Post by phdamage on Aug 30, 2022 21:06:54 GMT -6
Couple days late with this, but here goes: I think I finally learned to actually mix with an SSL style comp on my 2 bus! I’ve been leaving the ancient waves one on my tracking mix for a good while now. I don’t know if I just got used to it or figured it out, but when I started to do my mix on Sunday, I thought I should stay in the same realm instead of my usual UAD 33609. I went with the Townhouse so I could make use of parallel processing (I did a bit).
I have a busy 2 bus chain, admittedly, but the comp is 2nd in line after TDR Nova (just to keep the lows under control if needed) and prob does the most heavy lifting of the whole chain.
If this keeps up, I may swap my stam 609 order for a buss comp.
Post by OtisGreying on Sept 10, 2022 0:50:39 GMT -6
Today I discovered you can tighten a ProLine microphone stand to the its maximum tightness before it perhaps breaks and snaps - and it will still drift..... on a KM84!
