Post by okcrecording on May 1, 2024 20:08:31 GMT -6
Loving this thread. Great stuff here.
Post by drumsound on May 1, 2024 22:04:21 GMT -6
Was it No Hype Audio you tried? That's where I bought my pair from years ago. They're still in business so that might be another option as well. Looks like they have a waiting list. I'm not rushing to buy anything right now.
Post by theglow on May 3, 2024 7:27:21 GMT -6
Coles 4038 ~18” above the cymbal. Highpass around 400Hz and boost 10kHz shelf to taste. I’ve yet to find anything that sounds/blends better.
Post by Ward on May 3, 2024 7:58:12 GMT -6
Coles 4038 ~18” above the cymbal. Highpass around 400Hz and boost 10kHz shelf to taste. I’ve yet to find anything that sounds/blends better. My tinnitus deeply loathes 10khz shelving. (no chessparov, it doesn't like Ikea shelving either)
Post by drumsound on May 3, 2024 8:49:28 GMT -6
Coles 4038 ~18” above the cymbal. Highpass around 400Hz and boost 10kHz shelf to taste. I’ve yet to find anything that sounds/blends better. My tinnitus deeply loathes 10khz shelving. (no chessparov , it doesn't like Ikea shelving either) My tinnitus isn't that specific. Usually when working I don't notice it. It's when things are quiet that I'm aware of it.
Post by doubledog on May 11, 2024 10:37:06 GMT -6
How are you positioning said ride spot mics to minimize bleed? I'm usually mic'ing from the top (tried underneath once and found it was like mic'ing a gong. didn't like it). I like my drums and cymbals pretty tight together (economize motion - I don't want to have to swing my arms like a gorilla to reach something) - but that of course makes for more bleed between close mics. But sometimes I'm finding crash cymbals (especially big ones as are popular these days) are bleeding into the ride cymbal mic. I've tried raising the crashes a bit (helps some) and I also tried a piece of foam (sort of sitting on top of the boom stand that is holding the ride mic and reaching over the ride cymbal). The idea was to reduce bleed from the crash cymbals above and to the sides. I don't think it's really done much though. Those crashes are probably reflecting off the top of the ride and back up into the mic. I think the mic I'm using right now (Slate ML-2) is probably just plain old cardioid (Slate never published any specs on the mic itself). So maybe a hyper or super-cardioid mic would be better... or maybe I have to completely reposition the cymbals (and retrain many years of muscle memory... yikes).
Anyway, what are your tips/tricks?
Post by drumsound on May 11, 2024 12:07:02 GMT -6
How are you positioning said ride spot mics to minimize bleed? I'm usually mic'ing from the top (tried underneath once and found it was like mic'ing a gong. didn't like it). I like my drums and cymbals pretty tight together (economize motion - I don't want to have to swing my arms like a gorilla to reach something) - but that of course makes for more bleed between close mics. But sometimes I'm finding crash cymbals (especially big ones as are popular these days) are bleeding into the ride cymbal mic. I've tried raising the crashes a bit (helps some) and I also tried a piece of foam (sort of sitting on top of the boom stand that is holding the ride mic and reaching over the ride cymbal). The idea was to reduce bleed from the crash cymbals above and to the sides. I don't think it's really done much though. Those crashes are probably reflecting off the top of the ride and back up into the mic. I think the mic I'm using right now (Slate ML-2) is probably just plain old cardioid (Slate never published any specs on the mic itself). So maybe a hyper or super-cardioid mic would be better... or maybe I have to completely reposition the cymbals (and retrain many years of muscle memory... yikes). Anyway, what are your tips/tricks? The first time I did it was one for my own band. There's a slow tempo song where I put a chain on a 20" crash and ride on it for most of the song, but there's one section where I go to my main ride for contrast in a turnaround. besides that I really wanted the sizzle to speak like a drone. I even play all the fills with my left hand whils still playing eighths with my right o the sizzle/chain cymbal. For that I used a 414eb basically right between those 2 cymbals. It worked exactly as I thought it would. We did another song or two on the same day and I really liked having the ride present so, then I kept doing it. I more recently put the mic around 10 o'clock on the ride about 2-3 inches in. It feels a little better for isolation, but it still is kinds of like another overhead. I used a Gefel M295 a few times, and this week an MC012 in hyper, and I think I like it a little better.
Post by doubledog on Nov 17, 2024 13:50:18 GMT -6
Anyone else using a hypercardioid or supercardioid mic on ride cymbal? I'm thinking I may want to try one to see if it reduces some of the cymbal bleed (already repositioned cymbals and the mic). Looking for bang-for-the-buck kind of mic (i.e. limited budget). Probably SDC, but LDC might work as long as its not too large and heavy (if it has great rejection). A couple that came to mind are of course the Oktava MK012 (with the hyper capsule) and the Sennheiser e614. What else can you suggest?
