Post by Ward on Aug 13, 2013 23:23:26 GMT -6
I've done some sessions/albums at 88.2/24bit and even some demos at 44.1/24 I don't think I'll use either of those again. The final result from a session that starts at 44.1 and ends up at 44.1 sounds limited. the 88.2 just takes up way to much space and DAW horsepower.
So because I tend to run a LOT of tracks, and don't have the most powerful Macpro/PTHD system in the world... I need that horsepower for processing 48+trakcs, verbs, plugz, virtual instruments, midi and busses. So it's 48/24 for me. I find 48 does sound better than 24, especially in the 12-18khz region.
Post by cowboycoalminer on Aug 14, 2013 7:56:15 GMT -6
That's we're I hear the difference in higher sample rates as well, cymbals ect..
Post by svart on Aug 14, 2013 9:32:54 GMT -6
IF you must use higher bitrates that will be dithered, I suggest using multiples of the final bitrate. Something like 88.2 is much easier to dither down than something like 96 or even 48. It's entirely possible that you lose more audio information going from something like 96K than 88.2K even though you *technically* had more information available with 96Khz sampling rate. It's all in the math. Doing fractional multiplication and division in the digital domain will always lead to bit truncation as the resulting numbers are too large. Making the math more simple for the dithering process will result in less loss.
Besides, dithering is adding noise. It's pseudo-random noise applied to a signal that is being bit decimated in order to mask distortion from the decimation process.
So why on earth would you record at a higher rate, just to add noise to mask inherent distortion later? That's why I stick with the same bitrate as my final product and avoid dither, the possible algorithm issues, adding noise and distortion that this process all entails.
Post by Johnkenn on Aug 14, 2013 9:38:43 GMT -6
So, svart, are you saying you record at 24/44.1? I don't know if I believe that some "math" is more complicated than other math for a computer...The computer doesn't care. Who knows, though...maybe some math is harder because of fractional division. Also, are you saying not to dither from 88.2?
Post by cowboycoalminer on Aug 14, 2013 9:39:30 GMT -6
Thinking along those lines, wouldn't the ideal situation be to record and mix at a higher sample rate the pitch the final mix to another computer/converter setup recording that mix at 44.1/16?
Just thinking out loud here.
Post by jazznoise on Aug 14, 2013 10:00:40 GMT -6
Here's one for those worried about SRC: src.infinitewave.ca/Some of them are scary. Nuendo doesn't reach -40dB on its filter until 24Khz. I'm guessing the alias distortion would only become obvious around 24Khz, where it would reflect below 20Khz. Some of them, such as Waveburner, seem to learn their lessons pretty early on - I would assume after complaints. After using up all that extra space, it's good to know how much quality you've preserved in the end! I work at 44.1Khz or 48Khz at 24 bit. I really just don't have the resources to work any other way.
Post by svart on Aug 14, 2013 10:05:44 GMT -6
I record at 24/44.1. But that's just me. However, I also mix down through a console into a completely different sound card. In this case, I could track at something higher, say 88.2K, and just set the mix-down sound card to record at 44.1k. That would be cool if you can do it.
I suppose I should be more clear, if you are mixing ITB and everything stays ITB, then I would prefer to keep the tracks at the same bitrate as the final product. However, if you still want to record at a higher bitrate, I'd use a multiple of 44.1k. 88.2K would be fine.
Also, as stated in my earlier post, I think the analog circuitry can make more difference to the sound than the sampling rate does. DACs work by "stepping" voltage/current(depending on how they are designed) into a "reconstruction filter". It's essentially a super LPF that rejects higher spurious noise and higher images. It does this by "rounding" the edges of the DAC's output signal which typically looks like a rough staircase going up and down. The "staircase's" rough edges are harmonics. The filter rejects these higher harmonics BUT it's a very thin line between the cutoff point of the filter, the speed of the filter itself and the frequency range. If this isn't done very well, you'll have problems. Same goes for the A/D side, it also has an input LPF for similar reasons. Also, any outboard gear will add more noise and distortions to the system than fidelity you'll gain from higher bitrates..
A/D and D/A converters are cheap commodity parts these days. If you use the Cirrus Logic parts, the TI parts, the Analog Devices parts, or whomever, chances are, you could never tell the difference between them. The places where the designers go cheap are in the filters, the power supplies and the layouts of the boards.
That's primarily why I say "does it sound good" first, before looking at numbers on paper. An Mbox(or equally cheap equivalent) running at 24/88.2 might still only actually have 18/38K worth of usable audio, the rest being noise and distortions, while the Burl or something equally good might get 21/44.1 worth of usable audio from 24/44.1k. Catch my drift?
Of course, I could be completely off my rocker.
