Post by Blackdawg on Apr 9, 2022 1:45:54 GMT -6
Id add SoundToys Radiator and Devil Lock are both cool options at times too.
Post by kcatthedog on Apr 9, 2022 4:16:09 GMT -6
A great overview, thx guys. I had decapitator in the past and have missed it from time to time, but good to check out some of these others too!
Post by tasteliketape on Apr 9, 2022 6:58:41 GMT -6
Post by kcatthedog on Apr 9, 2022 8:22:38 GMT -6
ST’s want $199 for Decap., $200 to get everything I don’t have : hmmm:)
I’m thinking about selling my UA plugs and octo, find myself using fewer and fewer UA plugs. Not so worried about its sub plan, getting uadX plugs (free), goes with your plugs if you sell them, ironically, making them,I think, more desirable .
Post by ml on Apr 9, 2022 15:39:09 GMT -6
I agree with everything said. Decapitator is great. I do love FF Saturn 2 on vocals though. I sometimes use burier by KIT, and its FREE. kitplugins.com/pages/burier-free
Post by yewtreemagic on Apr 9, 2022 17:15:55 GMT -6
I've tried out loads, and top if my list for quality is Fuse Audio Labs' VPRE-2C for its versatility (low/high/flat grit) yet just getting the job done quickly. Others Fuse Audio Labs products I reach for include VPRE-31A, and for more extreme treatments VPRE-562A and TCS-68, Elysia's Phil's Cascade. Kit Plugins' Burier mentioned by ml above is also great for being able to quicker move from subtle grit to full-on distortion, when you're not sure what will best suit a sound. If I've got time to fiddle about more, I also like Black Box Analog (the original non mid-side release), even on the 2-buss, although I find it overkill for track duties. New discoveries with promise that I'm still investigating include Kiive Audio's Distinct! (a variety of more extreme treatments based on the Overstayer modular channel, with built-in compression) and Tone Projects' Kelvin (which is incredibly versatile and sounds great to my ears!) I do own Soundtoys' Decapitator, but although it can do more subtle preamp stuff (I've created some of my own presets for this) the factory presets are almost universally 'over the top' and less useful for my purposes, so I tend to find myself reaching for other plug-ins unless I really want to destroy a sound Martin
Post by deaconblues on Apr 9, 2022 22:10:57 GMT -6
Is anyone using the Softube Overstayer?
Post by Deleted on Apr 9, 2022 22:46:24 GMT -6
I've tried out loads, and top if my list for quality is Fuse Audio Labs' VPRE-2C for its versatility (low/high/flat grit) yet just getting the job done quickly. Others Fuse Audio Labs products I reach for include VPRE-31A, and for more extreme treatments VPRE-562A and TCS-68, Elysia's Phil's Cascade. Kit Plugins' Burier mentioned by ml above is also great for being able to quicker move from subtle grit to full-on distortion, when you're not sure what will best suit a sound. If I've got time to fiddle about more, I also like Black Box Analog (the original non mid-side release), even on the 2-buss, although I find it overkill for track duties. New discoveries with promise that I'm still investigating include Kiive Audio's Distinct! (a variety of more extreme treatments based on the Overstayer modular channel, with built-in compression) and Tone Projects' Kelvin (which is incredibly versatile and sounds great to my ears!) I do own Soundtoys' Decapitator, but although it can do more subtle preamp stuff (I've created some of my own presets for this) the factory presets are almost universally 'over the top' and less useful for my purposes, so I tend to find myself reaching for other plug-ins unless I really want to destroy a sound Martin Martin, if you want subtle, the Fuse 2C not pushed is king imo. The solid state ones are more obvious but still great. The 2C can be cleaner than the more exciting Neold V76. People forget that good tube pres are pretty clean for most of the gain range. Of course the good tubes are gone now. So is the Tupe 12ax7 not pushed on HQ. Tupe will just bring anything not Alder Bridge or an M1 to its knees when stacked up on a track with a lot of other killer modern non-linear plugs the most woody subtle 60s sounding “virtual pre” I’ve heard though is the PSP Infinistrip 60s pre. Fat and woody
Post by Deleted on Apr 9, 2022 22:52:24 GMT -6
Also U-he Satin. By far the most subtle tape plug. Choose a studer preset. Gainstage it correctly on the vu meter with the input knobs. Slightly better. Stack it up on everything with a high shelf feeding it if your computer is powerful enough even though the plug’s almost 10 years old and the mix just sounds huge.
