Post by delcampo on Apr 21, 2022 9:58:46 GMT -6
I Purchased this directly from Roger Foote and it’s been mostly used here on the mix buss & generally never came off the buss.
It has an impressive width & clarity. (they now sell for over 5k new) It's no BS to say I absolutely hate to have to sell yet I do for family needs.
It’s in proper working condition and very good cosmetic condition aside from one small scratch somewhat seen in pictures. (It's very small)
-$2900 obo
Details:
P4DMS Compressor
Blue panel with Red Dots
The P4DMS is a dual mono/stereo compressor with sets of controls on mil spec potentiometers.
In dual mono mode, the 2 channels are completely independent
In stereo mode, the left channel controls the stereo compressor while the right controls are disabled.
Cinimag transformers
Scott Liebers SL2520 Red Dot op amps
This unit already has the optional HPF frequency selector. It is a 5 position rotary switch on the rear panel
50Hz
74Hz
120Hz
160Hz
255Hz
P4DMS Stereo Compressor Features
> All analog audio path
> Fully balanced audio I/O on Neutrik XLR connectors
Cinemag input and output transformers
> High quality mil spec potentiometers
> Gold plated switch contacts
> RMS Mode that uses the human ear's responses as a compression model
> A/R Mode that allows the user to custom tailor attack and release times The Attack control has a range of 0.15ms/dB to 15.0ms/dB
The Release control has a range of 1.5ms/dB to 150ms/dB
> N/L mode that automatically adjusts time constants using program material content
> A high pass filter at 100 Hz before the detector to limit how much low frequencies contribute to overall compression shape
> Threshold range from -50dB to +15dB
> Ratio continuously variable from 1:1 through 12:1
> Makeup gain range from 0dB to +20dB
> Fast LED metering to display the gain reduction of the compressor. > Maximum ouput level of +27dBu
-$2900 obo
Details:
P4DMS Compressor
50Hz
74Hz
120Hz
160Hz
255Hz
