Post by cowboycoalminer on May 29, 2015 15:38:14 GMT -6
Well when you mix to a console it doesn't really matter that a converter adds or takes away. We manipulate the signal post conversion anyway so color might be a good thing. However, I would think mixing ITB, one would want sterile.
But you know I think getting to know whatever converter you use is more important than anything. Jumping from one to another makes little sense to me. Same with monitors, wives etc...
Post by Martin John Butler on May 29, 2015 16:31:29 GMT -6
If I knew exactly how to get the sound the Burl gives, I'd say yes, give me the cleanest conversion, but since I don't, I'd want the Burl. If I could be satisfied I had exactly the sound I liked before conversion, then I'd want the Svartbox. Now, I've only heard the Burl A/D converter, so my knowledge is limited.
Post by wiz on May 29, 2015 18:55:46 GMT -6
Well when you mix to a console it doesn't really matter that a converter adds or takes away. We manipulate the signal post conversion anyway so color might be a good thing. However, I would think mixing ITB, one would want sterile. But you know I think getting to know whatever converter you use is more important than anything. Jumping from one to another makes little sense to me. Same with monitors, wives etc... he he ... "wives" that got a giggle out of me 8) cheers Wiz
Post by NoFilterChuck on May 30, 2015 1:20:14 GMT -6
@johnkenn, i'm disappointed that you would feel it is ok to post my thoughts i wrote to you in *private messages* publicly. you should have asked me... Here are my thoughts: Pros: Slightly better transient response than the symphony. $400 for the D/A!!!! Cons: Less 3D than the symphony Less width than the symphony. Stuff in the center gets pushed forward, stuff on the sides gets flattened. non-lead Instruments don't sound like they're in their own 3d spaces. Less bass than the symphony. that BRIGHT ASS front panel. Turn that shit down, bro!! it's blinding!! lolol No volume control, meaning you have to own a monitor controller. Who is your target audience? Dudes with MOTUs, RMEs or Presonus's, or dudes with Consoles and monitor controllers? The best analogy I can use is: Symphony is an Incandescent bulb SvartBox is a fluorescent bulb. If i owned an older RME or MOTU interface and a Presonus Central Station or Mackie Big Knob, I would purchase this thing without question. As it stands, I don't find it to be an upgrade from the symphony, but more of a side-grade. I've only done round-trip tests with sine sweeps with the A/D side of things. As with what was stated earlier, I was unable to clock the symphony's SPDIF in to the ADC on this unit, as is how it normally works. SPDIF Transmitters are the master clock source (which doesn't make sense, because the symph would always be the Master for outbound audio, and another device would be the master for inbound. shouldn't one device control the clock for all connected devices?) Here are some plots of what I found. "Noise" is the signal before it leaves the computer, for comparison. These results are from sine sweeps running continuously for about 5 minutes per unit. I'm hazarding a guess that the garbage in the svartBox's upper end is due to the clocking issue described above. svart, if you fix the bottom end (both dan duerloo and jim williams told you how to do it, you should probably listen to what they're saying, since now i'm the third person to say it doesn't have any bottom) and fix the width/stereo image things, your unit will be a KILLER converter that everyone will purchase. I highly advise you to to not go ahead and do the run of units, but instead get this thing perfect. You asked us for feedback, and multiple folks have commented on the same issues with the same results.
