Post by kcatthedog on Mar 31, 2021 8:46:52 GMT -6
From Drew’s UA forum post :
UniversalAudio said:
1 Minute Ago
LUNA 1.1.7 is out, get it in-app.
Video on best method for creating/using Templates:
www.dropbox.com/s/6f4ku36joi...lates.mp4?dl=0
UA Live stream on new features:
LUNA v1.1.7
NEW Session Templates
- Save the exact state of the current session as a LUNA Template file
- Create new sessions from LUNA templates
- Option to include media in templates
NEW Utility: Mixer Delay
- Fully automatable track level "Delay" control added to UTILITY row allows 0 to to 1000ms delay of audio and midi playback on all track types
IMPROVED Increase/Decrease Grid value key command direction reversed to more intuitively change the value direction
IMPROVED Utility row mixer Trim value display now shows tenths of a dB
IMPROVED UAD2 Plug-ins with long names now use shortened name text in INSERT assignments
FIXED Resolved an issue that could cause LUNA Instrument plug-in windows to occasionally load with a very small window size
FIXED Return key no longer fails to perform action buttons in SAVE BOOKMARK and SAVE NEW VERSION pop over dialogs
FIXED LUNA Instruments no longer ignore initial automation breakpoints after loading a preset
FIXED Resolved an issue that caused delay compensation issues after changing sample rates
FIXED Resolved an issue that could prevent accurate note velocity capture for chords that are played just before the Count In ends
FIXED Toggle Snap and Toggle Relative Snap keyboard shortcuts now work on German keyboard layouts using the modifier and 7 key where "" is located
FIXED Resolved an issue that could cause undo to restore incorrect values on automation when restoring the first automation breakpoint
FIXED Sends and Cues POWER modifier overlay button now accurately reflects power status
FIXED Duplicated tracks no longer appear in alternate windows that have a bus SPILL engaged
FIXED Resolved an issue that prevented AU plug-ins from copying successfully (note that this fix will only apply to newly instantiated AU plugins, existing AU instances that have already been copied once will not paste successfully)
FIXED Resolved a crash that could occur when deleting an instrument track with multiple midi output assignments
FIXED Insert Time no longer fails to shift Time Signature events after making a selection in the ALL TRACKS ruler
FIXED Resolved an obscure crash that could cause LUNA to crash after using Set Bar One command and starting playback
Multi-Quote This Message
1 Minute Ago
LUNA v1.1.7