Post by Mister Chase on Nov 17, 2024 15:17:54 GMT -6
Neumann TLM102. Best goddamned ride cymbal mic I have ever used. I have had the same one on ride for 12 or more years now. Always trying something different (and I have 133 mics to choose from) and always come back to it, through the same old Neve 33420 preamp that crunches nicely. It is just a phenomenal sound. I keep hearing this about the 102. Must get some.
Post by drumsound on Nov 18, 2024 0:00:49 GMT -6
Anyone else using a hypercardioid or supercardioid mic on ride cymbal? I'm thinking I may want to try one to see if it reduces some of the cymbal bleed (already repositioned cymbals and the mic). Looking for bang-for-the-buck kind of mic (i.e. limited budget). Probably SDC, but LDC might work as long as its not too large and heavy (if it has great rejection). A couple that came to mind are of course the Oktava MK012 (with the hyper capsule) and the Sennheiser e614. What else can you suggest? The Oktavas are really cool little mics. And because they're modular, you could start with the hyper cap and add others later for different uses.
Post by Ward on Nov 18, 2024 10:12:58 GMT -6
Neumann TLM102. Best goddamned ride cymbal mic I have ever used. I have had the same one on ride for 12 or more years now. Always trying something different (and I have 133 mics to choose from) and always come back to it, through the same old Neve 33420 preamp that crunches nicely. It is just a phenomenal sound. I keep hearing this about the 102. Must get some. It's amazing on Femvox too. It may need de-essing in lead vocal application but it's something else on backing vocals for bringing out a ton of air and detail in the nicest way!
Post by gravesnumber9 on Nov 18, 2024 11:23:00 GMT -6
I keep hearing this about the 102. Must get some. It's amazing on Femvox too. It may need de-essing in lead vocal application but it's something else on backing vocals for bringing out a ton of air and detail in the nicest way! 102 was my first "step up" mic years ago. I still use it all the time. Sounds great on a lot of stuff. Even with a mic locker that now fills an actual locker, I still bring the 102 on a lot of stuff. Just in the last few months I've used it on guitar amps, piano, room mic, drum overhead, acoustic guitar body mic, and kick drum. The thing is so versatile and so small that you can pretty much just plug it in anywhere that a cardioid is appropriate. Oh, and it has won more than its fair share of vocal mic shootouts around here against more expensive opponents. To me the 102 is the utility infielder of my mic locker, but the utility guy who plays every day and can bat anywhere in the lineup (sorry to non-baseball fans). Best part... you can find them for $500 used all the time. It probably won't be your best mic but I guarantee it will get used. A lot.
Post by doubledog on Nov 21, 2024 10:27:10 GMT -6
I just pulled the trigger on a used Oktava MK-012 with the hypercardioid capsule so I'm looking forward to comparing it to what I've already got.
Post by EmRR on Nov 21, 2024 12:07:06 GMT -6
It’s so curious to me that mk-012 hyper has recently become the preferred cap mentioned frequently, there was a solid 20 years of it being the LEAST preferred capsule. I certainly never used it as it never won over the cardioid or omni and thus sold mine off eventually.
The first suggestion of usefulness was Oktava marketing the ‘film set’ with it for boom use along with the HPF adapter. The HPF adapter is a hopelessly noisy addition (science, damn you) and an O12 of any type is more prone to wind and vibration pickup than most SDC’s I’ve encountered. Seems to be mentioned frequently as a budget entry piece for film location work.
Post by Dan on Nov 21, 2024 12:13:12 GMT -6
It’s so curious to me that mk-012 hyper has recently become the preferred cap mentioned frequently, there was a solid 20 years of it being the LEAST preferred capsule. I certainly never used it as it never won over the cardioid or omni and thus sold mine off eventually. It sounds like a salt shaker on overheads but has that acidic Soviet mic midrange. Massive distortion is in vogue now. Hear the mixes people praise and popular music. It’s not really a stereo mix down more than distorting everything. I’ve been paid to do this. It’s very silly. The end results are far dirtier than something like a death album, where the gear tone is negligible beyond valvestates, sometimes over 1176ed vocals, and ssl channel compressor fast attack. And the envelopes those put on the material are nothing compared to the defective ones of dysfunctional digital compressors or the ping of a distressor or crappy diode comp.
Post by EmRR on Nov 21, 2024 12:14:13 GMT -6
Incredibly rare i spot a cymbal, if it was free i’d probably lean on M160 or M130 first.
Post by Dan on Nov 21, 2024 12:16:24 GMT -6
Incredibly rare i spot a cymbal, if it was free i’d probably lean on M160 or M130 first. I’ve put the sdcs on the cymbals and used Omni dynamics or typical dark ribbons for the overheads. It helps to have a bottom snare mic there too to add back in the wires
