Post by scumbum on Jun 11, 2015 14:28:42 GMT -6
Was finishing up one of my songs and theres way too much sibilance on the vocal . I volume automated the "S"' and de-essed......but it was bad mic placement . Bummer ......... I always have problems come mix time with sibilance and usually I can fix it but this vocal track ends in defeat .
So I'm gonna re-do the vocal . I was only 6 inches from the condenser and it was pointing straight at my mouth .
Whats the best mic position to avoid sibilance at the source with a condenser ?
One foot from the mic and have it off axis ? Pointing slightly to the left or right , not directly at the mouth ?
Is it even possible to get a vocal track with a condenser that doesn't need some type of sibilance correction come mix time ?
Thanks ,
Post by jeromemason on Jun 11, 2015 14:39:05 GMT -6
I always put it slightly above the singers mouth maybe 4", and then angle the mic down ever so slightly and that usually fixes it.
Post by tonycamphd on Jun 11, 2015 14:52:11 GMT -6
Was finishing up one of my songs and theres way too much sibilance on the vocal . I volume automated the "S"' and de-essed......but it was bad mic placement . Bummer ......... I always have problems come mix time with sibilance and usually I can fix it but this vocal track ends in defeat . If you wanna check out what I'm talking about you can hear the track here , www.dropbox.com/s/9tryhqmsb0bd2u5/As%20I%20Fall%20-%2024bit48K.wav?dl=0So I'm gonna re-do the vocal . I was only 6 inches from the condenser and it was pointing straight at my mouth . Whats the best mic position to avoid sibilance at the source with a condenser ? One foot from the mic and have it off axis ? Pointing slightly to the left or right , not directly at the mouth ? Is it even possible to get a vocal track with a condenser that doesn't need some type of sibilance correction come mix time ? Thanks , holy moly SCUM! dude, where you been? we miss you round here 8) pull every plug off the vocal, and any eq, see if you still have the issue? then maybe try a linear phase eq/or multiband comp to try to rid it, also D ess into any effects. If you have to re track vox, watch out for room reinforcement of the sib freqs, and Jerome's advice is solid.
Post by scumbum on Jun 11, 2015 15:35:11 GMT -6
Was finishing up one of my songs and theres way too much sibilance on the vocal . I volume automated the "S"' and de-essed......but it was bad mic placement . Bummer ......... I always have problems come mix time with sibilance and usually I can fix it but this vocal track ends in defeat . If you wanna check out what I'm talking about you can hear the track here , www.dropbox.com/s/9tryhqmsb0bd2u5/As%20I%20Fall%20-%2024bit48K.wav?dl=0So I'm gonna re-do the vocal . I was only 6 inches from the condenser and it was pointing straight at my mouth . Whats the best mic position to avoid sibilance at the source with a condenser ? One foot from the mic and have it off axis ? Pointing slightly to the left or right , not directly at the mouth ? Is it even possible to get a vocal track with a condenser that doesn't need some type of sibilance correction come mix time ? Thanks , holy moly SCUM! dude, where you been? we miss you round here 8) pull every plug off the vocal, and any eq, see if you still have the issue? then maybe try a linear phase eq/or multiband comp to try to rid it, also D ess into any effects. If you have to re track vox, watch out for room reinforcement of the sib freqs, and Jerome's advice is solid. Hey thanks ! I've been off forums / internet and locked in my recording dungeon trying to actually finish some music for once . The internet can be a time consuming black hole ...forums....looking at pictures of Koala Bears .....before you know it hours have gone by.... Even the raw vocal track has the issue . I'm always too close to the mic , blasting air into it . I've spent hours always trying to fix sibilance , its time I learn how to avoid it at the source .
Post by scumbum on Jun 11, 2015 15:37:04 GMT -6
I always put it slightly above the singers mouth maybe 4", and then angle the mic down ever so slightly and that usually fixes it. How far away should I be from the mic , 12 inches ? Then have it 4 inches up , pointing down towards the mouth ?
Post by ericn on Jun 11, 2015 16:20:14 GMT -6
Go off axis a bit , there is no magic distance it's singer and mic dependent, this is why I find myself suggesting large dynamics over condensers for DIY!
