Post by Johnkenn on Nov 22, 2021 18:51:35 GMT -6
Anyone have any suggestions? I have used the Waves LL-Ultra or whatever for a long, long time...ease of use and it sounds good. But after making the change to the new computer, that plug is only offered in bundles that I don't want. Any suggestions for a good Drumbus limiter? Catching peaks and pulling up volume is really all it will be doing. I have the GH Faraday - and I like that, but it can be too much color sometimes.
Post by kcatthedog on Nov 22, 2021 19:50:16 GMT -6
I like fab filter, UA Zener
Post by Johnkenn on Nov 22, 2021 19:58:20 GMT -6
yeah might demo the Pro-L again
Post by sirthought on Nov 22, 2021 20:51:01 GMT -6
Inflator
Manley Vari-Mu
Ozone Limiter
Post by notneeson on Nov 22, 2021 21:25:20 GMT -6
Why not use Stealth for that?
FWIW, I got Stealth during the group buy based on your recommendation and I'm still getting to know it.
Before that I used L2007 for a longggggg time and it can totally do the job.
Post by Deleted on Nov 22, 2021 21:26:22 GMT -6
Anyone have any suggestions? I have used the Waves LL-Ultra or whatever for a long, long time...ease of use and it sounds good. But after making the change to the new computer, that plug is only offered in bundles that I don't want. Any suggestions for a good Drumbus limiter? Catching peaks and pulling up volume is really all it will be doing. I have the GH Faraday - and I like that, but it can be too much color sometimes. For Faraday, turn down the analog color and turn on HQ!
Post by Johnkenn on Nov 23, 2021 9:33:15 GMT -6
Why not use Stealth for that? FWIW, I got Stealth during the group buy based on your recommendation and I'm still getting to know it. Before that I used L2007 for a longggggg time and it can totally do the job. I have to re-adjust my workflow with this new computer. Hadn’t used it on anything but the master because of cpu consumption. But I’ve tried it before and it sounded fantastic. That’s a great idea. I could probably use on on every channel now lol!
Post by svart on Nov 23, 2021 9:34:33 GMT -6
JST clip.
I also use Arouser for the drum bus compression these days.
Post by notneeson on Nov 23, 2021 10:10:47 GMT -6
Well here's something else, I'm using the Fuse LA4A for clipping drums and that sounds pretty boss.
Post by mcirish on Nov 23, 2021 10:53:19 GMT -6
The Softube Chandler Zener Limiter does a very cool thing to the drum buss. I also use DMG Track Limit in transparent mode as the final plugin on my drum bus. That one has no color and I use it to prevent the stray snare from peaking the sub. I often use a clipper for that too but Track Limiter is still always the last thing on the drum bus.
Try the Chandler. I think there might be some preset from Eric Valentine that makes the drums come alive a bit without overdoing it.
Post by Blackdawg on Nov 23, 2021 10:59:15 GMT -6
Anyone have any suggestions? I have used the Waves LL-Ultra or whatever for a long, long time...ease of use and it sounds good. But after making the change to the new computer, that plug is only offered in bundles that I don't want. Any suggestions for a good Drumbus limiter? Catching peaks and pulling up volume is really all it will be doing. I have the GH Faraday - and I like that, but it can be too much color sometimes. what version of LL Ultra do you have? Because you should be able to DL whatever version you had(V8/V9/V10/ect) as a seperate installer and just reinstall what you had. www.waves.com/downloads/v8Not that buying something new isn't fun but if you have it and like it, might as well keep using it.
