CS566 | Channel Strip with Console Emulator
May 30, 2022 23:26:50 GMT -6
plinker and tkaitkai like this
Post by hrkstudioequipment on May 30, 2022 23:26:50 GMT -6
CS566 | Processing Channel Strip with VCA Compressor, Console Emulator, 4 Band EQ and the Active Transformer
Enhance Your Tracks and Mix with Analog Harmonics
Upscale Your Mixing and Mastering Ability
Create Top Rate Results Effortlessly
Features HRK Solid Stated Drive Console Emulator
Flexible Input and Output Level Controls
Discrete Opamp Custom HRK VCA Compressor
NOS Military Grade Transistors from the '80s
Easy to Apply Soft-Knee Compression Curve
Post Compressor HF Auto-Enhance Feature
Stereo Coupling Feature for Stereo Operation
Four Band Ultrasmooth Equaliser
Two Frequency Settings for Each EQ Band
Musical and Intuitive EQ Filters Curves
Augmented HRK Active Transformer Output
Line Level Signal Processing
High Headroom up to +25dBu
Multiple Sources of Subtle Analog Harmonics
Ear Picked Studio-Grade Low Noise Opamps
High-Gloss Black Gold Pearl Finish Front Panel
Balanced Input and Output
High-Quality Audio Potentiometers
Compatible with API 500 Format
The CS566 is an Ultimate Analog Studio Processor dedicated to Professional Music Producers and Audio Engineers.
The CS566 is a result of the Extensive Development Process. The circuitry of each stage was carefully tweaked to produce bespoke performance.
The CS566 has independent +/-12dB input-output level controls to match a source signal level and the sensitivity of the following processing studio hardware in the signal chain.
The Custom Discrete Opamp VCA Compressor relates to the classic discrete VCA modules used in the '70s and '80s.
The CS566 compressor provides extensive control over the signal dynamics envelope while enabling straightforward operation.
The HRK Solid State Drive Console Emulator is a result of a completely new design approach to Analog Saturation and Harmonics Generation.
The CS566 features Four Band Equaliser. Each Band has two frequency settings.
The Augmented HRK Active Transformer adds the final touch to the processed signal by injecting additional harmonics and forming the frequency response of the classic transformer output stage.
The CS566 is a compact and easy to use line level Channel Strip featuring all essential tools for Tracking and Mastering.
Great review of the CS566 on the FB HRK User Group.
Direct Sale - Save on Distributors Fee!
More Info:
hrkshop.eu/product/cs566-processing-channel-strip/Great review of the CS566 on the FB HRK User Group.
