Post by superwack on Mar 22, 2021 15:30:50 GMT -6
I'm a Sonar Works 4 user and have been following the long and complaint-filled threads regarding the latest upgrade/rebranding (SoundID?) People are saying it was released while still in BETA, windows 10 users are having a lot of issues with clicks/pops and profiles resetting and the upgrade price is really high for what seems to be mostly the rebranded GUI, the re-addition of things they removed from SW4 (targets of other speakers to emulate them) and a couple other things - some of which do seem cool like the ability to only correct what you want and to have different correction for different outputs. The initial upgrade for previous owners was $119 but they have now lowered it to $89 for the Studio+Headphones. The previous upgrade from SW3 to SW4 was like $19! I really like SW4 but am waffling on upgrading. I see a lot of people in that thread talking about dSONIQ's Realphones and I was curious if anyone had any thoughts on it? I just downloaded the demo so I'm nowhere near making any sort of decision on it. It only does headphone correction (not speakers) and, if you'd like, it adds a "studio" sound and crossfeed, and speaker emu and all that. They have a ton of headphone models and seem to keep adding them (in a cheeky move, they even included Slate's VSX phones so you can compare his software with theirs). I have read posts from the company admitting it's too tweaky for most users and they plan to release a simplified option soon. It works as a plugin and system wide, just like SW4 It's got to be the most generous demo I've ever seen. 41 days and includes 3 headphone models of your choice AND you can renew the demo every 6 months. It's $99 for the "pro" level that includes 3 headphones of your choice and $179 for the one with unlimited headphone models but apparently they just had a 50% off sale so my plan is to work with it alongside SW4 for a month to see what I think in hopes a sale comes around again. Anyone else trying/using it? Here's the link: www.dsoniq.com/
Post by mamm7215 on Mar 23, 2021 20:14:05 GMT -6
I have and like Realphones. I also have Sonarworks 4. I haven't used it since getting Realphones. I won't be getting the upgrade to SoundID. I can sometimes get SW4 to be close to RP but usually it's when I dial the mix slider down 50% or less. Realphones I usually run around 70-80%. I like the Mix-phones settings for my profiles. It even makes my Sennheiser HD280Pros useable. SW4 made them sound weird. I normally use Sony 7506s or Focal Spirit Pros. I'm thinking hard about getting some Audeze LCD-1s now. It's got a great demo but for 50% off it's a no-brainer to me. I do still use SW4 for my monitors. Just not headphones anymore.
Post by superwack on Mar 23, 2021 21:06:24 GMT -6
I have and like Realphones. I also have Sonarworks 4. I haven't used it since getting Realphones. I won't be getting the upgrade to SoundID. I can sometimes get SW4 to be close to RP but usually it's when I dial the mix slider down 50% or less. Realphones I usually run around 70-80%. I like the Mix-phones settings for my profiles. It even makes my Sennheiser HD280Pros useable. SW4 made them sound weird. I normally use Sony 7506s or Focal Spirit Pros. I'm thinking hard about getting some Audeze LCD-1s now. It's got a great demo but for 50% off it's a no-brainer to me. I do still use SW4 for my monitors. Just not headphones anymore. Thanks for your thoughts. It’s day 1 for me and I mixed something on the default MIX “Normal” setting - resisting the urge to tweak - and then played it on my monitors corrected by SW4 and it translated really well. I was surprised as there is definitely an initial “wow, this sounds weird” not being used to it, but I’m already leaning where you are: RP for cans, SW for monitors. Funnily enough, before I saw the SoundID thread I had started contemplating getting LCD-1’s (currently have ATH-M50x that I bought “calibrated” through SW and Sennheiser HD600) and that’s kind of what led me on the path where I found Realphones.
Post by mamm7215 on Mar 24, 2021 18:44:11 GMT -6
Yeah I'm torn between HD600 and LCD-1s, HD600 is the perennial best all-rounder but I'm too curious about the LCD-1.
Post by bgrotto on Mar 25, 2021 23:25:23 GMT -6
Realphones basically revolutionized the way I mix. Not an exaggeration. I can get results at home comparable to what i get at my studio, and I've found it's made mixing a record between the two locations much, much simpler and more predictable.