Post by svart on May 30, 2015 9:15:19 GMT -6
@johnkenn, i'm disappointed that you would feel it is ok to post my thoughts i wrote to you in *private messages* publicly. you should have asked me... Here are my thoughts: Pros: Slightly better transient response than the symphony. $400 for the D/A!!!! Cons: Less 3D than the symphony Less width than the symphony. Stuff in the center gets pushed forward, stuff on the sides gets flattened. non-lead Instruments don't sound like they're in their own 3d spaces. Less bass than the symphony. that BRIGHT ASS front panel. Turn that shit down, bro!! it's blinding!! lolol No volume control, meaning you have to own a monitor controller. Who is your target audience? Dudes with MOTUs, RMEs or Presonus's, or dudes with Consoles and monitor controllers? The best analogy I can use is: Symphony is an Incandescent bulb SvartBox is a fluorescent bulb. If i owned an older RME or MOTU interface and a Presonus Central Station or Mackie Big Knob, I would purchase this thing without question. As it stands, I don't find it to be an upgrade from the symphony, but more of a side-grade. I've only done round-trip tests with sine sweeps with the A/D side of things. As with what was stated earlier, I was unable to clock the symphony's SPDIF in to the ADC on this unit, as is how it normally works. SPDIF Transmitters are the master clock source (which doesn't make sense, because the symph would always be the Master for outbound audio, and another device would be the master for inbound. shouldn't one device control the clock for all connected devices?) Here are some plots of what I found. "Noise" is the signal before it leaves the computer, for comparison. These results are from sine sweeps running continuously for about 5 minutes per unit. I'm hazarding a guess that the garbage in the svartBox's upper end is due to the clocking issue described above. svart, if you fix the bottom end (both dan duerloo and jim williams told you how to do it, you should probably listen to what they're saying, since now i'm the third person to say it doesn't have any bottom) and fix the width/stereo image things, your unit will be a KILLER converter that everyone will purchase. I highly advise you to to not go ahead and do the run of units, but instead get this thing perfect. You asked us for feedback, and multiple folks have commented on the same issues with the same results. Hey thanks for your feedback! I do have to address a few things though, and folks are free to interpret them as they will. I see that Tony edited your post. Not sure why he would do that.. Anyway.. "No volume control, meaning you have to own a monitor controller. Who is your target audience? Dudes with MOTUs, RMEs or Presonus's, or dudes with Consoles and monitor controllers?"I use my software to adjust the levels digitally before the output, and my DAC goes straight to my amplifier. In this day and age of interfaces, I don't even know why folks use analog monitor controllers, they are just another level of possibly messing up the analog signal to the amplifier. I'd personally avoid them whenever possible. "I was unable to clock the symphony's SPDIF in to the ADC on this unit, as is how it normally works. SPDIF Transmitters are the master clock source (which doesn't make sense, because the symph would always be the Master for outbound audio, and another device would be the master for inbound. shouldn't one device control the clock for all connected devices?)"SPDIF transmitters are ALWAYS the master to the receiver. The Symphony would be set to be a slave to the incoming SPDIF ADC signal. The Symphony would simply pass the clocking through to the DAC when set like this, and look like the master to the next device. If it does not, then it violates the AES/SPDIF protocol standard. "if you fix the bottom end (both dan duerloo and jim williams told you how to do it, you should probably listen to what they're saying, since now i'm the third person to say it doesn't have any bottom)"Dan made some suggestions and I greatly appreciate his testing work, but I've not heard anything from Jim as he hasn't tested a unit (not sure where that came from), but anyway, I have a couple people saying that it lacks bottom compared to known hyped units.. I also have some others saying it's perfect the way it is. I also have some audiophiles listening as well (you didn't think that you guys were the ONLY ones testing units did you?) and so far just some suggestions from them. I have frequency sweeps of my own showing that it's essentially flat down to almost 10hz. I've honestly found no electrical reason why anyone should think it's excessively light on the low end. In fact, the DAC is completely DC coupled from the DAC chips right through to the TRS connectors. Another thought is that you've set your speakers, room and listening position based on the symphony's output. You've "tweaked" and "tuned" for best performance with the symphony.. Any other converter dropped in place of the symphony would essentially require redoing most of that for optimum frequency response. This is one of the caveats of doing testing without controls, like this. So, here's the quandry.. What do I do? Even your sine sweeps show almost the exact same low end rolloff point on the graph for each converter(which seems really high considering).. However, if you look very carefully, you'll see that the symphony slowly drops in level as it goes up in frequency. Judging by the graph lines, it drops by 1dB or so, which is enough to make it seem more hefty on the low end. I think if anything, I think you've proven that the symphony does indeed live up to it's reputation as low-end heavy. So based on that, do I proceed to modify my unit to please a couple people, or continue on as planned? I don't know, but I will say that it's valuable information nonetheless. I'm still considering all opinions no matter what, and your's matters just as much as