Post by Johnkenn on May 17, 2015 10:05:01 GMT -6
No - he uses it. I think he mentioned it previously in this thread.
Post by Johnkenn on May 17, 2015 10:05:32 GMT -6
I used it to mix a tune today... It's certainly cool. Loading 3rd party responses into it was the most successful experience I have had with a convo reverb The M7 responses you are are referring to are they the samplicity ones? Cheers Wiz I think he said "True M7". I need to try them too.
Post by Randge on May 17, 2015 10:26:03 GMT -6
Hey Randge, I think you don't use UA so haven't tried its OWS; right ? I have a great many of the UA plugs including the Ocean Way plug.
Post by kcatthedog on May 17, 2015 10:58:42 GMT -6
Ah well do you draw a parallel between being able to place the mikes in OWS and the placement fx you describe with new waves verb: or apples and oranges ?
Thx!
Post by wiz on May 17, 2015 23:57:41 GMT -6
where is it available for 150, audio deluxe has it for 175?
Post by jeromemason on May 18, 2015 1:05:41 GMT -6
where is it available for 150, audio deluxe has it for 175? cheers Wiz Gotta put it in yo cart homie That whole MAPP thing is kinda tricky.
Post by formatcyes on May 18, 2015 16:34:05 GMT -6
Purchased. Thanks for the heads up jeromemason it's a fantastic reverb.
Post by wiz on May 18, 2015 19:19:38 GMT -6
I downloaded the TRUE M7 responses...
something funky going on.. might be me... can someone check.
Listen to the tails of the TRUE M7 stuff, there is a noise... could it be something like truncation? Its not there in the HOFA impulses...
Just play a sound, then stop playback, and set your DAW so you can hear the Reverb tail when stopping playback, and you will hear it....
I dont imagine the Bricasti does that, but I haven't used one... is it SRC artefacts, truncation, or user error on my part?
Post by wiz on May 18, 2015 19:21:57 GMT -6
I just imported a Simplicity Bricasti IR , and it doesn't do it...(48Kz 24 bit IR, my session I am running is 96Kz)
Post by kcatthedog on May 19, 2015 5:46:50 GMT -6
an incorrect post !
Post by jeromemason on May 19, 2015 13:38:31 GMT -6
Mmmmm looks like you got a little mixed up, that says Waves H-Reverb, not Hofa IQ-Verb
Post by kcatthedog on May 19, 2015 15:44:18 GMT -6
oops install glasses before posting:(
Post by wiz on May 19, 2015 17:06:08 GMT -6
Mmmmm looks like you got a little mixed up, that says Waves H-Reverb, not Hofa IQ-Verb Hey jeromemasondo your TRUE M7 impulse's do what I wrote about abvove? or is it me doing something wrong? cheers Wiz
Post by jeromemason on May 19, 2015 20:02:19 GMT -6
I've never heard them do that... I'm not really sure why they'd be doing that though....? Mine loaded just fine, tails are normal. Maybe google it? See if anyone else has had the same issue?
Post by wiz on May 19, 2015 21:12:54 GMT -6
I've never heard them do that... I'm not really sure why they'd be doing that though....? Mine loaded just fine, tails are normal. Maybe google it? See if anyone else has had the same issue? Weird stuff... I just checked them again.. Not doing it now. It was. But not now. I was able to duplicate it yesterday, load M7, noise, Load HOFA, no noise, reload M7 noise, on every IR I tried... I could even see it when I looked at Blue Cat Analyser as Nigel Tufnel said "one of those things better left, unsolved" 8) Just stick it in the back of your mind, in case it pops up... freaky, clean as a whistle today... certainly could be something flaky my end, and no one else will ever see it... cheers Wiz PS thanks for checking.
Post by lolo on May 19, 2015 21:16:58 GMT -6
Jerome, with the True M7 impulses. Can you load both the L and R? I can only road L or R. might be doing something wrong
Post by wiz on May 19, 2015 21:50:02 GMT -6
Jerome, with the True M7 impulses. Can you load both the L and R? I can only road L or R. might be doing something wrong drag em both in at the same time and it will ask you how you want to handle them. I did this.. grab the whole TRUE M7 Directory and dragged it into the HOFA plug and told it to create quad files...done.. actually this is a huge benefit to this plug... cheers Wiz
Post by lolo on May 19, 2015 22:53:12 GMT -6
Thanks Wiz, Will give it a go
Post by jeromemason on May 20, 2015 2:46:35 GMT -6
All you have to do in Hofa is click load IR, then locate the "L" file, double click it and it will ask if you want to also load the "R" and that's how I do it.
Post by levon on May 20, 2015 4:08:57 GMT -6
Where do you find the True M7 impulses? All links I found are dead.
Post by jeromemason on May 20, 2015 18:04:25 GMT -6
signaltonoize.com/?page_id=4188Also, there is a donate option, but when Bricasti allowed them to sample their box it was with the understanding that no one could make a profit on it. I chose not to donate because of that, that was the first time I'd ever felt dishonest about donating rather than not, choice is yours though. If you don't want to simply put $0 in during the whole checkout phase.
Post by wiz on May 20, 2015 18:13:33 GMT -6
signaltonoize.com/?page_id=4188Also, there is a donate option, but when Bricasti allowed them to sample their box it was with the understanding that no one could make a profit on it. I chose not to donate because of that, that was the first time I'd ever felt dishonest about donating rather than not, choice is yours though. If you don't want to simply put $0 in during the whole checkout phase. i felt exactly the same and did the same thing... cheers Wiz
Post by wiz on May 20, 2015 19:31:33 GMT -6
Hey jeromemasonyou mentioned you and Randge were able to get this to do the UAD plate 140thing... any chance you can post the preset, or screen shot or something.. I am running out of demo time, and have been sick for the last week or so.. i would love to hear that, prior to my demo running out cheers Wiz
Post by jeromemason on May 20, 2015 20:09:41 GMT -6
Post by wiz on May 20, 2015 21:39:29 GMT -6
Thanks so much jeromemason thats really awesome of you! I know that would have taken some time, and I really appreciate it... I owe you a libation or three when we catch up 8) cheers Wiz
