crash
Post by crash on May 29, 2015 21:19:32 GMT -6
Funny, talk about bass, I just got what was a perfect mix, but the bass was too loud, so I then ran a copy with only the bass turned down, then a copy with the bass turned down a little less, and the one with too much bass still vibes better, ugh.. I think beating the bass into submission has been the hardest thing to master for me... and I started out recording on thin strips of rusty metal.
Post by Martin John Butler on May 29, 2015 22:09:53 GMT -6
You guys are cracking me up. Mastering is one of my issues. So far, I plan to use my tracks for publishing demos, but.. it might become a record at some point.So, the conflict is if I'm making a demo, I pump up the volume a bit and do my own faux mastering, so t comes close to levels industry people are used to. I should probably run mixes without compression right after I run the hot demo mix, just in case I get them properly mastered, but hearing it loud and compressed is addictive, even though intellectually I know it's not the way to get the best results in the long run.
jdc, I never thought of turning everything else up, love that. Unfortunately that's not so easy when lots of tracks are automated.
OK, here's the "too much bass" mix. The tracking was done quite a while back, and I can get a much cleaner production now, but for my purposes at this time, I just want to get the best version of what I have, and run with it, for now anyway.
Almost forgot to say it's our Real Gear pal Henge on the kick ass fat bass!
https%3A//soundcloud.com/martin-john-butler/the-kindness-of-strangers-2-anton-ocean-way-off
Post by Deleted on May 29, 2015 22:41:05 GMT -6
When i co-produced my first demo in a studio together with the singer of the band and the talented engineer who was also a bassman, despite having attended 2 album productions at mixing time with the music of my first band in the same studio with professional producers before, i was so afraid to bring the bass too much upfront, that it got nearly lost...LOL.
Post by Deleted on May 29, 2015 22:53:49 GMT -6
Hahaha, i just listened to one of my triphop electro mixes in the DAW seconds before, when i started the soundcloud link. LOUD. I mean, your mix. :-) I see the addictive use of faux mastering, lol. Btw., i mix my stuff thru compression on mixbus as well, pseudo-mastering-wise...and came back to less compression in the long term, because i just can't get it right if i mix thru too much of it. (surprise, surprise...) I actually do not have the impression the bass is too loud in your mix. A guitar player's thing? And yes - it has the vibe. Nicely played by henge. Really good.
Post by Martin John Butler on May 29, 2015 23:09:50 GMT -6
Thanks for the feedback smallbutfine, it's honestly appreciated.
I know I'm mixing loud, but one problem is I go back and forth to my references, and they're loud, (obviously from mastering), and I try to get my level up there. For this mix, my references were Sailing to Philadelphia, by Mark Knopfler, and Two, by Ryan Adams. Both have strong bass.
Post by Deleted on May 30, 2015 0:08:00 GMT -6
OK, i understand. I am actually not much into mixing to a reference mix. It never worked out *for me* really, particularly not for my own music. Most of the time i am ok with hearing a kind of mix when i listened to the raw tracks and figure out what kind of song i want it to be, i mean, what kind of balance it needs to sound good. Which sometimes is not what i had in mind when recording. Certainly it's another thing if you are after a very defined genre of music with strong competitors products. I totally understand what you are after if you put up these reference mixes. And probably these do work out so well also, because they have a strong bass. It's hard to mix in direct comparison to a finished and mastered track of a major production that is squeezed *for me*. Most of the time i try to get the mix right with a lower compression level to hear the nuances of the mix volumes balance, which is obviously easier with little compression due to the nature of compression itself, and push it up afterwards if this is really required. Well, it's not, most of the time, but again, i don't have to compete with major label productions in a genre like americana anyway... I mean, if you have quite a pound of compression in a bus while mixing, it's harder to hear the balance of what is fed into it. You move the fader quite a bit and the mix gets more complex due to the dynamics. Sometimes, if you change compression or even take it away, it could be that the mix does not work out at all. If done the other way round, mixing into a non-compressed bus, getting a fairly well balanced mix and then push it up with some tasty musical compression, i find it much easier to maintain a mix. Don't know if i could make clear what i mean. Since you are not completely happy with your mixes right now (aka thread title), with alot of splendid hardware, which you have, good monitoring, good sources, perhaps you are at the point where you might tweak mixing workflow to figure out what works for you to get really there where you want to be with your mixes. Please(!) take this as a discussion that is meant totally constructive from my side. IMO your mixes do not suck, i get the picture that they are just not, what you want them to sound like and i try to figure out, what you could try to achieve what you want. So i do some loud thinking...
