Post by drbill on Jul 7, 2024 10:13:50 GMT -6
For heavy-duty stands, I have three of these that I've had for well over 15 years. Two are in daily use (literally), and one is for extra OH mics on-demand. on-stage.com/hex-base-studio-boom-mic-standAround $200. if I recall. Base is cast iron and heavy; counterweight is 7 lbs, IIRC. No issues ever, either with imbalancing or durability. The clutch is geared (or toothed, depending on your choice of terminology), and never slips/sags/droops. Same for the mini-boom extension at the end of the boom arm. -09 Yes!! I have 3 of those as well. No problems here.
Post by teejay on Jul 7, 2024 16:42:22 GMT -6
You guys are scaring me. I bought one three years ago specifically for my REDD. The mic has been on it ever since. Sounds like I need Plan B before it takes a dive. Sounds like it’s a matter of time.
Post by ericn on Jul 7, 2024 17:48:11 GMT -6
You guys are scaring me. I bought one three years ago specifically for my REDD. The mic has been on it ever since. Sounds like I need Plan B before it takes a dive. Sounds like it’s a matter of time. I Know it’s common practice but don’t keep a mic in a shock mount or on a stand ,unless of course you are prepared for it to sometime hit the floor. Most mounts and stands were designed for temporary support not permanent support. Yes some have done it for years, but you will notice most commercial facilities know better and value their mics.
Post by the other mark williams on Jul 7, 2024 22:14:23 GMT -6
I know I've said it before around here, but my MC-125 is the only mic stand I've ever used where it just literally fell over. It had my Soyuz 017FET on it at the time. The center of gravity where the base contacts the wheels is too high. Compare it to the On-Stage one where the base is at the level of the center of the wheels (or maybe even lower). The main clutch on the boom arm of my Ultimate worked fine, and the counterweight was good, but the telescoping part of the boom broke within a year of light use. And then eventually the whole stand just flipped over one day. Bananas.
I bought a LatchLake 1100 after that: no wheels or anything, but that stand ain't flipping for nobody.
Post by drumsound on Jul 7, 2024 22:34:05 GMT -6
You guys are scaring me. I bought one three years ago specifically for my REDD. The mic has been on it ever since. Sounds like I need Plan B before it takes a dive. Sounds like it’s a matter of time. You are in a personal studio where mic stands aren't seeing nearly the action of a commercial room. That said, replace it with the On Stage, or Latch Lack if you're feeling saucy.
Post by svart on Jul 8, 2024 6:55:20 GMT -6
Just looking at that design, it looks way over-complicated. It's like a german car.. 80 parts in place of something that 5 parts would be fine just to make it function 2% better, until it breaks after 5 years and then it's 5000% more expensive to fix.
I still use a bunch of the old rubber washer squisher types that used to come 10x for 100$ back in the day. Still work fine although I've had a few of the plastic tensioner things for the main shaft break over the years because I tend to over-tighten them.
I also have a few of the On-stage toothed-cam types which I guess are a bit more similar to what the OP is using. They're a pain to reconfigure but they'll never droop or break at least.
Post by EmRR on Jul 8, 2024 7:56:36 GMT -6
What I DO like about this stand is the way it’s sympathetically designed to work around traditional Atlas 36’s, the base nests perfectly over a 36 and the general reaches are the same, so you can get several big stands into a very small footprint.
I should order a couple replacement clutches and see how that goes.
I have moved to using the onstage 3lb counterweights on my large booms, balance the boom perfectly before locking them down. More cheap insurance. Hadn’t previously had something fall over but multiple times the clutch on an Atlas let go and the mic was straight up, several times hitting a ceiling.