Post by superwack on Mar 25, 2021 23:31:04 GMT -6
Realphones basically revolutionized the way I mix. Not an exaggeration. I can get results at home comparable to what i get at my studio, and I've found it's made mixing a record between the two locations much, much simpler and more predictable. Curious what you are using - preset? Tweaked preset or totally made your own? So far I’ve been on the MIX / nearfield dropping the ambience to about 80% from 100 for most of the mix but checking it on others... I have to admit there have been a couple of times when I actually stopped to see if the vocal was actually coming out of my monitors - spooky!
Post by bgrotto on Mar 27, 2021 19:08:06 GMT -6
Realphones basically revolutionized the way I mix. Not an exaggeration. I can get results at home comparable to what i get at my studio, and I've found it's made mixing a record between the two locations much, much simpler and more predictable. Curious what you are using - preset? Tweaked preset or totally made your own? So far I’ve been on the MIX / nearfield dropping the ambience to about 80% from 100 for most of the mix but checking it on others... I have to admit there have been a couple of times when I actually stopped to see if the vocal was actually coming out of my monitors - spooky! Main cans are Senny / Mass Drop 6xx. At first, I was using SonarWorks at home, which was OK, but not great. When I got Realphones, I was using their 650 setting, which I tweaked to suit my tastes. But for the last few months, I've combined the two: Realphones > Sonarworks, and I'm getting the best results of the three scenarios.
Post by superwack on Mar 27, 2021 19:34:21 GMT -6
Curious what you are using - preset? Tweaked preset or totally made your own? So far I’ve been on the MIX / nearfield dropping the ambience to about 80% from 100 for most of the mix but checking it on others... I have to admit there have been a couple of times when I actually stopped to see if the vocal was actually coming out of my monitors - spooky! Main cans are Senny / Mass Drop 6xx. At first, I was using SonarWorks at home, which was OK, but not great. When I got Realphones, I was using their 650 setting, which I tweaked to suit my tastes. But for the last few months, I've combined the two: Realphones > Sonarworks, and I'm getting the best results of the three scenarios. Oh wow, you just blew my mind! I have SW4 and am going to try this! So when you go RP > SW do you fully disable the RP correction and only use it for the room? Thanks so much for sharing
Post by bgrotto on Mar 28, 2021 16:13:38 GMT -6
Main cans are Senny / Mass Drop 6xx. At first, I was using SonarWorks at home, which was OK, but not great. When I got Realphones, I was using their 650 setting, which I tweaked to suit my tastes. But for the last few months, I've combined the two: Realphones > Sonarworks, and I'm getting the best results of the three scenarios. Oh wow, you just blew my mind! I have SW4 and am going to try this! So when you go RP > SW do you fully disable the RP correction and only use it for the room? Thanks so much for sharing There's actually a setting within RP that's meant for feeding into SW. It's a calibration profile called "SonarWorks Reference". I ended up liking that because there's a much wider variety of headphone profile options in SW (eg - they specifically have the 6xx model, so I didn't need to compromise by using RP's 650 profile), plus, you don't have to pay a la carte for other sets of cans. I have a few that I use between home and my studio, and it's nice to be able to fire up whatever I need in SW. But the room simulation in RP, and the customizability, is far, far superior. Thus, the combo lends the most effective range of options.
Post by superwack on Mar 29, 2021 19:56:36 GMT -6
Oh wow, you just blew my mind! I have SW4 and am going to try this! So when you go RP > SW do you fully disable the RP correction and only use it for the room? Thanks so much for sharing There's actually a setting within RP that's meant for feeding into SW. It's a calibration profile called "SonarWorks Reference". I ended up liking that because there's a much wider variety of headphone profile options in SW (eg - they specifically have the 6xx model, so I didn't need to compromise by using RP's 650 profile), plus, you don't have to pay a la carte for other sets of cans. I have a few that I use between home and my studio, and it's nice to be able to fire up whatever I need in SW. But the room simulation in RP, and the customizability, is far, far superior. Thus, the combo lends the most effective range of options. Is the SonarWorks a profile you have to choose as one of your “headphone models” when you download the demo? I can’t seem to find it as an option in the RealPhones plugin
Post by bgrotto on Apr 5, 2021 12:53:32 GMT -6
Yes, it’s a profile you gotta download from rp
Post by superwack on Apr 29, 2021 10:59:38 GMT -6
Bumping this to say that they have just released a new version of this with an "EASY" Mode with far less options to adjust (you can still use the old, advanced model) and also they are having a 45% off sale until 6/15 and offer a 41 day trial.