Post by lpedrum on May 30, 2015 7:52:54 GMT -6
You guys are cracking me up. Mastering is one of my issues. So far, I plan to use my tracks for publishing demos, but.. it might become a record at some point.So, the conflict is if I'm making a demo, I pump up the volume a bit and do my own faux mastering, so t comes close to levels industry people are used to. I should probably run mixes without compression right after I run the hot demo mix, just in case I get them properly mastered, but hearing it loud and compressed is addictive, even though intellectually I know it's not the way to get the best results in the long run. jdc, I never thought of turning everything else up, love that. Unfortunately that's not so easy when lots of tracks are automated. OK, here's the "too much bass" mix. The tracking was done quite a while back, and I can get a much cleaner production now, but for my purposes at this time, I just want to get the best version of what I have, and run with it, for now anyway. Almost forgot to say it's our Real Gear pal Henge on the kick ass fat bass! https%3A//soundcloud.com/martin-john-butler/the-kindness-of-strangers-2-anton-ocean-way-offI applaud you for posting your mixes Martin--not an easy thing to do to put yourself out there for criticism! You have an arresting voice that records well. Being a drummer though I'm curious how these drums were recorded. The main problem with this mix as I hear it (I'm a drummer!) is that the canned/hyped nature of the drumming and drum sounds collides against the wistful vocal vibe you're creating. You seem to be going for more of a pop/Nashville sound which honestly is not my thing. But I think you could change up the drums on this to sound more natural and real and you'll have a whole different mix. It's mostly the drums that create and define the environment of a song, and if that's not right everything else is moot. I hope you don't mind my two cents!
Post by Martin John Butler on May 30, 2015 8:17:07 GMT -6
You couldn't be more right lpedrum. I use Superior Drummer, and this is the NY vol I kit. At an earlier stage, cowboycoalminer graciously changed the drums for me, and it was much better, but there were some parts like cymbal crashes that weren't right, and I couldn't ask him to spend any more of his valuable time reprograming it, so I went back to my original drum sound.
For instance, on the second verse, the drums should ease off a bit, not keep hitting hard. I just don't have the patience to program drums with that much finesse, so I have to get better and faster at it, and refuse to accept what my ears say isn't right, and the drums really aren't right here, but will have to do for now. Some of the Slate drums sound pretty good, but i don't have them. I can also switch drums to any of Apples kits, but they weren't a good fit either.
I've been too lazy about learning SD, I'm sure they have ways of humanizing their sounds, but if the snare sample is hit too hard, I've found it difficult to get it to soften up a little..
Post by henge on May 30, 2015 11:26:38 GMT -6
First of all your mixes don`t suck, your just not happy with them!!lol After hearing this mix the only thing that stands out is the snare sound as has been suggested. A rounder less aggressive snare might suit the mood better imo. The most important thing is that the excellent vocal and emotion are supported and this mix does that. Guits and steel sound real nice Love the tune man!
Post by Martin John Butler on May 30, 2015 12:47:43 GMT -6
and I love the bass too bro !!
