Post by drumsound on Jun 6, 2022 7:45:01 GMT -6
What dessers are you guys into. I haven't 'renewed' or whatever my IK stuff since my upgrade, because I don't feel like dealing with their whole 'install everything' method. Plus I was never totally confident they didn't add latency (their comps never worked right in parallel...) But I did like the desser. It has a lot of cool features including a more 'notch like' feature by using the 3 band option, plus different db/octave choices.
So, anything similar/better?
What are you into, and why?
Post by kcatthedog on Jun 6, 2022 8:04:09 GMT -6
I Like Feb filter, easy to use, sounds good and good gui.
Post by din on Jun 6, 2022 8:33:12 GMT -6
FabFilter DS is good. I like the SofTube Weiss one a litter better.
Post by Deleted on Jun 6, 2022 8:56:15 GMT -6
Presswerk
Post by tkaitkai on Jun 6, 2022 8:57:49 GMT -6
Used to be Pro-DS, but lately I’ve been loving Techivation T-De-Esser. I don’t know if I’d call it transparent, but whatever it’s doing sounds really sweet to my ears.
Post by bossanova on Jun 6, 2022 8:59:35 GMT -6
Renaissance DeEsser in split mode does the trick for me in all but a handful of cases. Before that I used Fabfilter.
Waves Sibilance is great too but it's more tweak-y, and I can usually get faster results from just dropping in RenDeEsser with the default preset.
Post by ragan on Jun 6, 2022 9:19:40 GMT -6
FabFilter Pro-DS has been my go-to for years. I can’t find a fault with it. Love it.
Post by cowboycoalminer on Jun 6, 2022 9:29:10 GMT -6
I'm a Fab Filter guy for years. Easy to set and it works without too much degradation. Used others but always go back to this.
Post by drumrec on Jun 6, 2022 9:55:03 GMT -6
Worth checking out Sooth2. Works very nicely for most things!
Post by trakworxmastering on Jun 6, 2022 9:57:27 GMT -6
DSEQ is great at detecting and zapping only the offending frequencies, and it sounds natural to me. Similar concept to Soothe 2 but works even better IMO.
Post by seawell on Jun 6, 2022 11:59:36 GMT -6
Massey DeEsser 👍🏻
Post by srb on Jun 6, 2022 15:50:26 GMT -6
Weiss De-esser gets the most use here over the last couple-three years. Very flexible.
Post by delcampo on Jun 6, 2022 16:22:01 GMT -6
2 stage approach here lately of DBX 902 going in, & Nova GE later to fine tune. I Keep meaning to try DSEQ for more broad mix stuff.
Post by notneeson on Jun 6, 2022 16:54:10 GMT -6
I like the Massey, and I used to use the Digirack one that is free with Pro Tools too.
These days I use the T-racks one and I just drag all the IK plugs I don't own to the unused plugins folder so I never have to think about them again.
(I own several IK plugs that I get a lot of use out of).
Post by viciousbliss on Jun 6, 2022 17:36:40 GMT -6
I really like the PA Lindell 902. A good improvement over the LSR version.
shawnh
Junior Member
Post by shawnh on Jun 6, 2022 17:40:23 GMT -6
I can’t seem to figure out the IK de-esser. I have to crank it way up to get it to do anything. I must be missing something. Other similar plugins seem to work as expected on the same sources. I actually really like the one in the SSL vocalstrip plug-in. Find that plug-in very useful.
Post by phdamage on Jun 6, 2022 17:55:44 GMT -6
fab filter here for a long while. just stupid simple to use and not much of a CPU hit, compared to Soothe or one of my other options.
Post by drumsound on Jun 6, 2022 19:49:11 GMT -6
Thanks, folks. There's a couple of things I've never heard of, so I appreciate that.
Post by the other mark williams on Jun 7, 2022 15:47:57 GMT -6
Thanks, folks. There's a couple of things I've never heard of, so I appreciate that. Not that you need yet more suggestions, Tony, but in addition to several of the options listed above, I also use DMG Audio's two different deessers quite regularly: TrackDS and Essence. Waves Sibilance is also nice, and pretty damn transparent.
Post by drumsound on Jun 7, 2022 21:18:15 GMT -6
Thanks, folks. There's a couple of things I've never heard of, so I appreciate that. Not that you need yet more suggestions, Tony, but in addition to several of the options listed above, I also use DMG Audio's two different deessers quite regularly: TrackDS and Essence. Waves Sibilance is also nice, and pretty damn transparent. I appreciate it. I use the stock PT from time to time, and may even give in on the T-racks, but I wanted to know what was out there.
Post by yewtreemagic on Jun 8, 2022 9:10:40 GMT -6
I'm another TDR Nova GE user.
Post by Martin John Butler on Jun 8, 2022 9:36:22 GMT -6
Do you guys use multi-band compressors too? Recently I've begun to mainly use automation to edit vocals that have spitty formants and big "esses" and "T's". It's tedious, but feels a bit more natural. I'd love to just pop on a compressor for the main vocal and be done, but none of the software compressors I've used quite do it for me.
Perhaps a good hardware compressor like the Retro 176 or a Tube Tech CL1b would do that trick for me?
Post by Deleted on Jun 11, 2022 11:19:55 GMT -6
Do you guys use multi-band compressors too? Recently I've begun to mainly use automation to edit vocals that have spitty formants and big "esses" and "T's". It's tedious, but feels a bit more natural. I'd love to just pop on a compressor for the main vocal and be done, but none of the software compressors I've used quite do it for me. Perhaps a good hardware compressor like the Retro 176 or a Tube Tech CL1b would do that trick for me? That's essentially what the LA-2A was made for, a decent emulation or actual 2A should roll off the high's and smooth a few things out. Stam's version was just as good as the Tele's for me, not sure about Audioscape.
Post by Johnkenn on Jun 11, 2022 12:02:58 GMT -6
Just a mention. Waves Sibilance is really good.
Post by tasteliketape on Jun 11, 2022 12:47:09 GMT -6
