. Holy crud. Hey someone fill me in on Fix. What is it? Paul Wolf Who used to own API & Tonelux and Designed most of the modern API, has designed a new board modules are on API 500 series spacing the frame is completely modular the master section control room section is the controller he designed for Slate. Check it out at Fix Audio designs. It looked nice at NAMM! Thanks Eric. Realized I had seen it before. Looooong time coming... JEEEEEEEFFFFFFF!!!! OPEN THE STORE!!!
Post by ericn on Apr 19, 2016 11:45:15 GMT -6
Paul Wolf Who used to own API & Tonelux and Designed most of the modern API, has designed a new board modules are on API 500 series spacing the frame is completely modular the master section control room section is the controller he designed for Slate. Check it out at Fix Audio designs. It looked nice at NAMM! Thanks Eric. Realized I had seen it before. Looooong time coming... JEEEEEEEFFFFFFF!!!! OPEN THE STORE!!! Let's give him a break to get moved in, plus he's got this and the Graphic EQs to get to market ! Maybe you need to make a Roadtrip to Nashville ? Time for another RGO get together !
Post by odyssey76 on Apr 19, 2016 12:08:43 GMT -6
Thanks Eric. Realized I had seen it before. Looooong time coming... JEEEEEEEFFFFFFF!!!! OPEN THE STORE!!! Let's give him a break to get moved in, plus he's got this and the Graphic EQs to get to market ! Maybe you need to make a Roadtrip to Nashville ? Time for another RGO get together ! There's graphics as well? Like the 560?
Post by ericn on Apr 19, 2016 13:23:44 GMT -6
Let's give him a break to get moved in, plus he's got this and the Graphic EQs to get to market ! Maybe you need to make a Roadtrip to Nashville ? Time for another RGO get together ! There's graphics as well? Like the 560? Jeff has 2 that use knobs rather than sliders there is a thread here somewhere and they are on his site!
Post by jcoutu1 on Apr 25, 2016 8:52:10 GMT -6
Any more news on these? How are they different from the LC's? They have the same EQ points, but I see these honkin' switches in there. Price, ease of build, differences to the LC's, all questions that we need answers to!
Post by NoFilterChuck on Apr 25, 2016 13:10:35 GMT -6
the LC53s use Inductors and Capacitors to achieve the filtering. This new EQ uses Resistor/Capacitor networks to do the filtering.
Post by jsteiger on Apr 25, 2016 15:49:15 GMT -6
Hey guys, still trying to get organized since the move. Trying to get setup so I can reopen the store has been my priority. Getting close. Hoping to reopen on the 1st.
The new BT50 will street for $449.99 plus 2 opamps. The first batch of Grayhill switches are due in about a week or 10 days. The knobs should be here later in May. Metal is in production. Faceplates will be printed and done in about 2 weeks. My goal is for the kits to be released by the end of May.
The only similarities between these and the LC53A's are the freq points. Chuck has already (very well) described the filter topologies. I have not had a chance to do any side by side listening but will have some pro's doing that over the next few weeks. I will try to get some clips for download at similar settings. The highest amount of cut/boost they have in common is 6dB.
I hope to have the LC25 and LC40 kits released before the BT50's. I have the final PCB Rev here that I want to build up and test. Switches are here for those. Metal is also at the print shop.
Busy, busy, busy!!!
Post by roundbadge on Apr 25, 2016 21:29:58 GMT -6
I havent been this excited for new eqs in ages. I am so looking forward to replacing my modern 550's and 560's with these and Jeff's new 10 banders!
Post by odyssey76 on Apr 26, 2016 14:28:26 GMT -6
I havent been this excited for new eqs in ages. I am so looking forward to replacing my modern 550's and 560's with these and Jeff's new 10 banders! I'm going to learn how to solder just because of these EQ's. It was just a matter of time....
Post by roundbadge on Apr 26, 2016 14:50:39 GMT -6
I had the 10 bands here a bit ago.just lovely. focused warm finished record sound.
Post by tonycamphd on Apr 26, 2016 16:20:13 GMT -6
this is gonna be great! i need to get a bunch of new face plates, and new capi style knobs to bring my VINTAGE Capi stuff up to the new Capn standards! 8)
Post by Johnkenn on Apr 26, 2016 16:28:18 GMT -6
I havent been this excited for new eqs in ages. I am so looking forward to replacing my modern 550's and 560's with these and Jeff's new 10 banders! I'm going to learn how to solder just because of these EQ's. It was just a matter of time.... Let me chime in...Being the master veteran that I am, it's pretty easy...(by the time you get to the end of the project.)
Post by Johnkenn on Apr 26, 2016 16:29:06 GMT -6
That was sarcasm, btw.
Post by odyssey76 on Apr 26, 2016 16:51:48 GMT -6
Yeah but you also started with a VP28. Not really a novice's 1st project. Go big or go f*** yourself, I guess! Lol. Did you watch any vids or get some kind of practice kit? The CAPI stuff is just way too good and this is a skill I really should learn anyway. I'm dying for some nice outboard EQ's.
Post by odyssey76 on Apr 26, 2016 16:53:32 GMT -6
this is gonna be great! i need to get a bunch of new face plates, and new capi style knobs to bring my VINTAGE Capi stuff up to the new Capn standards! 8) You'll love the new knobs. More open, airy top, punchier mids and tighter bass response. They're brilliant.
Post by rowmat on Apr 26, 2016 18:09:34 GMT -6
Yeah but you also started with a VP28. Not really a novice's 1st project..." I reckon jump right in at the deep end with a LC53A!
Post by winetree on Apr 26, 2016 18:24:20 GMT -6
I'm keeping all my older CAPI gear face plates with the Law suit knobs. Someday everyone will want the vintage Capi gear.
Post by Johnkenn on Apr 26, 2016 19:26:37 GMT -6
Yep. Me too
Post by ericn on Apr 26, 2016 21:43:53 GMT -6
I do like the FU API Knobs! It's the coolest knobs since 1970!
