Post by kidvybes on Nov 30, 2015 12:10:26 GMT -6
I also don't pass judgement on his mixing skills. I feel as if your statement is dangerously close to passing judgement on his mixing skills based on a couple of single tracks hastily thrown up on a forum.. ...etiquette lessons from Svart?... ...listen, I'm really just trying to help M57 cut thru the process of sussing out the best mic...if being frank comes off too judgmental, I'm guilty...
Post by Bob Olhsson on Nov 30, 2015 12:14:19 GMT -6
Beware that mike shootouts almost never reveal what I think are the three most important aspects to choosing a mike.
1. How good does it sound on absolutely anything so that the person being miked won't become bored?
2. What does it sound like in the context of a mix relative to other instruments and how well it takes processing?
3. What does it sound like on vocals without a wind screen? What does it sound like on kick drum with a windscreen?
A KM-84/86 has always won the first two. The third has often been a big surprise. I also assume every single mike will be shock-mounted. This includes putting the mike and stand on an isolation pad if need be.
Post by M57 on Nov 30, 2015 12:42:12 GMT -6
First, I'm very appreciative of the level of honesty that I'm hearing from this crowd. I mean it. I'm finding it very thought-provoking and instructive in a productive way. Yes, my engineering skills are lacking, but I did put some thought into how to present these mics, and the 'path' that I chose was purposely one involving compromise. I used compression on the way in because ..well, that's how I plan on recording when I'm doing the real thing. I purposely did not present the tracks naked with no accompaniment because that's not how I'm doing the real thing. Yes, I understand the point is to be able to isolate and be critical of the mic, but I was cognizant of the 'what does it sound like in the mix' argument, so instead of throwing it in with a dense mix, I chose a 1+1 (a compromise). Did I use too much compression on the way in? Probably - I just bought the compressor a few months ago so I got a little carried away, but the tone of that compressor is likely going to be the standard for me at least for the near future. My intention was to knock a few db off the edges, not crush things. I can tell you that SoundCloud changed the way the mics sound MUCH more than the compressor did.
Post by M57 on Nov 30, 2015 13:35:48 GMT -6
Beware that mike shootouts almost never reveal what I think are the three most important aspects to choosing a mike. 1. How good does it sound on absolutely anything so that the person being miked won't become bored? 2. What does it sound like in the context of a mix relative to other instruments and how well it takes processing? 3. What does it sound like on vocals without a wind screen? What does it sound like on kick drum with a windscreen? A KM-84/86 has always won the first two. The third has often been a big surprise. I also assume every single mike will be shock-mounted. This includes putting the mike and stand on an isolation pad if need be. This sounds like good advice for those who are managing a locker, but in my case I am shooting out these mics for a single specific instrument (me). I don't care about versatility, and I don't care how it sounds on a kick. I mentioned in a separate post about compromise where processing is concerned. The only one I didn't use a shockmount on was the GZ47, not that I see it as that important because I'll most likely NOT be using the mic when other instruments are playing in the room, and I don't tap my foot when I sing. Though now that you mention it, it just occurred to me that a shockmount is probably much more important where recording my piano is concerned.
Post by Ward on Dec 1, 2015 9:44:15 GMT -6
...etiquette lessons from Svart?... Oh the ironical humor of it all!
Post by miscend on Mar 31, 2016 15:22:11 GMT -6
My vote goes for the 3U Warbler MKID. It sounds better in the mix.
The GZ47 comes a close second.
