Post by jfoc on May 26, 2015 12:52:23 GMT -6
Post by jeromemason on May 27, 2015 1:13:28 GMT -6
Roxul is safer than fiberglass.... at least that's what I was told. Whether it is rigid board or the semi rigid it's still going to dust... 703, all of them dust, I have no idea why it wouldn't be safe in something that is recommended for fiberglass.
Post by guitfiddler on May 27, 2015 3:43:18 GMT -6
Roxul is safer than fiberglass.... at least that's what I was told. Whether it is rigid board or the semi rigid it's still going to dust... 703, all of them dust, I have no idea why it wouldn't be safe in something that is recommended for fiberglass. Agreed. Thanks
Post by guitfiddler on Jun 9, 2015 20:02:58 GMT -6
I'm a contractor for a living, i've done 100's of insulating jobs, forget the electric knife, this is the ONLY way to cut any sizable job www.soundaway.com/insulknife_p/21002.htm , it works so well it's ridiculous, trust me on this, any other cutting device is a waste of time and money. This will cut through any insulation from fiberglass, ultratouch(the hardest to deal with) and rockwool, panels or batts. It is USELESS without the sharpener, i will swipe sharpen the blade after every couple cuts, it takes seconds and keeps you flying. When I made my 22 panels, I used Tontine Acoustisorb 3. I cut it with an Angle grinder.... Worst weekend in memory... 8) Man did that suck. Worked out great and the whole 22 panels cost me about 1/15th of what the commercial solution would have been Hey Wiz, What Adam monitors are those? I have a similar pair, But they don't have the Blue led's. Are those A7's? Thanks
Post by Johnkenn on Jun 9, 2015 20:30:37 GMT -6
I have asbestos traps. Is that safe?
Post by wiz on Jun 9, 2015 20:45:40 GMT -6
When I made my 22 panels, I used Tontine Acoustisorb 3. I cut it with an Angle grinder.... Worst weekend in memory... 8) Man did that suck. Worked out great and the whole 22 panels cost me about 1/15th of what the commercial solution would have been Hey Wiz, What Adam monitors are those? I have a similar pair, But they don't have the Blue led's. Are those A7's? Thanks Hi yep, A7s... Haven't heard the A7x's..... Would be interesting cheers Wiz
Post by LesC on Jun 9, 2015 20:57:26 GMT -6
I have asbestos traps. Is that safe? Well, at least they won't catch on fire.
Post by guitfiddler on Jun 9, 2015 21:49:06 GMT -6
Hey Wiz, What Adam monitors are those? I have a similar pair, But they don't have the Blue led's. Are those A7's? Thanks Hi yep, A7s... Haven't heard the A7x's..... Would be interesting cheers Wiz Thanks Wiz, I like the blue led's. I haven't heard the A7's. I have the 7x's and they almost look identical except for the one port, in which the 7X's have 2 port holes and a green led. I guess I am too picky wanting blue instead of green led's. Lol. John, did you cut your traps from a block of asbestos? I hear it brings out more rasp in the voice.
Post by matt on Jun 10, 2015 8:41:49 GMT -6
I have asbestos traps. Is that safe? I've heard that soaking them in DDT makes them easier to cut.
