Post by Quint on Nov 3, 2024 21:14:24 GMT -6
Has anybody here tried out the the black series Burl stuff? I'm wondering what people are thinking about it versus the older green face Burl stuff. The BAD16 and BDA16 are cheaper per channel than the older, lower channel count stuff, so they must be finding ways to make these for cheaper, per channel. That said, they're not exactly cheap, but at least maybe in a price range I could justify. If I decided to go this route, I'd be looking at the B16 Mothership with the BAD16 and BDA16 cards plus whatever motherboard card I decided to go with (MADI or Dante).
Also, I'm looking around at Dante and MADI and, man, there are not a whole lot of options to get Dante and MADI into the computer, without spending a decent chunk just for the interface. What are you Burl guys using? It's too bad that Burl doesn't have a Thunderbolt motherboard for the B16 Mothership. For latency reasons, I'm really only looking at either thunderbolt or pcie (in a Sonnet box connected to my Mac via thunderbolt).
Post by BenjaminAshlin on Nov 4, 2024 1:33:07 GMT -6
Can't comment on the Burl stuff but I think RME MADIface or Danteface USB would be one of the cheapest ways if you don't need dsp fx.
Post by Quint on Nov 4, 2024 1:40:50 GMT -6
Can't comment on the Burl stuff but I think RME MADIface or Danteface USB would be one of the cheapest ways if you don't need dsp fx. Unfortunately, for latency reasons, I'm really only looking at either thunderbolt or pcie (in a Sonnet box connected to my Mac via thunderbolt).
Post by BenjaminAshlin on Nov 4, 2024 3:39:14 GMT -6
YMMV, but in my experience running the Raydat PCI and Fireface 802 (USB2) on the same system the performance results were very close. RME USB latency numbers are about the same or slightly slower than their PCIe cards. As per the chart above when you add in the converter latency its basically the same.
Post by frans on Nov 4, 2024 5:22:59 GMT -6
If i am not mistaken, RME makes their own chipsets because they were not satisfied with what was available. Here i run a MADI pci card into my recording machine, so the digital doorstop doesn't has to be replaced every few years with some fancy new thing. Going to the patchbay with dSub connectors, so everything digital and everything analog is clearly seperated. In the mix room there is a much newer machine with a 2ch AD and done.
Post by Quint on Nov 4, 2024 8:09:24 GMT -6
YMMV, but in my experience running the Raydat PCI and Fireface 802 (USB2) on the same system the performance results were very close. RME USB latency numbers are about the same or slightly slower than their PCIe cards. As per the chart above when you add in the converter latency its basically the same. I looked at the RME USB stuff, and if I were going to go USB, they would be the one, but I'm sticking with Thunderbolt, for various reasons. So I would really need to find something that works with that. So far, the best option I've seen seems to be finding a used RME HDSPe MADI card, and putting that inside a Sonnet Thunderbolt box, and then connect that to my Mac. But that's still gonna be like a minimum total of roughly $1500. Ouch. The other option is the Motu 112D, but that's only Thunderbolt 2. I'm still surprised that nobody makes a TB 3 to Madi interface.
Post by frans on Nov 4, 2024 9:07:01 GMT -6
Would Thunderbolt 2 be a bottleneck? In my deluded mind i was thinking that it had enough bandwidth.
Post by gravesnumber9 on Nov 4, 2024 9:23:17 GMT -6
Would Thunderbolt 2 be a bottleneck? In my deluded mind i was thinking that it had enough bandwidth. I was about to say the same. I think TB2 is still way above the bandwidth where it matters. It's still 20 gb/s which is 4x faster than USB3. I don't think speed is the problem with these formats, it's drivers. My MOTU 828ES is also TB2 and latency is very low.
Post by Quint on Nov 4, 2024 10:00:08 GMT -6
It's not the speed and bandwidth. It's compatibility. As I understand it, despite the claim that it's not supposed to be a problem (it's supposed to be backward compatibile), there are some issues with trying to use TB3/4 gear with a downstream TB2 connection.