anyone else's. "fix the width/stereo image things"These things are a function of the input signal, and the hardware receiver/DAC chips. My units use dedicated DAC and SPDIF ASIC chips so the signals are handled only in hardware, not software. Since each output is it's own separate circuit, there isn't anything between them that would smear or otherwise cause issues between the outputs. I feel there isn't much I can do to the circuit for this besides add some longer lines between the DAC IC's to introduce false delay for some HAAS effect. However, since I took great pains to ensure that trace lengths were equidistant for each DAC chip, for superior propagation delay matching from the receiver to the DAC chips, I'd say that it could possibly only seem like an issue since you only have the symphony to compare. Which is correct? It's anyone's guess, but I'd wager that since the Symphony wouldn't let you clock from the SPDIF input, which is a fundamental error in implementing AES/SPDIF, I have to wonder about their implementation of SPDIF in general. I'll look into all options on this and see if there is anything that can be done. But overall, thanks for your efforts. I'm still investigating every opinion that everyone has mentioned to me, and hope to have a conclusion soon.
Post by tonycamphd on May 30, 2015 9:33:41 GMT -6
Seems a bit of paranoia going around these days? I edited nothing of his content or analysis, just some simple language, and I PM'd chuck that I did so. Svart, Like I said before, i'm routing for this to work for you, taking advice from everyone who's put the evaluation in, including Jim(even blindly) is a very good idea, he has been part of the some pretty damn famous ADDA designs.
Concerning the stereo width, have you done a crosstalk test on this? I'm sure it's probably very good, but i'm curious, i'd see what it looks like @10k. It's normal to do a LOT of listening tests, and expect plenty of tweaking as parts of identical values do indeed sound different from one another as i'm sure you know.
one other thing you may consider is swapping out all of those SMD electro's(there are only 12 per board or so, no biggie at all), IME they NEVER sound good, i know they are not in the audio path, but ime it doesn't matter, if they were to be replace with the top notch through hole stuff(even surface mounted with short bent leads), and even though it would look identical on a analyzer, i'd bet my last dollar that it would change the sound for the better.... JMO and trying to help, I think you are dangerously close to having one of the best boxes out there, keep pushing it and you will own this market at your price point!
Post by svart on May 30, 2015 9:57:28 GMT -6
Seems a bit of paranoia going around these days? I edited nothing of his content or analysis, just some simple language, and I PM'd chuck that I did so. Svart, Like I said before, i'm routing for this to work for you, taking advice from everyone who's put the evaluation in, including Jim(even blindly) is a very good idea, he has been part of the some pretty damn famous ADDA designs. Concerning the stereo width, have you done a crosstalk test on this? I'm sure it's probably very good, but i'm curious, i'd see what it looks like @10k. It's normal to do a LOT of listening tests, and expect plenty of tweaking as parts of identical values do indeed sound different from one another as i'm sure you know. one other thing you may consider is swapping out all of those SMD electro's(there are only 12 per board or so, no biggie at all), IME they NEVER sound good, i know they are not in the audio path, but ime it doesn't matter, if they were to be replace with the top notch through hole stuff(even surface mounted with short bent leads), and even though it would look identical on a analyzer, i'd bet my last dollar that it would change the sound for the better.... JMO and trying to help, I think you are dangerously close to having one of the best boxes out there, keep pushing it and you will own this market at your price point! It's definitely on my list to do a final crosstalk test. I've done rudimentary ones on the prototype, but nothing on the final iteration of the design yet. Since every supply is separate on either of the DAC chips, it should be relatively low crosstalk. Also, I did just remember that the prototype DAC being sent around has two differences to the final design(I sent it out before I found these changes!), and I'll have to compare the two side by side to see if it makes any significant difference in sound. I didn't think it would, but it's very possible that it does because they improve the current bias of the DAC and also lower impedance to the opamps slightly. These SMD electrolytics are mainly local bulk caps. The low level decoupling is handled by NPO/X5R ceramics at the parts themselves. The DAC has tantalum decoupling as well, as I was intending to get away from electrolytics on it, but price/performance dictated I use electrolytics for the largest bulk caps and cascade downwards. The tantalums provide a low/medium ESR bulk source locally to the parts along with the low ESR ceramics for high frequency decoupling. I'm also using low impedance power planes rather than higher impedance traces, so some consideration is made to caps choices overall, as I intended to cover the various ESR/ESL ranges with overlapping cap types. I can assure you that these parts were chosen for their overall attributes. I actually did replace a handful of the bulk caps on a DAC per Dan's suggestions, but I found relatively little change in listening tests. I'm getting ready to do sweeps of this and see what gives. It could still simply boil down to the prototype vs. final design changes. I might also take another tweaking step and change the I/V integrator feedback cap values once again based on some other tests I've done. I thank you for your thoughts on this, and I do take all suggestions seriously.
