Post by craigmorris74 on Oct 27, 2022 10:24:32 GMT -6
The ribbon motor of the Apex 205 is almost identical to one of the best commercial ribbons currently produced. What is different is the ribbon material (often thicker in the Apex) and the installation and tensioning of the ribbon, which is often sloppy. If you get the a new ribbon installed by a qualified tech, it should sound fantastic. Contrary to a lot of internet speculation, the Apex transformers aren't too bad.
As far as removing mesh layers goes, all expensive ribbon mics have multiple layers of mesh for protection and/or shaping the frequency response. Check out the innards of nice mics both modern and vintage to see what I mean.
Post by drumsound on Oct 27, 2022 11:48:14 GMT -6
I'll have to check out the sE mics. I've wanted to get a V7 for a while and hearing that their ribbons are good makes me even more curious... as the owner of 5 Apex 205s, I cannot encourage you enough to get someone to pull out the extra mesh and stick a lundahl in there. worth every penny. I literally use them (at least 2 of them) on every session i do. Already done the mesh stuff. I haven't yet upgraded transformers. My plan had always been to get a second 205 and get transformers in both at the same time (and I expected to get both ribbons looked at/replaced at the same time to make sure they matched) but it all just hasn't gone that way. The V7 is also a very good mic. I should get a couple more. I think they DESTROY a certain really famous mic that costs the same on the retail market...