Post by lpedrum on May 30, 2015 13:30:59 GMT -6
You couldn't be more right lpedrum. I use Superior Drummer, and this is the NY vol I kit. At an earlier stage, cowboycoalminer graciously changed the drums for me, and it was much better, but there were some parts like cymbal crashes that weren't right, and I couldn't ask him to spend any more of his valuable time reprograming it, so I went back to my original drum sound. For instance, on the second verse, the drums should ease off a bit, not keep hitting hard. I just don't have the patience to program drums with that much finesse, so I have to get better and faster at it, and refuse to accept what my ears say isn't right, and the drums really aren't right here, but will have to do for now. Some of the Slate drums sound pretty good, but i don't have them. I can also switch drums to any of Apples kits, but they weren't a good fit either. I've been too lazy about learning SD, I'm sure they have ways of humanizing their sounds, but if the snare sample is hit too hard, I've found it difficult to get it to soften up a little.. I'm not a purist by any means, but I have found that "in general" it's much harder to mix sampled sounds than recorded instruments if the goal is to sound like a "real band." It's deceiving because standing on their own the samples are very impressive. But when you go to mix it can be fiddle, fiddle, fiddle and still not get things to sit right. The biggest eye opener to me in this regard was B3 software vs the real deal. I had a B3 part for a bridge of a song and no matter how I tweaked the Hammond plugin I just didn't dig it. So I took the track to a friend that plays organ, had him play the same exact part and voila. It wasn't about my mix ability AT ALL. Not too long after that I bought a Hammond M101 on Craigslist for $75 and never looked back! I'm not saying that everyone can always afford a real drummer and a full band, or that it's needed in every instance. But I don't think you can really measure your mixing success if samples are used to recreate a band. I'm sure it's been done, but it's a LOT harder road.
Post by Martin John Butler on May 30, 2015 13:35:02 GMT -6
Appreciate the ideas lpedrum, and I suspect that you're right, it would be much easier to mix this if a drummer was following the dynamics naturally. Hopefully the next set of recordings will be different in that sense.
Maybe I should change the title of the thread to "My Drummer Sucks", which might actually be closer to the truth.
Post by henge on May 30, 2015 20:26:32 GMT -6
and I love the bass too bro !! Thanks bro. You going to post Kindness...
Post by henge on May 31, 2015 9:40:05 GMT -6
You couldn't be more right lpedrum. I use Superior Drummer, and this is the NY vol I kit. At an earlier stage, cowboycoalminer graciously changed the drums for me, and it was much better, but there were some parts like cymbal crashes that weren't right, and I couldn't ask him to spend any more of his valuable time reprograming it, so I went back to my original drum sound. For instance, on the second verse, the drums should ease off a bit, not keep hitting hard. I just don't have the patience to program drums with that much finesse, so I have to get better and faster at it, and refuse to accept what my ears say isn't right, and the drums really aren't right here, but will have to do for now. Some of the Slate drums sound pretty good, but i don't have them. I can also switch drums to any of Apples kits, but they weren't a good fit either. I've been too lazy about learning SD, I'm sure they have ways of humanizing their sounds, but if the snare sample is hit too hard, I've found it difficult to get it to soften up a little.. I'm not a purist by any means, but I have found that "in general" it's much harder to mix sampled sounds than recorded instruments if the goal is to sound like a "real band." It's deceiving because standing on their own the samples are very impressive. But when you go to mix it can be fiddle, fiddle, fiddle and still not get things to sit right. The biggest eye opener to me in this regard was B3 software vs the real deal. I had a B3 part for a bridge of a song and no matter how I tweaked the Hammond plugin I just didn't dig it. So I took the track to a friend that plays organ, had him play the same exact part and voila. It wasn't about my mix ability AT ALL. Not too long after that I bought a Hammond M101 on Craigslist for $75 and never looked back! I'm not saying that everyone can always afford a real drummer and a full band, or that it's needed in every instance. But I don't think you can really measure your mixing success if samples are used to recreate a band. I'm sure it's been done, but it's a LOT harder road. I find the same thing lpedrum. I`m producing 2 bands right now, one with live drums and the other with samples and the live drums a way easier and more pleasurable to work with.
Post by Martin John Butler on May 31, 2015 10:42:29 GMT -6
I looked around, and found some older drum midi for Kindness. I popped it in my DAW, but the whole track sounded strange, so it's possible I opened the wrong version. Anyway, this drum midi has a more relaxed snare, so if I can locate my last mix, (I know that sounds odd, but I have a dozen versions and they're getting all mixed up), I'll see if the new midi fixed the "over-snare" issue. The current version for some reason has only the bounced drums, and not the midi, otherwise I'd have just changed the snare in that mix. Somewhere down the road, I must have deleted the midi. If it doesn't work out, well, I'm done with it for now..
Henge, next up is What the Heart Only Knows..