Post by Johnkenn on May 30, 2015 10:04:35 GMT -6
I'm just confused by the "lack of stereo width" comment. That is absolutely the opposite of my experience. Plus, I think it's confusing when you say it "lacks" bass. That might give the impression there's something wrong with it. It is lighter on the bass than the symphony, yes. But you've had four people tell you that the symphony is colored and has an exaggerated bottom...and to say, "doesn't have any bottom" just makes me roll my eyes.
Post by NoFilterChuck on May 30, 2015 10:07:04 GMT -6
In USB mode, you can't clock the symphony to another device. if I used the symphony in Stand-alone or PT HD mode, i could clock it. that's probably a result of it being a usb device vs. fw or PCIe, but I have no idea. What I can do is connect my old MOTU Traveler and test it out with that being the interface it connects thru. that would let it be the master clock for the rig.
I want to love the unit, i really do. Just for the transient response alone, but using it is not a simple experience for guys with setups like mine. i.e. the majority of bedroom/livingroom studio cats. Again, who are you targetting with this box? those are the dudes who will see this converter for only $400 and say "hey, wait a sec... lemme check this thing out".
re: the monitor controller, It sounds like you're using your unit not as an audio interface, meaning you can't play music or youtube videos on your computer thru the converter. Even tho I use the symphony as my converter, it's also what I use to listen to everything coming out of my computer. System Preferences -> Sound -> Output ->Default Device: Symphony I/O.
I have Focal SOLO6's, and they're set flat. They're plugged right into the symphony's out1-2.
The best thing I can say to do is go rent some of these interfaces everyone else is using, and shoot out the box yourself. Sure, the theory that using the shortest paths is the best thing to do, but have you actually heard to what these other converters that everyone uses sound like? Apollo, new MOTU intefaces, Symphony, PT HD, PT 192s, Auroras, Prisms, Burl...
and turn down the brightness of that LCD lol
Post by Johnkenn on May 30, 2015 10:13:19 GMT -6
In all seriousness, I wonder if clocking it with the Symphony spdif could have caused any problems? I know that I had problems with all three (or was it four) symphony's I had. I could never seem to use spdif successfully because I would constantly get crackles. That didn't happen with any other interfaces.