Post by andersmv on Jul 8, 2024 8:10:32 GMT -6
It's harder for me to tell people "spend a little bit more on the Latch Lake" now, as the prices have gone up significantly. If you've got mics that are getting up there in price (like the Chandler REDD mic) I know you've got the money to buy a nice stand. You're just being stingy, be honest . I'm not judging, I've been there and done the same thing. If you're just going to rack it straight up on a stand and do vocals in your bedroom, you don't need something big and expensive. The Guitar Center DR Pro stands are well under $100 and are just as good as a K&M or anything else in my opinion for mild use. If you're going to record drums and do overheads or something stupid and crazy with an extended arm, set aside 10% more of your mic budget and get a nice stand that's going to last you a lifetime and can be repaired. I splurged a few years ago and got two of the Latch Lake 1100's, one of them as the package with a few of the Xtra-Boom arms. Guess what I don't think or worry about anymore? Mic stands... The mics go where I want them to go, I can leave them up all week and never stress about it. I know I can do what I need to do with it and I know it's not going to break my mics. If you're spending thousands of dollars on mics, buy at least one really nice stand that isn't crap. If taking your mic stand budget from $300 (for sub par) to $500 (for top of the line, spare no expense) is too much for you, don't spend more crazy money on microphones... Ya the Latch Lakes are freaking expensive. You know what's even worse? That punch in your gut when your crap stand gives up, breaks your stuff and you go "I'm an idiot...". I've been there and done that, you never stop feeling like an idiot sandwich even years after it happens.
Post by ericn on Jul 8, 2024 8:19:53 GMT -6
It's harder for me to tell people "spend a little bit more on the Latch Lake" now, as the prices have gone up significantly. If you've got mics that are getting up there in price (like the Chandler REDD mic) I know you've got the money to buy a nice stand. You're just being stingy, be honest . I'm not judging, I've been there and done the same thing. If you're just going to rack it straight up on a stand and do vocals in your bedroom, you don't need something big and expensive. The Guitar Center DR Pro stands are well under $100 and are just as good as a K&M or anything else in my opinion for mild use. If you're going to record drums and do overheads or something stupid and crazy with an extended arm, set aside 10% more of your mic budget and get a nice stand that's going to last you a lifetime and can be repaired. I splurged a few years ago and got two of the Latch Lake 1100's, one of them as the package with a few of the Xtra-Boom arms. Guess what I don't think or worry about anymore? Mic stands... The mics go where I want them to go, I can leave them up all week and never stress about it. I know I can do what I need to do with it and I know it's not going to break my mics. If you're spending thousands of dollars on mics, buy at least one really nice stand that isn't crap. If taking your mic stand budget from $300 (for sub par) to $500 (for top of the line, spare no expense) is too much for you, don't spend more crazy money on microphones... Ya the Latch Lakes are freaking expensive. You know what's even worse? That punch in your gut when your crap stand gives up, breaks your stuff and you go "I'm an idiot...". I've been there and done that, you never stop feeling like an idiot sandwich even years after it happens. What’s worse? The bill to fix that mic & knowing you could have prevented it!
Post by guitfiddler on Jul 8, 2024 8:25:05 GMT -6
Post by drbill on Jul 8, 2024 9:38:30 GMT -6
My mainstay stands are the DR ones from GC/MF. For OH or high room mics, the OnStage come out. But for normal mic-ing, the DR's have worked great for me. BTW, any heavy mic gets sandbags on the bass/tripod of whatever stand I'm using.
Post by teejay on Jul 8, 2024 10:14:51 GMT -6
If you've got mics that are getting up there in price (like the Chandler REDD mic) I know you've got the money to buy a nice stand. You're just being stingy, be honest . I suggest a more appropriate word is "suspect" rather than "know". Some of us have personal studios that generate no income, and thus have limited funds. Mine are currently invested in mics and outboard, and I was stingy on none of it. I bought the MC-125 because at the time it seemed more than adequate for my requirements and was within budget. It's apparent I may now need to reconsider its continued use, but to "be honest", it's a big assumption that I have another $500-$1K available.
Post by andersmv on Jul 8, 2024 10:32:37 GMT -6
If you've got mics that are getting up there in price (like the Chandler REDD mic) I know you've got the money to buy a nice stand. You're just being stingy, be honest . I suggest a more appropriate word is "suspect" rather than "know". Some of us have personal studios that generate no income, and thus have limited funds. Mine are currently invested in mics and outboard, and I was stingy on none of it. I bought the MC-125 because at the time it seemed more than adequate for my requirements and was within budget. It's apparent I may now need to reconsider its continued use, but to "be honest", it's a big assumption that I have another $500-$1K available. Sounds to me like you weren't being stingy, you just bought what you thought was best! That's different, in that case my opinion is that there are better options out there you should consider. I'm talking directly to the crowd that will try to say "I just spent $4000 on a mic, I don't have money for a $XXX mic stand!". I've had this conversation play out for me in real life plenty of times, and that's pretty much the path to the dark side. Pain leads to anger, anger leads to hate, hate leads to suffering. COME BACK TO THE LIGHT!!!! You're definitely not stingy
Post by Vincent R. on Jul 8, 2024 10:33:45 GMT -6
I have (2) of these stands, and have never had any issues with them. Now, I'm not an active professional studio as some of you are. I'm either recording session vocal work, or for myself. That said, I did take one apart for my move. The hub part everyone is talking about had to be put back together very specifically, or it would not work, so I imaging if one of the parts within it failed, that this could absolutely be an issue. Even when the stand does work, it requires the counter weight to be properly balanced or it will move a bit, even when locked. crillemannen do you know which internal part of the hub failed on you? Just curious, as I'll want to keep an eye on my stands.
