Post by peterhess on Dec 10, 2020 16:48:33 GMT -6
Anybody heard one of these? I’m curious. Thanks!
Post by gravesnumber9 on Jun 11, 2021 14:48:33 GMT -6
Anybody heard one of these? I’m curious. Thanks! Bumping this. Anyone heard one? Two channel FET for $500 sounds appealing. Trash or treasure?
Post by NoTomorrow on Jun 11, 2021 15:10:19 GMT -6
I'm interested in this as well.... I almost pulled the trigger last week.
I like the dual mono/stereo functionality and also the +/- output gain, so I can use it to gain stage into Colour modules (which are very sensitive to input levels) and then use my SSL Fusion on the other side to gain it back up pre-converter if need be.
Post by gravesnumber9 on Jun 11, 2021 17:03:43 GMT -6
I'm interested in this as well.... I almost pulled the trigger last week. I like the dual mono/stereo functionality and also the +/- output gain, so I can use it to gain stage into Colour modules (which are very sensitive to input levels) and then use my SSL Fusion on the other side to gain it back up pre-converter if need be. I have some pretty similar uses in mind. By the way, is the the worst name for a piece of gear ever or is it just me?
Post by ragan on Jun 11, 2021 17:07:57 GMT -6
I listened to a couple clips, sounds pretty cool.
And yeah, really dumb name.
Post by NoTomorrow on Jun 11, 2021 19:23:49 GMT -6
Yea, the name.... ugh
Post by mcirish on Jun 12, 2021 6:49:40 GMT -6
I was thinking of picking up a Daking get. This would be a lot less expensive if it sounds good. Its hard to justify a hardware compressor for my uses. Typically, I don't compress or EQ on the way in. My home studio is a single 20x20 room so I have be separate control room.
Post by gravesnumber9 on Jun 12, 2021 8:31:09 GMT -6
I was thinking of picking up a Daking get. This would be a lot less expensive if it sounds good. Its hard to justify a hardware compressor for my uses. Typically, I don't compress or EQ on the way in. My home studio is a single 20x20 room so I have be separate control room. I’m getting into using hardware on my busses but I still want versatility. So stereo compressors that can do dual mono are very interesting in my case.
Post by prene1 on Jun 12, 2021 11:01:40 GMT -6
I have one. I use it. It’s cool.
Post by gravesnumber9 on Jun 12, 2021 12:29:38 GMT -6
I have one. I use it. It’s cool. I’ve seen some of your other posts, looks like you’ve got some other hardware FET compressors. Where would you say the TransY fits in that world?
Post by Ward on Jun 15, 2021 11:28:13 GMT -6
The thing about ART . . . what's the best thing I can say? Hmmm . . .
They make a lovely channel strip suitable for talkback mic purposes.
Post by prene1 on Jun 22, 2021 19:49:41 GMT -6
I have one. I use it. It’s cool. I’ve seen some of your other posts, looks like you’ve got some other hardware FET compressors. Where would you say the TransY fits in that world? I use them on background vox ALOT.
