Post by veggieryan on Nov 19, 2024 14:48:19 GMT -6
Antelope thunderbolt rtl Sample Rate (in kHz) Buffer (in samples) Round Trip Latency in (ms) 44.1khz. 16 1.769 44.1khz. 32 2.857 44.1khz. 64 5.034 96khz. 32 1.438 96khz. 64 2.438 Is this the reported latency in the DAW or the actual RTL as measured by Oblique RTL Utility? Can you run a small or medium size project in a DAW at 96 khz with 32 sample buffer?
Post by BenjaminAshlin on Nov 19, 2024 15:04:52 GMT -6
That makes sense. My SW guy is a personal friend and he helped my navigate and get the Orion/MADIface happening, and save for one weird issuse and I assume was my fault, I haven't had any issuses. At this point the Orion is purely the converter, and I've always liked the sound of it. Yeah, I would basically set the routing up in the Orion to be simple AD to MADI out and MADI in to DA, and then probably never mess with it again. I'm just really gun shy about depending on Antelope for any sort of driver/software sort of stuff, so relying on the Orion to work on it's own, much less also serve as the interface for MADI connections to/from the Burls, really worries me. RME, on the other hand, I feel like I would get really dependable, super low latency performance with their HDSPe MADI FX card in a Sonnet box. And I wouldn't have to worry about any interface stuff for a LONG time. That's not worth nothing. I just use the basic mixer view in Totalmix with just in's and out's. Then i use the orion mixer for routing and dsp...
Post by BenjaminAshlin on Nov 19, 2024 15:55:35 GMT -6
Antelope thunderbolt rtl Sample Rate (in kHz) Buffer (in samples) Round Trip Latency in (ms) 44.1khz. 16 1.769 44.1khz. 32 2.857 44.1khz. 64 5.034 96khz. 32 1.438 96khz. 64 2.438 Is this the reported latency in the DAW or the actual RTL as measured by Oblique RTL Utility? Can you run a small or medium size project in a DAW at 96 khz with 32 sample buffer? Just DAW. Yes my computer will manage an medium sized project at 96 khz 32. Antelope drivers are second best i have used in terms of latency performance. Almost as good as my RME PCI card. Slightly better than RME firewire/usb much better than MH, Apogee, Apollo.
Post by veggieryan on Nov 19, 2024 17:03:02 GMT -6
Post by doubledog on Nov 20, 2024 16:04:04 GMT -6
For kicks I measured my Orion 32+ Gen4 connected via USB on Windows 11 (using Oblique RTL). I typically run at 512 samples and just monitor through the software mixer (vs. the DAW) so there is zero "perceived" latency that way.