Post by EmRR on Jul 8, 2024 11:07:04 GMT -6
Even when the stand does work, it requires the counter weight to be properly balanced or it will move a bit, even when locked. Yes that's what I see with the pair here, it's not strong enough to hold an imbalance and I've wondered if it was worn out.
Post by ab101 on Jul 8, 2024 11:49:37 GMT -6
If you do live work, metal hubs really help. The plastic ones do break. (You never know what order or how a roadie throws in the stand and heavy equipment into a vehicle. And soft stand cases will not protect those plastic hubs.) For a studio, the Latch Lakes with the heavy bases rule.
Post by crillemannen on Jul 8, 2024 12:08:54 GMT -6
I have (2) of these stands, and have never had any issues with them. Now, I'm not an active professional studio as some of you are. I'm either recording session vocal work, or for myself. That said, I did take one apart for my move. The hub part everyone is talking about had to be put back together very specifically, or it would not work, so I imaging if one of the parts within it failed, that this could absolutely be an issue. Even when the stand does work, it requires the counter weight to be properly balanced or it will move a bit, even when locked. crillemannen do you know which internal part of the hub failed on you? Just curious, as I'll want to keep an eye on my stands. I made a video showing the part that broke. It's all metal so it's quite weird that it would get loose. Just poor construction I guess. I would suggest to sell the stands.
Post by doubledog on Jul 8, 2024 13:52:59 GMT -6
I have 3 of the MC-125. I got them probably 12-15 years ago. I had a problem with one of the knobs and one of the clutches and back then, Ultimate had a "lifetime warranty" which changed to something shorter (it's on the website but I think it's 5 or 6 years now). Anyway, they sent me parts and I made them send parts for all 3 even though only 2 had different issues... But that gave me extra parts. I have 2 of the stands semi permanently over drums and no issues. The other I use for heavy mics but I don't ever leave them unattended.
It is important to use the counterweights, but I also don't use mine heavily so they are not completely worn out yet.
Post by tonycamphd on Jul 8, 2024 22:15:43 GMT -6
What’s up fella’s? Been a minute, I picked these beefsters up for safe booming, u can get adapters for microphones for a couple extra bucks, you can solidly hang U47’s overhead of drums from a mile away with em, the only mic stands that come close ime are the old school pneumatic ones that cost at least a couple $k(star bird?) www.amazon.com/GVM-C-Stand-Photography-Reflector-Monolight/dp/B08Q3K384B
Post by the other mark williams on Jul 8, 2024 22:57:57 GMT -6
What’s up fella’s? Been a minute, I picked these beefsters up for safe booming, u can get adapters for microphones for a couple extra bucks, you can solidly hang U47’s overhead of drums from a mile away with em, the only mic stands that come close ime are the old school pneumatic ones that cost at least a couple $k(star bird?) www.amazon.com/GVM-C-Stand-Photography-Reflector-Monolight/dp/B08Q3K384BWhat's up, Tony - it's been awhile. Yeah, C-Stands can work well, and you can (and should) sandbag the tall leg on the base, and then it's definitely not going anywhere. I use these for lights all the time. Lights that are much heavier than any microphone. Tony, which adapters for mics do you use? I haven't actually seen very many that I like.
