Post by Ward on Feb 7, 2016 21:35:09 GMT -6
So, one of my song co-writes got picked up for a TV show airing February 15th on PBS, also being carried and re-broadcast in New Zealand and Australia. The show is called "Put Some Color in your Life", and the song is called "Someone else's trouble now". They're using two 30 second segments of it, possibly extended to 1 minute.
Anyone know standard sync rates for PBS and NZ/AU??
Thanks in advance!
Post by Ward on Feb 8, 2016 11:34:10 GMT -6
Nothing from Johnkenn? What about in Australia and New Zealand, wiz?
Post by Ward on Feb 8, 2016 13:25:03 GMT -6
Post by wiz on Feb 8, 2016 15:37:20 GMT -6
I have no idea Ward let me see what I can find out for you cheers Wiz
Post by Ward on Feb 8, 2016 17:48:00 GMT -6
I have no idea Ward let me see what I can find out for you cheers Wiz Thanks bro!
Post by wiz on Feb 9, 2016 16:14:37 GMT -6
I have no idea Ward let me see what I can find out for you cheers Wiz Thanks bro! Here is the reply I got... There are no set rates except for AMCOS library tracks. Original material just comes down to your or your publisher's negotiating skills. Bear in mind some production companies ask for a cut of the royalties.
that help? Wiz
Post by Ward on Feb 9, 2016 16:54:15 GMT -6
That helps a lot actually! Thank you.
Post by Ward on Feb 9, 2016 16:54:31 GMT -6
Does the same thing apply for NZ?
Post by wiz on Feb 9, 2016 18:22:45 GMT -6
Does the same thing apply for NZ? Don't know.... But probably involves sheep 8) cheers wiz
Post by Ward on Feb 9, 2016 20:09:37 GMT -6
Does the same thing apply for NZ? Don't know.... But probably involves sheep 8) cheers wiz Easier to screw than a kangaroo!