If you don’t want to be careful and want big distorted tape sound on 2 bus, Fuse Flywheel, UAD Ampex 102, and Waves Kramer Tape are pretty cool on mix bus.
Post by Deleted on Apr 9, 2022 23:00:16 GMT -6
And The real dirty secret is there is no secret weapon distortion plug and you need a ton the stuff mentioned here in this thread. Because on any individual song, 9/10s of these won’t work no matter how clean they are in plug-in doctor or how big they sound on an individual drum or guitar or voice. and there will always be ONE that just sounds amazing. Even for same room, same mics, same gear, same day, same session but different song.
One track, Fuse TCS-68 did it where the pultec plugs and E27 and Slick EQ to boost failed. The mid eq band and shelves and pre amp distortion were just perfect. Next track, TCS-68 sounded awful and the PSP E27 sounded amazing and a low shelf + a 200 hz boost, 550/680 cut, + high shelf and the drive turned down to peak at -10 dbfs just sounded huge on the room.
You still need ears.
Post by yewtreemagic on Apr 10, 2022 5:56:21 GMT -6
Post by theshea on Apr 10, 2022 6:00:53 GMT -6
damn! there goes my audio engineer/musician career ... but i could still be a modern pop producer - thank god for those sample/chord packages where i can put together a song like playing with lego bricks! yey!
Post by evangelista on Apr 10, 2022 8:12:00 GMT -6
I do still sometimes use the original sansamp plugin. SNIP Also using softube tape here and there. Great choices
Post by chessparov on Apr 10, 2022 9:10:47 GMT -6
2 pages and no one mentioned the... ART Tube MP? ![;)](//storage.proboards.com/forum/images/smiley/wink.png) Chris
Post by Deleted on Apr 10, 2022 9:59:40 GMT -6
Post by Guitar on Apr 10, 2022 10:09:39 GMT -6
2 pages and no one mentioned the... ART Tube MP? ![;)](//storage2.proboards.com/forum/images/smiley/wink.png) Chris the true path of saturation:
Post by theshea on Apr 10, 2022 10:26:34 GMT -6
klf what time is love?! mu mu! haha!
Post by drumsound on Apr 10, 2022 11:15:39 GMT -6
2 pages and no one mentioned the... ART Tube MP? ![;)](//storage2.proboards.com/forum/images/smiley/wink.png) Chris You joke, but one of the best distorted drum things I ever got was an EV 408 over the BD shell pointed at the snare through a cranked ART Pro MP. There's Not Much Left
Post by Ward on Apr 10, 2022 18:44:36 GMT -6
I'm still fond of the Digidesign Avid Eleven amp models for some overdrive on bass.
And the AIR Soundfield distortion plug is awesome on crotch mic.
Post by drumrec on Apr 11, 2022 8:27:03 GMT -6
Although the honeymoon has passed and everyday life steps in, I am still in love with "KITBB N105" for distortion when driving mic gain. Many other good tips on the thread, must check out
Post by the other mark williams on Apr 12, 2022 0:01:11 GMT -6
Soundtoys Juice all the way.
Hahahaha - man, how long ago was it that ST pushed that thing and it literally never appeared! IIRC, it even won some award at a tradeshow or something.
Post by the other mark williams on Apr 12, 2022 0:08:49 GMT -6
Now, on a more serious note, I do like Tone Projects Kelvin - that’s a good plugin IMO.
Also Saturn2, KIT BB N105, Kush Omega 458a, and even the venerable Sonnox Inflator sometimes. Acustica Cream has some really nice saturation, as does Magenta.
Post by kcatthedog on Apr 12, 2022 4:36:13 GMT -6
Having fun with kit burier, it punches the ticket just fine: simple but useful features and very good sound with adjustable drive: nice !
Post by yewtreemagic on Apr 12, 2022 6:10:47 GMT -6
Having fun with kit burier, it punches the ticket just fine: simple but useful features and very good sound with adjustable drive: nice ! Yep, that's what I like about it too - if you're not sure what treatment to give a sound, Burier lets you dial in anything from subtle preamp vibes to totally buried in distortion by turning a single control, all with reasonably well-matched gain compensation for consistent volume
Post by brenta on Apr 12, 2022 9:44:43 GMT -6
Anybody using the UAD Culture Vulture? I use most of the plugins mentioned in this thread and don’t feel like I need another, but this is on sale right now.