Post by svart on May 30, 2015 10:26:11 GMT -6
I'm just confused by the "lack of stereo width" comment. That is absolutely the opposite of my experience. Plus, I think it's confusing when you say it "lacks" bass. That might give the impression there's something wrong with it. It is lighter on the bass than the symphony, yes. But you've had four people tell you that the symphony is colored and has an exaggerated bottom...and to say, "doesn't have any bottom" just makes me roll my eyes. I've had a few audiophiles listen and find nothing out of the ordinary. I've also had a few people say "lacks bass". I've had a few people say it was "fine". Even though this design is not a democracy, I'm taking all opinions and considering them. Most of the opinions have been positive, with most people saying that it sounds nice and flat, but somewhat clinical/sterile. I'd say that only a few of the recording subset have made mention of less bass. Honestly I think it boils down to expectations and opinion right now. Most folks are used to their systems and how they sound, and anything else that is introduced will sound foreign. On the other hand some people just like more top or bottom when mixing. I think the expectation that has been created is that this ADC/DAC setup would somehow make things sound better than before. However, I think people hear it and when they hear differences that aren't more of the "better" things they like out of their current setup, it's disappointing, even if it's technically better. The problem for me is trying to extract meaningful data out of opinions that were based on expectations, that may or may not have been met. I think that's the hardest part about recording in general, the constant "Am I doing this right" questions that drive us to try harder and be better. It boils down to whether your system works for you or not. Some people have their setups working in such a way that the slightest change makes everything sound completely different, and I understand that. I'm sure if I put a Symphony in my system right now, it would sound very bass heavy without tweaks, because my system is setup for a DAC that is not bottom heavy. Once I do some mixes and check the translation, I might adjust things and get the bottom heavy-ness evened out. At that point if I went back to my DAC, it would sound light on bass. In either case, my monitor positions, my room treatments, etc were all based on my DAC and how it acts with my monitor amplifier. Changing the DAC would simply change how everything else reacts. That's why most companies would do an-echoic measurements and double/triple blind listening tests, etc. They have teams of folks who pull data out of opinions and cross reference them to find the facts. I can't do that, so I'm just taking opinions and listening to them.
Post by NoFilterChuck on May 30, 2015 10:37:44 GMT -6
I'm just confused by the "lack of stereo width" comment. That is absolutely the opposite of my experience. Plus, I think it's confusing when you say it "lacks" bass. That might give the impression there's something wrong with it. It is lighter on the bass than the symphony, yes. But you've had four people tell you that the symphony is colored and has an exaggerated bottom...and to say, "doesn't have any bottom" just makes me roll my eyes. The sweeps i made don't show an exaggerated bottom. up until about 7k, both units have identical frequency response, so explain that, mr. science lol Please explain to me how, if i'm going out the analog outputs of the symphony into the analog inputs of the symphony and getting a flat response, it has an exaggerated bottom end.
Post by svart on May 30, 2015 10:40:14 GMT -6
re: the monitor controller, It sounds like you're using your unit not as an audio interface, meaning you can't play music or youtube videos on your computer thru the converter. Even tho I use the symphony as my converter, it's also what I use to listen to everything coming out of my computer. System Preferences -> Sound -> Output ->Default Device: Symphony I/O. I do use it for everything, music, youtube, etc. I simply choose the system audio output stream to be SPDIF/AES and route what I want to it. This box is simply a converter to be used by whomever wants to use it. I even have audiophiles interested in using it with CD players and things like that. Keeping it simple extends the ability for other groups to use it, besides just the recording folks.
Post by tonycamphd on May 30, 2015 10:42:05 GMT -6
Just noting dans comparison was the RMSB
Post by svart on May 30, 2015 10:43:36 GMT -6
I'm just confused by the "lack of stereo width" comment. That is absolutely the opposite of my experience. Plus, I think it's confusing when you say it "lacks" bass. That might give the impression there's something wrong with it. It is lighter on the bass than the symphony, yes. But you've had four people tell you that the symphony is colored and has an exaggerated bottom...and to say, "doesn't have any bottom" just makes me roll my eyes. The sweeps i made don't show an exaggerated bottom. up until about 7k, both units have identical frequency response, so explain that, mr. science lol Please explain to me how, if i'm going out the analog outputs of the symphony into the analog inputs of the symphony and getting a flat response, it has an exaggerated bottom end. I dunno, but if you look at the graphs you posted, you can see that the "symph" graph shows that the response goes down as frequency goes up. It's very slight, but you can see it, probably by about 1dB or so. Also, the sweeps you show don't show a lack of bass on my box either! It does show that it's a couple dB louder though. I mean, it looks like we have a quandry here. Your graphs don't show that the Symphony has excessive low end, but they also don't show that mine lacks low end. How could this be? Thoughts?