Post by wiz on Jun 11, 2015 16:27:54 GMT -6
There are quite a few reasons why you might put a mic, in one position on one singer, and completely different on another... (like away in the cupboard LOL )
here is one of the zillion to try for this issue.
sing across the front of the mic...
Also, try this...
hold the mic in your hand... stand or sit comfortably, and just sing, a phrase that exhibits the issue.. e.g. 8) "Steve Slate Sells Plug ins, Ba Ba Baby... Today tell everyone something soon"
and just move the mic till its not impacted by the S T P and B and then place the mic on a stand in that position.
Having "ESS" sounds so bad you can't fix, sounds like a bit much compression somewhere in the process too.. watch out for that..
Post by jeromemason on Jun 11, 2015 17:51:26 GMT -6
I always put it slightly above the singers mouth maybe 4", and then angle the mic down ever so slightly and that usually fixes it. How far away should I be from the mic , 12 inches ? Then have it 4 inches up , pointing down towards the mouth ? Well, I'm not sure, I'm not recording you I'll usually set the mic up that way, have a listen and tell the singer to move forward or back until it sounds right. I think the best possible thing you could do is record yourself at about 5 different positions and whichever sounds the absolute best, mark it with tape and roll on.
Post by winetree on Jun 11, 2015 17:55:59 GMT -6
Other than condenser, what type of mic are you using? Does it have a chineese capsule with a high rise at high feequencies? For this type of "dynamic" vocal, a dynamics mic would probably work better.
Post by jazznoise on Jun 11, 2015 18:16:34 GMT -6
In general the more radical the sibilance issue the further off axis you can have to come. Top down, as has been suggested, is a great start for most singers, provided the singer has a pop shield to sing *at*. Many mic techniques rely on the singer not trying to snuggle up to the mic like a concert.
Ribbons and dynamics can help by rolling of some top - you can put it back in on a needs basis. A dynamic EQ plugin like Vladg's Nova67 will help if it's really bad - but I think you know yourself to leave off any processing until you have the issue remedied as best as possible.
Post by Johnkenn on Jun 11, 2015 18:19:54 GMT -6
scumbum - where you been man? Missed seeing Pee Wee around here.
Post by Johnkenn on Jun 11, 2015 18:21:01 GMT -6
Doh...another instance of "I should've read the thread before I posted..."
Post by Johnkenn on Jun 11, 2015 18:27:11 GMT -6
My experience has been that a lot of that sibilance is just because of the mic you're using. Seems to be one of the fantastic qualities of great mics. Speaking of which, that MK-U47 I have definitely has a great top end - but it doesn't really have sibilance. I tracked a vocal the other day and dropped it in the mix - and it sounded like it already had a de-esser on it. Almost to the point to where I wanted more top end. That's certainly a different experience for me - adding top end to a vocal. I'm not sure I've ever done that other than ribbon mics.
Also - the de-esser is your friend. The best one I've worked with is the Fabfilter Pro-DS. Pretty amazing and simple.
Post by wiz on Jun 11, 2015 18:55:40 GMT -6
ditto on fab filter pro... out of all the de essers I have used... its really great
Post by porkyman on Jun 11, 2015 19:04:25 GMT -6
have you tried the pencil trick. if not, try taping a pencil to the middle of the mic. it deflects the pops and ess's past the edges of the diaphram.... i also have an mk47 (blueline) and it just simply doesnt have sibilance. its an amazing mic.
Post by jeromemason on Jun 11, 2015 19:54:02 GMT -6
Condensor mic's distort usually <8K, a lot of what folks think is bothersome is really distortion caused by the capsules resonance. Like a lot of folks are saying, ribbons and dynamics don't have so much of this problem, ribbons more so. The issue is that condenser's give you a very open and detailed sound pretty easily, but this is one trade off. Now, capsules can be designed to minimize that resonant distortion which then makes the esses sound natural. A desser really can take the life out of a vocal IMO. If you can get a great capsule that doesn't distort that resonance quite so bad your sound will be much larger and open.
