Limiters
Mar 25, 2021 14:46:21 GMT -6
via mobile
Post by theshea on Mar 25, 2021 14:46:21 GMT -6
lets talk limiters. which one are you using when mastering? and why? i am still using vlad‘s limitier n. 6. i have compared it in the past with L2, ozone limiter but always got back to n. 6. am i missing out on something?
Post by Blackdawg on Mar 25, 2021 14:56:42 GMT -6
Pro Limiter by Avid L2, sometimes, I don't always love it's sound Elixir v3 is great
Need to try DMG Limitless And try Ozone again as well, wish you could just buy the limiter only.
For a lot of things though I use 2 limiters in series so one isn't doing all the work.
Post by svart on Mar 25, 2021 15:06:37 GMT -6
L1, JST clip or one of the dozen limiters in reaper.
Limiters
Mar 25, 2021 15:09:57 GMT -6
via mobile
Post by theshea on Mar 25, 2021 15:09:57 GMT -6
For a lot of things though I use 2 limiters in series so one isn't doing all the work. did that in the past. forgot about it. thanks for reminding.
Post by Blackdawg on Mar 25, 2021 15:44:59 GMT -6
For a lot of things though I use 2 limiters in series so one isn't doing all the work. did that in the past. forgot about it. thanks for reminding. Im mixing an album and when I go to master it I want to try out Flatline which is a clipper plugin in series with a limiter. It looks interesting to me and sounds cool in the examples.
Post by tasteliketape on Mar 25, 2021 16:00:25 GMT -6
Post by stormymondays on Mar 25, 2021 16:04:08 GMT -6
Fabfilter Pro L2. Does the job beautifully with no artifacts and great metering. The 1:1 comparison is really great.
Post by Blackdawg on Mar 25, 2021 16:39:19 GMT -6
wow that's a cool limiter. Might have to check that out.
Limiters
Mar 25, 2021 17:49:41 GMT -6
via mobile
Post by nick8801 on Mar 25, 2021 17:49:41 GMT -6
Ozone here. Love all the options. No issues.
Limiters
Mar 25, 2021 18:02:23 GMT -6
via mobile
Post by mcirish on Mar 25, 2021 18:02:23 GMT -6
For mastering I use Ozone limiter, but before it I usually have a clipper to just knock off the odd random transient by a dB. The DMG Track Limiter set to transparent mode is also very good. I used to use Elephant too but found it a little too fiddly. I was thinking of looking at the Boz Wall. Might be ok as a track limiter and the sale price is good.
Limiters
Mar 25, 2021 18:10:15 GMT -6
via mobile
Post by mrholmes on Mar 25, 2021 18:10:15 GMT -6
Most often: Ozone9 or the free W1.
Limiters
Mar 25, 2021 18:49:08 GMT -6
via mobile
Post by srb on Mar 25, 2021 18:49:08 GMT -6
I've used Voxengo Elephant a lot over the years. PSP Xeon, too. Over the last couple years the Ozone limiter more.
The one I'm really liking and using more and more these days is the Softube Weiss offerings. Solid.
Post by nomatic on Mar 25, 2021 20:04:19 GMT -6
AOM invisible Limiter G2 on every track... I have done hundreds of tracks with this and it is still my fav after trying everything.
Post by Blackdawg on Mar 25, 2021 21:22:39 GMT -6
AOM invisible Limiter G2 on every track... I have done hundreds of tracks with this and it is still my fav after trying everything. That one looks nice too. Will check it out.
Limiters
Mar 26, 2021 1:37:34 GMT -6
via mobile
Post by theshea on Mar 26, 2021 1:37:34 GMT -6
when using ozone, are you using limiter IV? i only got ozone elements, so only limiters I and II. but ... are you “hearing“ differences when only applying 1-2 db reduction?
Post by schmalzy on Mar 26, 2021 3:50:44 GMT -6
A little clipping from JST Clip, a little limiting from Reaper's Event Horizon, and then I'll use the VladG Limiter N°6.
I like the last little clipping and ISP protection the VladG Limiter N°6 has.
I'm definitely trying to get my loudness from the mix and not work to find it in a mastering process. JST Clip tells me audibly when I'm pushing too hard. Event Horizon tells me audibly when I'm pushing too hard. I like knowing with no uncertainty about stuff like that.
Limiters
Mar 26, 2021 7:11:11 GMT -6
via mobile
Post by srb on Mar 26, 2021 7:11:11 GMT -6
when using ozone, are you using limiter IV? i only got ozone elements, so only limiters I and II. Yes, limiter IV 90% of the time, when I do use it.
Post by Deleted on Mar 26, 2021 7:23:29 GMT -6
Tokyo Dawn Limiter 6 GE on insane mode. Nothing else is close. DMG Limitless is a diy limiter construction kit and is missing half the features that give you loudness cleanly, keeping punch. The high frequency stuff in Limiter 6 is great.
Post by tasteliketape on Mar 26, 2021 7:39:04 GMT -6
Post by Guitar on Mar 26, 2021 7:53:07 GMT -6
I've had 3 main eras over the years
Fab Filter Pro L then Newfangled Elevate now Ozone 9 Maximizer
But the best process, sometimes is a blend of a couple of them together, for the biggest sound. For example, Elevate doing a lot, then Pro L just doing 1 or 2 dB more. A lot of times, you can skip the mix bus compressor with this method.
All three are fantastic and will beat out lesser competition.
Pro L is pretty normal sounding, just all around decent. Elevate has a lot of wonderful expert features, so I lean on it. Ozone seems to be able to get incredibly loud with minimal artifacts, and has a very simple interface. Flipping around the different modes, you'll find a good one for the material.
Limiters
Mar 26, 2021 7:56:40 GMT -6
via mobile
Post by theshea on Mar 26, 2021 7:56:40 GMT -6
Post by Deleted on Mar 26, 2021 7:57:17 GMT -6
The TDR bundle + De-edger is the best deal in digital audio.
Post by gwlee7 on Mar 26, 2021 11:25:54 GMT -6
The TDR bundle + De-edger is the best deal in digital audio. I will probably pick this up when I get back home this afternoon. Put in my cart.
Post by Martin John Butler on Mar 26, 2021 17:21:52 GMT -6
I bought Slate's FG-X mastering compressor/limiter ages ago. It was quickly outperformed by other plug-ins. Slate promised a version II to version one buyers, and eight years later still hasn't delivered. I've used Waves L2 a lot, but would like something like that, just a bit cleaner.
Post by popmann on Mar 26, 2021 19:52:15 GMT -6
I've not used anything since Lurrsen just changed that game for me. It's the first solution for masturbing that I end up making it louder than I meant to...and having to back it down back into double digits. But, also--I'm not looking to fix shit about the mix. There's really little facility for that.
I'm telling you...track with Burl...pull tracks into Mixbus32c....mix...spit out 32/96 into Lurrsen...this is all getting a little too easy. I'm gonna have to start focusing on making better music or sompin'...