Post by wiz on Aug 14, 2013 16:26:36 GMT -6
Some do that cowboy, but then you have extra DA and AD stage, or clocking if you stay digital. So Tomato if you do Tomato if you dont 8)
Personally, if you hear a difference, go for it. Like everything, It may matter to one person and not to another.
Also, all devices, don' function exacxtly the same and its quite feasible that one device might perform audibly better at one sample rate compared to another (and not always that the higher rate is better).
18K is pretty high up. Put a test oscillator up in your DAW and make a 1Khz tone at a pleasant level, and then change the frequency to 18K and see how well you percieve it........ I would be interested to know, then do it with a sweep of that whole range 12 to 18Khz and then manipulate the volume by 3dB as it sweeps and see how much you percieve a 3dB change at 12 to 18 Khz vs say a 3dB change at 1 to 4 Khz....
Often people get their knickers in a knot with this stuff.... if you like it, its good, if you can afford it or have the horsepower to use it, use it.
Again, I am not ever one to say that just cause I cant hear it it doesnt exist... but just keep in mind, just cause something says its something, dont mean its anything 8)
Post by Ward on Aug 14, 2013 21:49:23 GMT -6
18,000 CYCLES???
I doubt I'll ever hear 18khz again. The results of my last hearing evaluation showed I could hear up to 16.4khz, granted not as well as I could hear from 15k down. Most of us lose 20khz at around 16 years old.
Post by Deleted on Aug 14, 2013 23:51:49 GMT -6
Well, depends. If latency is an issue, 88.2/96khz come in handy. Another reason could be: Most converters are optimized for one sample rate. Mostly: If the chip is capable of 96khz, then it sounds best at 96khz, because the higher sample rate is a marketing argument. People try out the higher sample rate and say "wow, it sounds better." (But maybe not better than a good 44.1/48khz single speed only converter?) As far as i know, that is already an issue in the converter chips. There is no reason, a higher samplerate than 48khz should sound any better. Think of nyquist theorem. Does anybody hear more than 24khz? More is not better. That is a marketing type of psychological expectation. There are people out there, saying 60khz would be the optimal audio samplerate when considering all factors, e.g. Dan Lavry. But this is no chip industry standard, and 48khz should fit all needs, and even 44.1khz is totally ok - you don't need an SRC if your end media are cd compatible. DVD-A, however, can sound awesome. Most difference comes from 24 vs. 16bit. 88.2khz, well, dunno if that's the converter thing or if it sounds really any better anyhow... Mr. Katz *sometimes* upconverts 48 or 44.1khz sources to 96khz for masterin, that's what i read, IF there is lots of dynamics work to do in a specific mastering.... Anyway....SRC's are very high quality nowadays. One can get SRCs for free that rival the highest quality Weiss algorithms. If done ONCE, it should be no problem at all...
Best regards, M.
Post by tonycamphd on Aug 15, 2013 0:22:49 GMT -6
There is no reason, a higher samplerate than 48khz should sound any better. Think of nyquist theorem. Does anybody hear more than 24khz? Isn't SRC(sample rate conversion) the rate of digitally converted samples per second? Don't higher rates only equate to higher resolution, and not have anything to do with the audible frequency of actual audio signal? The conflating of the two, never makes sense to me? I appreciate any clarification.
Post by wiz on Aug 15, 2013 2:41:11 GMT -6
The sample rate defines the upper rate of the frequency that can be captured, theorectically. Google Nyquist Theorum... 8)
There are a whole bunch of things that can now appear as rabbit holes in the discussion. It can get like sample rate in wonderland.
With sample rate, there is a point of diminishing return. Where that point is, frequency wise, is a thing of debate.
Post by svart on Aug 15, 2013 8:05:56 GMT -6
There is no reason, a higher samplerate than 48khz should sound any better. Think of nyquist theorem. Does anybody hear more than 24khz? Isn't SRC(sample rate conversion) the rate of digitally converted samples per second? Don't higher rates only equate to higher resolution, and not have anything to do with the audible frequency of actual audio signal? The conflating of the two, never makes sense to me? I appreciate any clarification. Sample rate is how many points per cycle are sampled in time (think X axis). 88.2K is twice as many points as 44.1k per second. This *in theory*, should result in twice the resolution. But again, as I mentioned before, the filters could limit the disparity between the numbers. Now, bit depth is another thing. Bit depth defines the amount of points that can be sampled on a volume/level scale (think Y axis). If you take a 60db possible volume scale and divide it by 16, that's 3.75db per bit of level resolution. if you take 60db and divide by 24, that's 2.5db per bit of resolution. The smaller the dB/bit the more precise the math that can be done on the signal, the more precise the reconstruction that can be done by the DAC and the less stringent the filters have to be.
