Post by littlesicily on Nov 23, 2014 18:53:56 GMT -6
littlesicily Johnkennhow close were the drip and the retro in compression action and output level? cheers Wiz Compression action on my drip… there's a 6 position knob that has both the "single" and "double" settings as on the original gates, and 4 more faster settings. The Retro has a combination of single/double/triple and then diff recovery settings. So… not apples to apple suppose. Output level… not sure but this Drip is HOT. Normal use I have the input at 9 o'clk and output at 12 o'clock and it's rocking. Can be used as a mic pre with one tube tied behind it's back
Post by wiz on Nov 23, 2014 19:55:16 GMT -6
littlesicily Johnkennhow close were the drip and the retro in compression action and output level? cheers Wiz Compression action on my drip… there's a 6 position knob that has both the "single" and "double" settings as on the original gates, and 4 more faster settings. The Retro has a combination of single/double/triple and then diff recovery settings. So… not apples to apple suppose. Output level… not sure but this Drip is HOT. Normal use I have the input at 9 o'clk and output at 12 o'clock and it's rocking. Can be used as a mic pre with one tube tied behind it's back thanks I may have seen your DIY photos of the release time switch. Mine ends up set at 1ppm and 9 am (in and out) respectively and most of the time I am using SINGLE release on vocals, sometimes DOUBLE on acoustic thanks again cheers Wiz
Post by popmann on Nov 23, 2014 21:03:50 GMT -6
Someone should definitely make me an offer I can't refuse on my vintage Urei La3a.
Post by wiz on Nov 23, 2014 21:48:21 GMT -6
Someone should definitely make me an offer I can't refuse on my vintage Urei La3a. I will use it every day, love it.. hug it and kiss it... ummm I will be really nice to strangers...
Post by Johnkenn on Nov 24, 2014 8:36:58 GMT -6
Someone should definitely make me an offer I can't refuse on my vintage Urei La3a. $900
Post by jcoutu1 on Nov 24, 2014 8:47:58 GMT -6
$901.
Post by Johnkenn on Nov 24, 2014 8:53:39 GMT -6
$899
Post by Johnkenn on Nov 24, 2014 8:53:51 GMT -6
Wait...
Post by Ward on Nov 24, 2014 13:26:27 GMT -6
Someone should definitely make me an offer I can't refuse on my vintage Urei La3a. $900 $903