Post by Deleted on Nov 23, 2021 11:07:20 GMT -6
I've retracted my 1176 offering (even though I use it often) because I was going to buy the entire TDR suite and kept forgetting to do so. Also I have the UA Sonnox Limiter and Ozone 9 so it wasn't a must buy right now.. However as a cheap(ish) limiter that's extremely transparent and has a great clipping section you can't really beat TDR's 6 GE. www.tokyodawn.net/tdr-limiter6-ge/
Post by superwack on Nov 23, 2021 11:50:41 GMT -6
Anyone have any suggestions? I have used the Waves LL-Ultra or whatever for a long, long time...ease of use and it sounds good. But after making the change to the new computer, that plug is only offered in bundles that I don't want. Any suggestions for a good Drumbus limiter? Catching peaks and pulling up volume is really all it will be doing. I have the GH Faraday - and I like that, but it can be too much color sometimes. what version of LL Ultra do you have? Because you should be able to DL whatever version you had(V8/V9/V10/ect) as a seperate installer and just reinstall what you had. www.waves.com/downloads/v8Not that buying something new isn't fun but if you have it and like it, might as well keep using it. John bought an M1 Mac so he's got to have Waves V13 for that which means a WUPgrade $$$
Post by Johnkenn on Nov 23, 2021 11:54:38 GMT -6
Anyone have any suggestions? I have used the Waves LL-Ultra or whatever for a long, long time...ease of use and it sounds good. But after making the change to the new computer, that plug is only offered in bundles that I don't want. Any suggestions for a good Drumbus limiter? Catching peaks and pulling up volume is really all it will be doing. I have the GH Faraday - and I like that, but it can be too much color sometimes. what version of LL Ultra do you have? Because you should be able to DL whatever version you had(V8/V9/V10/ect) as a seperate installer and just reinstall what you had. www.waves.com/downloads/v8Not that buying something new isn't fun but if you have it and like it, might as well keep using it. I had a...ahem...long term borrow.
Post by Johnkenn on Nov 23, 2021 11:55:34 GMT -6
The Softube Chandler Zener Limiter does a very cool thing to the drum buss. I also use DMG Track Limit in transparent mode as the final plugin on my drum bus. That one has no color and I use it to prevent the stray snare from peaking the sub. I often use a clipper for that too but Track Limiter is still always the last thing on the drum bus. Try the Chandler. I think there might be some preset from Eric Valentine that makes the drums come alive a bit without overdoing it. I often slam that and use it in Parallel. What I'm kind've looking for is more of a clean one.
Post by Johnkenn on Nov 23, 2021 11:55:57 GMT -6
what version of LL Ultra do you have? Because you should be able to DL whatever version you had(V8/V9/V10/ect) as a seperate installer and just reinstall what you had. www.waves.com/downloads/v8Not that buying something new isn't fun but if you have it and like it, might as well keep using it. John bought an M1 Mac so he's got to have Waves V13 for that which means a WUPgrade $$$ Yeah - that's what it was
Post by Ward on Nov 24, 2021 11:09:08 GMT -6
Until they're manufactured, and we all have our own audioscape 78s, What's the best 1178 plugin out there?
Post by gouge on Nov 24, 2021 15:25:23 GMT -6
keen to know the answer for the best 1178 too.
for now im using the 2252 compressor in acustica gold 4.
Post by superwack on Nov 24, 2021 15:35:44 GMT -6
Until they're manufactured, and we all have our own audioscape 78s, What's the best 1178 plugin out there? Does anyone but PULSAR make one? I've never heard of one and google only turns up that one. I've never tried it but I guess it's the best? LOL
Post by ragan on Nov 24, 2021 15:48:42 GMT -6
That’s the only DSP 1178 I’ve heard of
Post by gouge on Nov 24, 2021 15:58:53 GMT -6
pulsar plug gets a pretty good wrap.am starting to think it may be a cheaper alternative to arouser
Post by Deleted on Nov 24, 2021 20:58:08 GMT -6
Presswerk
Post by gouge on Nov 24, 2021 21:38:39 GMT -6
listened to pulsar 1178 demo and it's definitely not for me. too bright
listened to presswerk and it sounds great. but. not me.
listened to arouser...oh my i need to be arousered
Post by ab101 on Nov 24, 2021 23:38:58 GMT -6
interesting - a couple mentions of Arouser. I have Dave Derr's Big FrEQ plugin and think it is very good, but almost no mention on this forum. I need to try Arouser.