Post by Ward on Aug 15, 2013 10:37:10 GMT -6
Human beings cannot hear about 22khz for very long after birth, although I am sure someone knows of an exceptional batboy out there. Typically, by 12 years old you're already losing the upper echelons of your hearing, albeit slowly.
As for the Nyquist Theorem. It isn't exactly half. It's roughly half less 10%. I don't have all the math in front of me at the moment, but a sample rate of 44.1khz can only produce a 20khz signal, not a 22khz signal. Likewise, a 48khz sample rate can only produce 21.6khz signal.
But what you can't "hear" you may be able to feel. That goes for harmonics and transients.
Post by tonycamphd on Aug 15, 2013 10:48:12 GMT -6
But what you can't "hear" you may be able to feel. That goes for harmonics and transients. Agreed! I get the feeling if all atmospheric sounds above my limited tangible hearing range disappeared, there would be a imminent, tangible and foreboding feeling of doom for the world as i know it! just saying lol!
Post by Deleted on Aug 16, 2013 10:27:18 GMT -6
But what you can't "hear" you may be able to feel. That goes for harmonics and transients. Wow, yes often used in arguments...unfortunately in arguments about higher samplerates. This is totally true for basses. Everything else i only believe if someone points me to a reliable scientific source. This is not meant as an offense at all, but this is really a topic where esoteric arguments are done much too often. So if this is true for frequencies above the hearing range, i want to understand it scientifically. Best regards, M.
Post by Deleted on Aug 16, 2013 10:35:10 GMT -6
And yes, the practically modified formula for technically applied shannon-nyquist theorem uses the factor 2.2 for samplerate frequency to be able to fully reconstruct the maximum signal frequency, thanks, ward, for pointing that out.
Post by tonycamphd on Aug 16, 2013 13:19:20 GMT -6
Other than what svart has stated, i'm still confused on all the talk about "highest audible frequency" Bit depth aside, and all things being equal, 88.2 has twice the definition or resolution as 44.1....right? I wonder since the resolution at...say...4 to 8k is doubled, will I have less chance of the "stab or poke" in my ear at a potentially strident frequency? This is what i feel i get with higher reso's, smoother all together. On a total off topic, I also feel i get this when i use high grade electrolytic caps in the audio(when necessary) and PS paths, your PS's are feeding the audio paths as well, so the sooner you get it all jiving, the better, if your entire chain is very hi fi, when you ADC back into the box, you'll end up with a far superior result. I often say the quality of the end result, is the accumulation of all the small things in a studio, some people say small things don't matter, i say put one fly in a room, and you may or may not hear it, put 1000 fly's in a room, and you'll hear nothing else. wow!, what a tangential rant lol! I don't even know what my point was... ok then, carry on... Btw, i'm no expert, and jmo and all that good stuff cheers!
Post by svart on Aug 16, 2013 13:31:47 GMT -6
I'm going to say it again.. Just because the sampling rate is 88.2K doesn't mean that the input and output filters *allow* 44Khz to be sampled. That was kinda my point all along. 88.2K (or whatever) is just a number on paper. The quality of the filters and the quality of the digital manipulation can mean much more than just having a high sampling rate. Those filters still might be set to 20Khz or so even though you have the ability to sample at 88.2khz.. Get my drift?
The caps in the power supply are not really the same situation. Having poor decoupling can mean that your amplifiers are pulling the rails around and not robustly slewing as they should. They are also generating noise on the rails that seeps into the other amplifiers. The result is noise added to the audio or outright distortion.
I'm not sure the sampling rate thing even matters as much as people let on. Most commercially available CDs are hard LPF during mastering and production around 16Khz anyway. MP3s are hard cut even lower during encoding, somewhere around 12Khz.
I think the next point is that most people fall prey to "hearing detail" and immediately think it's high frequencies that define the detail. It's really just fast transients, harmonics and lack of muddy low mids that psycho-acoustically fool us into thinking that we hear like dogs.
Post by cowboycoalminer on Aug 16, 2013 14:45:12 GMT -6
Human beings cannot hear about 22khz for very long after birth, although I am sure someone knows of an exceptional batboy out there. Typically, by 12 years old you're already losing the upper echelons of your hearing, albeit slowly. As for the Nyquist Theorem. It isn't exactly half. It's roughly half less 10%. I don't have all the math in front of me at the moment, but a sample rate of 44.1khz can only produce a 20khz signal, not a 22khz signal. Likewise, a 48khz sample rate can only produce 21.6khz signal. But what you can't "hear" you may be able to feel. That goes for harmonics and transients. And there it is ladies and gentlemen. Anyone who has ever sat in front of a symphony orchestra can attest to this. I;m a firm believer we perceive more than with our ears when we listen to music. As humans we are a wonder to behold. I think a lot of our music making process involves feel.
