Post by stratboy on Sept 16, 2015 21:16:08 GMT -6
UAD Brainworx bx_digital V2 M/S EQ, Vintech x73i pair, Elysia xFilter, IGS S-type
Post by Jason on Sept 16, 2015 21:21:14 GMT -6
Wooly Mammoth Standard Issue and EQP-WA.
Post by drsax on Sept 16, 2015 21:52:09 GMT -6
Charter Oak SCL-1 Buss Comp & Charter Oak PEQ-1 EQ
I've got a ton of outboard but these two have kept everything else off of my 2-buss
Post by levon on Sept 16, 2015 23:46:31 GMT -6
AU or VST? Great answer Wiz, thanks for the laugh on this grey rainy morning. I have a Manley Vari-Mu, followed by a Retro 2A3 and, most recently, followed by a Kush Clariphonic. Everything in tiny doses.
Post by jayson on Sept 17, 2015 6:15:23 GMT -6
Right now I've got a Vintech 609CA into a Great River EQ-2NV across the 2-bus. Pretty much there for flavor though; neither are doing any particularly heavy lifting.
Post by jimwilliams on Sept 17, 2015 9:24:50 GMT -6
A pair of 3' runs of Kimber AGSS pure silver cable from the console outouts feeding the PCM4222 EVM ADC. Same as usual. Buss compression is delt with in mastering. EQ is applied locally, never globally.
Post by b1 on Sept 17, 2015 9:38:15 GMT -6
Today, nothing for me mix-wise, usually. I agree with Jim on the EQ locally and Mastering process.
Future: other ADC's.
Post by rickcarson on Sept 17, 2015 9:42:11 GMT -6
Nice its cool to see how everyone is working.
Post by dandeurloo on Sept 17, 2015 10:32:19 GMT -6
Today is the same as Yesterday.
In a few weeks these mixes are going to DVS at Focus Mastering. Who knows what he will do to them.
Post by Johnkenn on Sept 17, 2015 11:34:42 GMT -6
Ha...well, yeah, if I could afford it, I'd leave everything off and send it to mastering...
Post by donr on Sept 17, 2015 13:17:34 GMT -6
Ha...well, yeah, if I could afford it, I'd leave everything off and send it to mastering... I've been mixing ITB with just VCC mixbus SSL or API or Trident, sometimes UAD Ampex and a DP Masterworks Limiter only to prevent overs. But I'll go back and massage the 2 mix with comps eq whatever and limiting if I can get more out of it. I just don't mix into it.
Post by mdmitch2 on Sept 17, 2015 19:58:35 GMT -6
Currently, SB4001 and VP28's. About to try adding CAPI 553 eq's.
Post by rickcarson on Sept 18, 2015 5:34:50 GMT -6
DAn do you take your processing off before you send it to doug? I leave my eq comp and deeser but Ill take off the limiter
Post by dandeurloo on Sept 18, 2015 7:39:05 GMT -6
DAn do you take your processing off before you send it to doug? I leave my eq comp and deeser but Ill take off the limiter No, I send him how I mixed it. I don't use a limiter on mixes when mixing so I don't have to worry about it. I often fake master my stuff to see what might change once limiting is applied and I'll go back and tweak the mix of something ugly happens.
Post by noah shain on Sept 18, 2015 11:48:24 GMT -6
Uh oh...bring on the flames!
MAAG EQ4 Overstayer Fet MKII Retro 2a3 Roll Super Stereo Overstayer VCA AWTAC Channel Amps Western Electric 111c Ampex 440b
Scares me just to write it
Post by mdmitch2 on Sept 18, 2015 12:12:23 GMT -6
Uh oh...bring on the flames! MAAG EQ4 Overstayer Fet MKII Retro 2a3 Roll Super Stereo Overstayer VCA AWTAC Channel Amps Western Electric 111c Ampex 440b Scares me just to write it Post API 1608?? You think your new CAPI mods will cut back on some of that, or just add to the oooey gooey goodness?
Post by noah shain on Sept 18, 2015 12:23:26 GMT -6
Uh oh...bring on the flames! MAAG EQ4 Overstayer Fet MKII Retro 2a3 Roll Super Stereo Overstayer VCA AWTAC Channel Amps Western Electric 111c Ampex 440b Scares me just to write it Post API 1608?? You think your new CAPI mods will cut back on some of that, or just add to the oooey gooey goodness? Some of that is on the 2 bus insert some is post. No way! I'm gonna add more!!!
Post by rickcarson on Sept 18, 2015 13:13:15 GMT -6
I wanna try a pair of those 111c's
Post by forgotteng on Sept 18, 2015 18:51:54 GMT -6
Vintech 609CA and Daking FetIII
lms
New Member
Post by lms on Sept 18, 2015 21:33:06 GMT -6
API 525 (trans only) Eisen Audio Lilpeqr SSL MB comp API 2500 Mcdsp channel 2
Been living without the limited for a year now.. Love the air and impact I'm getting. All settings are subtle.. No more than .5 to a db of gr
Post by keymod on Sept 19, 2015 4:59:35 GMT -6
John Oram Hi-def 35 EQ into Alan Smart C2
Post by Randge on Sept 19, 2015 10:12:10 GMT -6
Just the Hofa Limiter today to make roughs. I haven't welded myself to one particular chain for the 2 Buss just yet. Maybe that will change when I get a Charter Oaks SCL-1. I would rather go back to the individual tracks for eq if something isn't laying right and polish there first. Randy Leroy at Airshow mastering in Takoma Park, MD does all of my mastering, so I give it to him unprocessed on the 2-buss generally. For more aggressive music, I will sometimes mix into some compression. That is a song by song treatment for me.
Post by Gustav on Oct 18, 2015 11:49:30 GMT -6
M/S decoder and M/S Coder lets you convert LR to M/S EQ it then Convert it back. That reminds me, I forgot to post whats on my 2bus. How much is the Avenson? I have a DIY board in the shop that creates a balanced, stereo MS send/return with switched send return level, insert bypass and solo functions. There are so few being sold, I won't bother making another batch when they are gone, so just wondering what a built unit is going for. Gustav
Post by jcoutu1 on Oct 18, 2015 12:26:14 GMT -6
M/S decoder and M/S Coder lets you convert LR to M/S EQ it then Convert it back. That reminds me, I forgot to post whats on my 2bus. How much is the Avenson? I have a DIY board in the shop that creates a balanced, stereo MS send/return with switched send return level, insert bypass and solo functions. There are so few being sold, I won't bother making another batch when they are gone. Gustav Got a link? How difficult is the build? Gotta be pretty simple right?
Post by kcatthedog on Oct 18, 2015 15:02:58 GMT -6
3 ua plugs: vari mu (little glue), bax eq ( mastering setting ) and precision k(little widening).