Post by tonycamphd on Jul 9, 2024 9:13:21 GMT -6
What’s up fella’s? Been a minute, I picked these beefsters up for safe booming, u can get adapters for microphones for a couple extra bucks, you can solidly hang U47’s overhead of drums from a mile away with em, the only mic stands that come close ime are the old school pneumatic ones that cost at least a couple $k(star bird?) www.amazon.com/GVM-C-Stand-Photography-Reflector-Monolight/dp/B08Q3K384BWhat's up, Tony - it's been awhile. Yeah, C-Stands can work well, and you can (and should) sandbag the tall leg on the base, and then it's definitely not going anywhere. I use these for lights all the time. Lights that are much heavier than any microphone. Tony, which adapters for mics do you use? I haven't actually seen very many that I like. cant remember exactly, but I use something like this www.sweetwater.com/store/detail/KM85040--k-and-m-85040-thread-adapter?mrkgadid=&mrkgcl=28&mrkgen=gpla&mrkgbflag=1&mrkgcat=accessories&acctid=21700000001645388&dskeywordid=&lid=58700008695999512&dsproductgroupid=&product_id=KM85040&prodctry=US&prodlang=en&channel=online&storeid=&device=c&network=x&matchtype=&adpos=largenumber&locationid=9031930&creative=&targetid=&campaignid=21161059670&awsearchcpc=&gad_source=1&gclid=Cj0KCQjwv7O0BhDwARIsAC0sjWMe_JK3F4hLkVLMZpedwVTcZ-2rbKQdmbSDDX5naKdIkQXaNrXZ3xIaAi95EALw_wcB&gclsrc=aw.dsto something like this www.amazon.com/dp/B0BRTTBCNY/ref=sspa_dk_detail_1?psc=1&pd_rd_i=B0BRTTBCNY&pd_rd_w=73aRu&content-id=amzn1.sym.8c2f9165-8e93-42a1-8313-73d3809141a2&pf_rd_p=8c2f9165-8e93-42a1-8313-73d3809141a2&pf_rd_r=CGHGEY8RWKEPS5D1EDFR&pd_rd_wg=okIGQ&pd_rd_r=c2ed6dcb-bbf9-488d-b051-6645157d5225&s=photo&sp_csd=d2lkZ2V0TmFtZT1zcF9kZXRhaWwhope that helps
Post by ericn on Jul 9, 2024 9:32:14 GMT -6
What’s up fella’s? Been a minute, I picked these beefsters up for safe booming, u can get adapters for microphones for a couple extra bucks, you can solidly hang U47’s overhead of drums from a mile away with em, the only mic stands that come close ime are the old school pneumatic ones that cost at least a couple $k(star bird?) www.amazon.com/GVM-C-Stand-Photography-Reflector-Monolight/dp/B08Q3K384BWhat's up, Tony - it's been awhile. Yeah, C-Stands can work well, and you can (and should) sandbag the tall leg on the base, and then it's definitely not going anywhere. I use these for lights all the time. Lights that are much heavier than any microphone. Tony, which adapters for mics do you use? I haven't actually seen very many that I like. Someone with say a nice Atlas metal lathe could crank those out, but I haven’t had one in 35 years so that leaves me out. We really need to find someone who owns a machine shop and likes to record, so many cool little bit we could use.
Post by Martin John Butler on Jul 9, 2024 9:50:41 GMT -6
Dang, I've got one of these and planned to use it to hold my SA-47. Now I'm concerned.. ugh.
Post by the other mark williams on Jul 10, 2024 11:31:11 GMT -6
(Note: The below response is meant for future forum users as much as or more than Tony) Ah, gotcha - I thought maybe you'd found the holy grail that I've never quite managed to find: a grip stud with a male 5/8" screw on the end, ready to receive a microphone clip ( ericn, THAT'S what we need our mythical machine shop to make!). If you're currently using a spigot stud as listed above, I would recommend something like this instead: www.bhphotovideo.com/c/product/1340616-REG/kupo_kg012512_3_5long_5_8_baby_stud.htmlThat's a baby pin stud that's actually designed to go into a grip head / knuckle (if your C-Stand didn't come with an extra knuckle, you can get those separately here: www.bhphotovideo.com/c/product/371923-REG/Impact_KCP_200_Grip_Head_2_5.html)You can then use a 3/8" to 5/8" adapter like the one from Sweetwater above - except I wouldn't use that one from Sweetwater, as it's made of plastic. You can find brass ones that won't degrade, burr up, or fail. Or I guess for you folks in Europe, is it true that 3/8" is your standard size for mic clips anyway??
Post by EmRR on Jul 10, 2024 12:14:52 GMT -6