If you think about it, if someone is speaking next to your ear normally you're not bothered by the sibilance of their voice, in fact, if they were very close to your ear the lower and mid frequencies would probably bother you more. When you speak across a condenser mic or off axis you're simply putting a band aid over the fact it's distorting those frequencies. Again, if someone were standing next to you and speaking near your ear, which would you hear more definition and power in? On axis or off? The first step in all of this is to have the capsule in your microphone tuned to remove those esses and compliment your voice. After that, then finding the sweet spot of your vocal is what I'd do next. Now, that's the ideal way to go about it, if you can't afford to have your capsule tuned then skip to step two and then save your money and have it done. It will literally sound as if you're singing right next to someone's ear and the amount of compression and eq you use will dramatically decrease. This is the fix, the other ways are just work arounds.
Post by scumbum on Jun 12, 2015 0:14:19 GMT -6
scumbum - where you been man? Missed seeing Pee Wee around here. Hey Thanks ! Hows the forum been ? Has it been growing ? This is such a nice forum . Its so cool you got your own place to hang out . This place is like the local small guitar shop where experienced musicians hang out and you can get reliable info , whereas the other audio forums are like a giant Guitar Center filled with noise and annoying salesmen giving unreliable info and trying to sell you crap .
Post by scumbum on Jun 12, 2015 0:22:12 GMT -6
I tried what jeromemason suggested and put the mic about 4 inches up and pointed down towards my nose . It definitely helped a lot . But I think the main problem is the mic . Its a "Made in Latvian" Blue Bottle . Its kinda dark but the damn sibilance , it has an annoying sibilance issue . It was still kinda there even with the different mic positions .
I then tried my other condenser , a Shure KSM32 into a VP312 . Much better . The sibilance is a different frequency and lower pitched and doesn't sound annoying .
So what do you guys think about the KSM32 on vocals ? So far I think it sounds good , not spectacular , but solid and the sibilance doesn't seem to be an issue at all .
Post by wiz on Jun 12, 2015 1:04:06 GMT -6
scumbum - where you been man? Missed seeing Pee Wee around here. Hey Thanks ! Hows the forum been ? Has it been growing ? This is such a nice forum . Its so cool you got your own place to hang out . This place is like the local small guitar shop where experienced musicians hang out and you can get reliable info , whereas the other audio forums are like a giant Guitar Center filled with noise and annoying salesmen giving unreliable info and trying to sell you crap . Great analogy. i love this place.... I walk in down the stairs and everyone turns around and says "Wiz!!!!!!" Then Woody pours me a beer.... wait a sec.... That's cheers. 8) cheers Norm
Post by Ward on Jun 12, 2015 11:27:44 GMT -6
Hung overhead with the capsule angled away will reduce sibilance. Be about 6-12" from the microphone at least.
Or, opposite pointing up, but angle, angle the capsule away (25º to 45º).
the 'under' position works best when also trying to contain (or eliminate) 'nasaliness' from a singer.
Post by jimwilliams on Jun 12, 2015 13:05:03 GMT -6
I mic on axis here. I haven't had a sibilance problem in many years. I use condenser mics too. I found the problems usually came from the mic preamp's distorting the upper registers. Use clearer stuff and it's still there, just in place and sounds natural.
Listen to someone speak and carefully listen to the sibilance, there's plenty there naturally. Somehow, it doesn't bother us until our recording gear makes it a problem.
Post by scumbum on Jun 29, 2015 18:59:49 GMT -6
So I recorded a new song and used my Shure KSM32 , positioned the mic like what was suggested about 4-5 inches up , pointing down towards my nose . It definitely was less sibilant , but I STILL had to battle the sibilance at mix down . I had to use 2 Dessers , one at around 6K , the other around 5K and also automate the volume of the track around -2-3dbs for each sibilant area . Maybe my voice is naturally much more sibilant than normal Maybe I need to use a dynamic mic I don't know . You can hear the new track here , Did I tame the sibilance enough ? EDIT:removed link
Post by odyssey76 on Jun 29, 2015 19:32:21 GMT -6
Can't get in on my iPhone? Error 403.....anyone?
Post by jazznoise on Jun 29, 2015 19:37:10 GMT -6
Same, that's not a valid URL for sharing.
It seems, on an aside, that Dropbox has has removed the play in browser option. Lame.
Post by wiz on Jun 29, 2015 19:37:32 GMT -6
403 here , on mac