Post by gravesnumber9 on Nov 4, 2024 10:02:18 GMT -6
It's not the speed and bandwidth. It's compatibility. As I understand it, despite the claim that it's not supposed to be a problem, there are some issues with trying to use TB3/4 gear with a downstream TB2 connection. Hasn't been a problem for me with my UA Satellite. I daisy chain those all up without issue. Just one use case but still.
Post by Quint on Nov 4, 2024 10:04:10 GMT -6
It's not the speed and bandwidth. It's compatibility. As I understand it, despite the claim that it's not supposed to be a problem, there are some issues with trying to use TB3/4 gear with a downstream TB2 connection. Hasn't been a problem for me with my UA Satellite. I daisy chain those all up without issue. Just one use case but still. I'd have to go back and remind myself what the issues were. It was one of those "note to self" things, where I filed the concern away, but can't remember why it was a concern. I want to say it had to do with TB4 NOT being backward compatibile with TB1/2. TB3 may be fine (?), but what happens when I get a piece of TB4 gear somewhere down the road? That will happen sooner or later, and I don't want to spend $1500 on a MADI to TB box which won't work with that that TB4 gear in the not so distant future.
Post by veggieryan on Nov 4, 2024 12:06:27 GMT -6
I had the Motu 112D for a while. It worked well but it's kinda weird that the AES ports don't go above 96 kHz.
I dunno, at $1,500 it's not that much more to jump up to the RME PCIe which you know is the best there is.
Post by nobtwiddler on Nov 4, 2024 12:14:01 GMT -6
And now we have Thunderbolt 5~!
Post by Quint on Nov 4, 2024 12:28:08 GMT -6
I had the Motu 112D for a while. It worked well but it's kinda weird that the AES ports don't go above 96 kHz. I dunno, at $1,500 it's not that much more to jump up to the RME PCIe which you know is the best there is. Yeah, based on what I've seen thus far, and IF I end up going with MADI/Dante/AES converters, and thus need a separate interface of some kind, I'm leaning towards getting a Sonnet TB box and placing inside it an RME pcie card with the appropriate connection protocol. Potential TB2 compatibility issues aside, how did you like the routing on the Motu 112D? Any other gotchas with the 112D? Or features which you really liked?
Post by Quint on Nov 4, 2024 12:41:34 GMT -6
So has anybody here used the new black Burl BAD16 and BDA16 units? That's what I'm particularly interested in, especially how they compare to the older Burl stuff. Are these worth the money, or should I just go with the Lynx Aurora (n) and call it a day? The Aurora would certainly be cheaper.
Post by veggieryan on Nov 4, 2024 12:44:51 GMT -6
I liked it. The routing is flexible and I miss that being stuck on Apollo right now. The built in mixer is flexible but has anemic DSP like pretty much all interfaces with DSP mixers so no surprise there. The driver was solid and low latency over thunderbolt but RME is probably going to be significantly more efficient and I just trust them more. The other thing that bothered me is that there is only one thunderbolt port so no daisy chaining beyond it but not that big of deal these days since the new Macs have many thunderbolt ports and its probably best to keep it dedicated to its own port. Also if you use the AVB port to add another Motu interface the latency is offset unless you route through the mixer which is confusing: gearspace.com/board/music-computers/1356594-motu-16a-24ao-avb-latency.htmlAlso it's Motu and I never trust them 100%.
Post by christopher on Nov 4, 2024 15:49:50 GMT -6
I’ve been confused by the roll out of the black series. The pictures look same to me as the green stuff, but it’s new and less good if you read the description. Yet still expensive. Which is a weird way to market it, like what’s the point? I don’t see any images of the parts, so I’m guessing it’s all SMT pick and place by a robot? As to why.. I sort of wonder could this be the UA2192 multi-channel we never saw but should have had 20 years ago?
Post by copperx on Nov 4, 2024 16:08:08 GMT -6
I'm sticking with Thunderbolt, for various reasons. Why, though? Is the latency more predictable? USB is truly universal; Thunderbolt isn't.
I run my interfaces via USB even though Thunderbolt is available.