Post by LesC on Aug 16, 2013 15:41:35 GMT -6
Other than what svart has stated, i'm still confused on all the talk about "highest audible frequency" Bit depth aside, and all things being equal, 88.2 has twice the definition or resolution as 44.1....right? I wonder since the resolution at...say...4 to 8k is doubled, will I have less chance of the "stab or poke" in my ear at a potentially strident frequency? This is what i feel i get with higher reso's, smoother all together. On a total off topic, I also feel i get this when i use high grade electrolytic caps in the audio(when necessary) and PS paths, your PS's are feeding the audio paths as well, so the sooner you get it all jiving, the better, if your entire chain is very hi fi, when you ADC back into the box, you'll end up with a far superior result. I often say the quality of the end result, is the accumulation of all the small things in a studio, some people say small things don't matter, i say put one fly in a room, and you may or may not hear it, put 1000 fly's in a room, and you'll hear nothing else. Tony, I may be misunderstanding what you're saying, but definition or resolution is all about the number of bits per sample, each additional bit representing about 6 db dynamic range. The sample frequency relates only to the maximum frequency recorded, and has nothing to do with resolution. So in a perfect system, the highest frequency that can be recorded is a bit less than half the sampling frequency. On a standard tuned guitar, for example, the high E at the 24th fret is about 1280 Hz. So a sampling frequency of 3 kHz would be sufficient, except it would exclude any harmonics, which extend out to as far as you care to measure them. But the quality or resolution of the sound would be determined by the number of bits.
Post by Deleted on Aug 16, 2013 15:50:54 GMT -6
Well, yes, cowboycoalminer... For sure, if you sit in front of a symphony orchestra and listen to, say, Beethoven's 9th, and feel nothing, you are certainly either deaf or dead. BUT. I doubt what you feel are frequencies above of your hearing range. It matters if you want to capture music, that you know, what you are doing, which frequencies you are able to capture and if they affect your product anyway. As svart said...most converter's filters cut in the same places, no matter if you have a 44.1/48 or 88.2/96 kHz capable converter. And somtimes it will be LPFed anyway in the mastering process... Maybe some people have more senses than me. I feel basses below hearing range and this is very common. But not frequencies above hearing range.... Best regards, M.
Post by Ward on Aug 16, 2013 23:49:23 GMT -6
Although this is a source of contention and debate amongst some, there were white papers done on this in the late 90s (during the old debates on sample rates and frequency response) that the human body could "feel" up to 30khz and that certain phonograph needles were capable of reproducing this, which is why analog had a technical edge over digital. The human body can also feel as low as the 5-10 cycle octave, even though most ears can't perceive pitch below 25 cycles.
I'm sure with some extensive digging, one of us could find the published studies on this... if we had someone amongst us who demanded peer-reviewed scientific proof. There are those who scream "BS" without it. You all know the types.
Post by Ward on Aug 16, 2013 23:58:00 GMT -6
Tony, I may be misunderstanding what you're saying, but definition or resolution is all about the number of bits per sample, each additional bit representing about 6 db dynamic range. The sample frequency relates only to the maximum frequency recorded, and has nothing to do with resolution. So in a perfect system, the highest frequency that can be recorded is a bit less than half the sampling frequency. On a standard tuned guitar, for example, the high E at the 24th fret is about 1280 Hz. So a sampling frequency of 3 kHz would be sufficient, except it would exclude any harmonics, which extend out to as far as you care to measure them. But the quality or resolution of the sound would be determined by the number of bits. Not to be "Mister know it all" or a stickler, but I'd just like to point out a couple of calculation (math) errors here. 1. "24-bit digital audio has a theoretical maximum SNR of 144 dB, compared to 96 dB for 16-bit; however, as of 2007 digital audio converter technology is limited to a SNR of about 124 dB (21-bit)[3] because of real-world limitations in integrated circuit design. Still, this approximately matches the performance of the human auditory system". Each bit does not quadruple dynamic range as 6db means. 2. the note "b" at the 12th fret on the b strong of the guitar is 988 hz. The 24th fret "e" is 2637hz
Post by LesC on Aug 17, 2013 0:52:18 GMT -6
Thanks for the corrections.
For the high e on the 24th fret, I knew the low e was about 80, so I just doubled 4 times in my head and got 1280, which I thought would be a reasonable estimate. But I looked up the exact frequency, and it seems to be 1318.51, so I wasn't that far off. Your 2637 I think would be at the 36th fret. I've seen 30-fret guitars, does a 36-fret exist?
