Post by Quint on Nov 16, 2020 18:17:20 GMT -6
It reads more like they're caving to pressure, rather than following working policies. Again, most of europe imposed draconian lockdowns, some of the countries just barely getting out of the first one at this point, only to see logarithmic increases in cases again. Yet Sweden did no such thing and even if their cases are rising, the result would be the same as those who did lockdown. Their numbers in Sweden are spiking and they're going to make a policy shift because of it. I read it as simple as that. I think it's pretty simple. Keeping (or forcing) people apart from one another will reduce or eliminate avenues of infection. That's an easily understandable fact, not requiring any sort of study. If you're not around anyone who is infected, you won't get infected yourself. If you're around less people than usual, you stand to have less of a chance of getting infected, all other variables being kept the same. If you go on as normal, yeah, you're more likely to get infected. So, if "lockdowns" have been implemented, but infection numbers haven't moved in the intended direction, that's an indictment of poor adherence and/or lax enforcement, not of the concept of a lockdown itself.
Post by svart on Nov 16, 2020 18:23:20 GMT -6
It reads more like they're caving to pressure, rather than following working policies. Again, most of europe imposed draconian lockdowns, some of the countries just barely getting out of the first one at this point, only to see logarithmic increases in cases again. Yet Sweden did no such thing and even if their cases are rising, the result would be the same as those who did lockdown. Their numbers in Sweden are spiking and they're going to make a policy shift because of it. I read it as simple as that. I think it's pretty simple. Keeping (or forcing) people apart from one another will reduce or eliminate avenues of infection. That's an easily understandable fact, not requiring any sort of study. If you're not around anyone who is infected, you won't get infected yourself. So, if "lockdowns" have been implemented, but infection numbers haven't moved in the intended direction, that's an indictment of poor adherence and/or lax enforcement, not of the concept of a lockdown itself. So if high numbers are indicative of people not adhering to lockdowns, then they must be absolutely partying in the streets.. oh wait. I digress. I'd believe small upticks were from some non-social distancing, but not massive numbers. But then again, if masks worked we'd not need the lockdowns. People see what they want in all this, that it's as simple as wearing a mask and everyone is safe and everything will be fine. Same for lockdowns, they want to believe that their suffering is for a greater good. The data says that neither is true because nothing works against something that is biologically evolved to do exactly the thing it's doing.
Post by Quint on Nov 16, 2020 18:39:10 GMT -6
Their numbers in Sweden are spiking and they're going to make a policy shift because of it. I read it as simple as that. I think it's pretty simple. Keeping (or forcing) people apart from one another will reduce or eliminate avenues of infection. That's an easily understandable fact, not requiring any sort of study. If you're not around anyone who is infected, you won't get infected yourself. So, if "lockdowns" have been implemented, but infection numbers haven't moved in the intended direction, that's an indictment of poor adherence and/or lax enforcement, not of the concept of a lockdown itself. So if high numbers are indicative of people not adhering to lockdowns, then they must be absolutely partying in the streets.. I'd believe small upticks were from some non-social distancing, but not massive numbers. But then again, if masks worked we'd not need the lockdowns. It's a combination of all the above. Lax mask usage. Lax social distancing. Lax adherence to lockdown protocols. It's unknowable, at least certainly at this point, how much each factor has played a role in spikes in different locations but it is a fact that 100% separation of all people from all other people would effectively kill the virus in it's tracks. Conversely, public interactions as usual would allow many avenues of infection and allow the virus to flourish. It isn't practically possible for a lockdown to achieve the former scenario of 100% isolation (at least not without VERY draconian measures), but neither is the latter scenario of business as usual a reasonable approach to take. SOME attempt should be made to keep people separated, and that is what these lockdowns have attempted to do, albeit done in a poorly implemented and adhered to fashion in a lot of places. It sounds hyperbolic to say that it's necessary that "people must be partying in the streets", otherwise anything less must just mean that lockdowns don't work. Here's the thing. I can't speak for other parts of the world, but I can tell you what I see in places all over the US, and here in Texas: PEOPLE PARTYING IN THE STREETS. Literally! Again, don't fault the concept of a lockdown. Fault those who aren't enforcing it. Fault those who slow walk their implementation. Fault those who aren't adhering to it. Lockdowns work if you're willing to actually do them correctly. Biological imperative of the virus or not, one person can't catch Covid from another person if they're not around them for it to happen. Eliminate enough of those interactions and you can make a real difference. Screw around with it like we've done in the US and you'll get the result were facing now.