Post by Quint on Nov 4, 2024 16:30:26 GMT -6
Superior performance reasons aside, TB is also simply what I'm set up on, and I'm not really planning on changing that. So Thunderbolt solutions are what I'm looking at.
Post by veggieryan on Nov 4, 2024 16:39:48 GMT -6
Lynx Aurora (n) is tempting but they run hot putting so many channels in a 1U unit. You really need 3U of space with a blank above and below and even then I would not run it in a hot room. I never really gelled with the Hilo conversion I had so I never really considered this one personally. I also consider Apogee Symphony I/O MKII 16x16SE at this price point. It's 2U and has a quiet fan so it runs cooler. I find the Apogee sound more musical than Lynx to my ear. Another option if you want to go Dante for a bit more money: AMS Neve StarNet ADA16 It's +26 dbu and has the line amps from the 88R which is interesting. It's 1U so you need 1U space above but at least the power supply is external which greatly reduces heat. www.ams-neve.com/outboard/starnet-range/ada16/"The StarNet ADA16 is Neve’s first 16x16 analogue line-level AD/DA converter to the Dante audio-over-IP network. Housed in a 1U 19” rack chassis, the ADA16 is a compact, professional unit suited for integration into a wide range of recording studios, live sound venues, and broadcast or post-production suites. The StarNet ADA16’s is capable of up to 192kHz sample frequency and 32-bit integer bandwidth, with mastering- grade A/D converters producing 119dBFS of dynamic range, and pristine quality D/A converters producing 122dBFS of dynamic range. The ADA16 features a selectable headroom of +18, 24 or 26dBu to accommodate any digital standard. Analogue I/O is provided via four rear-panel DB25 connectors for simple connection to professional analogue equipment and studio patch bays. The Neve StarNet ADA16 uses a modern, low-drift crystal oscillator clocking system and PLL complimented with DAC chips featuring built-in jitter elimination, this system makes the ADA16 the ideal master clock in any professional studio environment. Devices can synchronise to the ADA16 master clock via a 75 Ohm BNC word clock output, and the StarNet ADA16 can synchronise with external equipment via a 75 Ohm BCN word clock input connection. The ADA16’s analogue output stage uses the same balanced line amplification technology from the 88R console. This circuitry delivers an analogue frequency bandwidth that surpasses 100kHz, the perfect platform to translate true 192kHz digital audio. This amplification stage is incredibly stable, able to drive long cable lengths without signal degradation. The analogue input stage is complimented with similar technology, professionally balanced, with superb common mode rejection and pristine audio quality."
Post by BenjaminAshlin on Nov 4, 2024 20:03:31 GMT -6
YMMV, but in my experience running the Raydat PCI and Fireface 802 (USB2) on the same system the performance results were very close. RME USB latency numbers are about the same or slightly slower than their PCIe cards. As per the chart above when you add in the converter latency its basically the same. I looked at the RME USB stuff, and if I were going to go USB, they would be the one, but I'm sticking with Thunderbolt, for various reasons. So I would really need to find something that works with that. So far, the best option I've seen seems to be finding a used RME HDSPe MADI card, and putting that inside a Sonnet Thunderbolt box, and then connect that to my Mac. But that's still gonna be like a minimum total of roughly $1500. Ouch. The other option is the Motu 112D, but that's only Thunderbolt 2. I'm still surprised that nobody makes a TB 3 to Madi interface. RME HDSPe MADI is the ultimate but I agree its expensive. Motu thunderbolt performance is way worse than RME USB so i would steer clear of that. Motu has double output buffer...
Post by Quint on Nov 4, 2024 20:41:47 GMT -6
Post by BenjaminAshlin on Nov 4, 2024 20:47:33 GMT -6
Let us know how it goes........... at least if you buy RME you know they will probably still be supported in 20 years.
Post by Quint on Nov 4, 2024 20:50:59 GMT -6
at least if you buy RME you know they will probably still be supported in 20 years. And that's not worth nothing, so I'd potentially be okay with paying more for the RME, for that reason alone.