Post by NoFilterChuck on May 30, 2015 10:43:50 GMT -6
So, how do you control how loud it is? there's nothing between the system and your speakers preventing a line-level signal of a youtube video hitting your speakers lol
actually, your box was 5-6db quieter than the symphony. Does that mean that sending a sine wave out of your unit set to -18dbFS in the DAW will not be 1.22V, but lower?
Post by Johnkenn on May 30, 2015 10:49:14 GMT -6
The sweeps i made don't show an exaggerated bottom. up until about 7k, both units have identical frequency response, so explain that, mr. science lol Please explain to me how, if i'm going out the analog outputs of the symphony into the analog inputs of the symphony and getting a flat response, it has an exaggerated bottom end. I dunno, but if you look at the graphs you posted, you can see that the "symph" graph shows that the response goes down as frequency goes up. It's very slight, but you can see it, probably by about 1dB or so. Also, the sweeps you show don't show a lack of bass on my box either! It does show that it's a couple dB louder though. I mean, it looks like we have a quandry here. Your graphs don't show that the Symphony has excessive low end, but they also don't show that mine lacks low end. How could this be? Thoughts? Lol
Post by svart on May 30, 2015 10:52:17 GMT -6
So, how do you control how loud it is? there's nothing between the system and your speakers preventing a line-level signal of a youtube video hitting your speakers lol actually, your box was 5-6db quieter than the symphony. I use the system output fader, or I use the fader in my DAW/NLE depending what program I'm using at the time. I'm looking at the graphs, and the "symph" graph shows the line around 1/3rd the way up between -25db and -20db, say around -24db. The "svart" graph shows the line a bit higher, around -23dB.. I'm not seeing the 5-6db difference here. Are you sure you're running the outputs balanced? The outputs on my DAC are balanced and either need to go to a balanced input, or cables that convert from balanced to unbalanced(leave the RING unhooked). If the the cold/negative output is being grounded, then all bets are off on what it would sound like as the opamps are being stressed.
Post by Johnkenn on May 30, 2015 10:54:02 GMT -6
It's no different than buying any other outboard DAC. Burl B2, Lavry, etc. you can either have another interface that gets you in the computer or have a volume controller like the NOS, TC Level Pilot, Avocet, etc.
Post by NoFilterChuck on May 30, 2015 11:01:16 GMT -6
So, how do you control how loud it is? there's nothing between the system and your speakers preventing a line-level signal of a youtube video hitting your speakers lol actually, your box was 5-6db quieter than the symphony. I'm not seeing the 5-6db difference here. yes, I used balances cables. I am bumping up the signal in Logic 5db via a gain plugin after it comes back in. i wanted the graphs to have identical X values, so folks wouldn't think about the level difference when they looked at the graphs. also, i was callling JohnKenn mr. science, not you Svart
Post by Johnkenn on May 30, 2015 11:25:48 GMT -6
also, i was callling JohnKenn mr. science, not you Svart Wtf?
Post by svart on May 30, 2015 11:31:02 GMT -6
I think he was just razzing you.
Post by kcatthedog on May 30, 2015 11:53:17 GMT -6
mr. science, hmm,, I like that ! Damn the dilithium crystals, Scotty; give me full power to the proton converters ! I'll show you how to mix; you Klingon bastard !!!
Post by tonycamphd on May 30, 2015 12:04:04 GMT -6
IMO this falls squarely under the "parts of identical values and analyzer readings, do not necessarily sound the same" camp, probably why circuit clones rarely sound like originals? component choices and sound subtleties must be sussed out by ear through listening tests.
Post by Johnkenn on May 30, 2015 12:05:22 GMT -6
If the sweeps don't show anything different until 7khz, then they shouldn't sound as dramatically different as you claim. In fact, the science says they should be the exact same on the bottom. So obviously science doesn't explain everything.
Mr. Science
