Post by Randge on Apr 26, 2014 13:47:55 GMT -6
Does each 51X rack have individual power or do you have to shut the supply off to change out modules?
R
Post by tonycamphd on Apr 26, 2014 13:55:36 GMT -6
Does each 51X rack have individual power or do you have to shut the supply off to change out modules? R Not sure what you mean by "individual power" Randge? I've changed them hot, the 51x box has 18 pin card accepters(extra pins for 24v, standard vpr has 15 pin for 16v only), you can put it in skewed and pop a fuse, the standard vpr case you can't do that, it only goes in one way, although i would NEVER recommend anyone hot swapping cards with exposed electronics or otherwise, too easy to F up IMV.
Post by Randge on Apr 26, 2014 14:21:36 GMT -6
Each of the RTZ 10 slot racks have an individual power so you can shut them off and not have to power down everything. You also don't have to waste electricity if you are only using one of the racks and not the others. R Attachments:
