Post by kcatthedog on Sept 19, 2015 16:32:19 GMT -6
So got the 2 superchunks corner front bass traps in 32x18X 75 inches of roxal safe and sound
curious to redo room eq wizard !
out getting dinner having a cold one will post pic in a bit !
Post by kcatthedog on Sept 19, 2015 17:13:44 GMT -6
Post by jazznoise on Sept 19, 2015 17:28:26 GMT -6
Woah! I'm very curious about the acoustic properties of an upside down control room! I guess it removes ceiling reflections?
Post by kcatthedog on Sept 19, 2015 18:02:32 GMT -6
exactly, but I can never get my Ozzy recording mates out of my house: they friggin love it !!
Post by formatcyes on Sept 20, 2015 16:17:36 GMT -6
Do you have that upside down mic that was posted here about a year ago? Good fix make the whole studio upside down. We will have to send you some Vegemite now you are almost one of us
Post by formatcyes on Sept 20, 2015 16:19:21 GMT -6
BTW I like the look of your room.
Post by kcatthedog on Sept 20, 2015 16:34:49 GMT -6
Send Sheilas and fewer architectural compliments !
Thx, the chunks really have improved the mid and lower bass a lot. I also put those long absorbers at top walls along side walls.
The 2 SC cost less than $100 cdn; money very well spent.
Post by jazznoise on Sept 20, 2015 18:02:25 GMT -6
Gonna do another test? Graphs are like sfw porn for engineers.
Yeah, I said it.
Post by kcatthedog on Sept 21, 2015 16:33:02 GMT -6
yup just about done nailing everything to the cieling seriously just busy selling some gear to try to afford some amphions. I'll need to stop complaining about shipping as my adcam 545 just got to Jim, 2 days early !!
Post by gouge on Sept 26, 2015 7:57:19 GMT -6
The 11 is the front and back wall. I will get chunks for front corners done this weekend. I'll redo measurement then and post but show from 750 or so down so we see more detail. Thx again ! That's what I meant. The front and back walls are 11' so the distance between your side walls is 11'. Ie. The side wall is creating a null
Post by gouge on Sept 26, 2015 8:09:09 GMT -6
Good stuff mulmany. I've never understood how you find troublesome reflection points based on an IR. Below is a sample of one. From the example, how would you discover where in the room the reflection point(s) are that are letting this "Discrete Reflection" be so prominent so that you could fix it? Thanks if you can provide some insight! Simple answer is a tape measure and calculation of the reflection path. This is done one speaker at a time. If you look at the delay time you can then find the distance traveled, sound travels @ 1130ft/s at 74 degrees. I usually take the direct path measurement and subtract it from the reflection path measurement then measure for objects that reside at that distance from the mic. The example is pretty nice and clear, in smaller rooms it gets harder as the initial delay gap is smaller. But this delay gap is very important to be larger then the space you record in, or you will never hear the acoustic coloration of the recording space. Hope that helps. This is what I do. I use a tape and calculate the delay. The other alternative is to reduce the volume 20db if you can't achieve an isd gap of 20ms.