Post by svart on Nov 16, 2020 18:59:12 GMT -6
So if high numbers are indicative of people not adhering to lockdowns, then they must be absolutely partying in the streets.. I'd believe small upticks were from some non-social distancing, but not massive numbers. But then again, if masks worked we'd not need the lockdowns. It's a combination of all the above. Lax mask usage. Lax social distancing. Lax adherence to lockdown protocols. It's unknowable, at least certainly at this point, how much each factor has played a role in spikes in different locations but it is a fact that 100% separation of all people from all other people would effectively kill the virus in it's tracks. Conversely, public interactions as usual would allow many avenues of infection and allow the virus to flourish. It isn't practically possible for a lockdown to achieve the former scenario, but neither is the latter scenario a reasonable approach to take. SOME attempt should be made to keep people separated, and that is what these lockdowns have attempted to do, albeit done in a poorly implemented and adhered to fashion in a lot of places. It sounds hyperbolic to say that it's necessary that "people must be partying in the streets", otherwise anything less must just mean that lockdowns don't work. Here's the thing. I can't speak for other parts of the world, but I can tell you what I see in places all over the US, and here in Texas: PEOPLE PARTYING IN THE STREETS. Literally! Again, don't fault the concept of a lockdown. Fault those who aren't enforcing it. Fault those who slow walk there implementation. Fault those who aren't adhering to it. Lockdowns work if you're willing to actually do them correctly. I was being a bit sarcastic with the partying thing since there had been the large numbers of folks in the streets for reasons and most of those were folks were the same lamenting our leadership, although our government response was similar in overall scope and breadth to the average of other countries. It seems that this would be a case of impossible implementation, and any subsequent failure would be blamed on "lax" something or other. 70% adherence would fail and someone would say it needed to be 75%, 99% needed to be 100%, etc. But we've heard this before during the beginning of the last wave of cases that didn't result in deaths too. I see no reason to expect this wave to be different.
Post by Quint on Nov 16, 2020 19:13:53 GMT -6
It's a combination of all the above. Lax mask usage. Lax social distancing. Lax adherence to lockdown protocols. It's unknowable, at least certainly at this point, how much each factor has played a role in spikes in different locations but it is a fact that 100% separation of all people from all other people would effectively kill the virus in it's tracks. Conversely, public interactions as usual would allow many avenues of infection and allow the virus to flourish. It isn't practically possible for a lockdown to achieve the former scenario, but neither is the latter scenario a reasonable approach to take. SOME attempt should be made to keep people separated, and that is what these lockdowns have attempted to do, albeit done in a poorly implemented and adhered to fashion in a lot of places. It sounds hyperbolic to say that it's necessary that "people must be partying in the streets", otherwise anything less must just mean that lockdowns don't work. Here's the thing. I can't speak for other parts of the world, but I can tell you what I see in places all over the US, and here in Texas: PEOPLE PARTYING IN THE STREETS. Literally! Again, don't fault the concept of a lockdown. Fault those who aren't enforcing it. Fault those who slow walk there implementation. Fault those who aren't adhering to it. Lockdowns work if you're willing to actually do them correctly. I was being a bit sarcastic with the partying thing since there had been the large numbers of folks in the streets for reasons and most of those were folks were the same lamenting our leadership, although our government response was similar in overall scope and breadth to the average of other countries. It seems that this would be a case of impossible implementation, and any subsequent failure would be blamed on "lax" something or other. 70% adherence would fail and someone would say it needed to be 75%, 99% needed to be 100%, etc. But we've heard this before during the beginning of the last wave of cases that didn't result in deaths too. I see no reason to expect this wave to be different. Though I might disagree, I could at least give some plausibility to the notion that no lockdown could ever be locked down enough. If yours is an argument of absolute impracticality, short of a "violators will be shot on sight scenario", that would at least hold some plausible water, though it would lead to another discussion about just how bad a theoretical virus "X" would have to be to warrant such drastic measures. My understanding was that you were saying no lockdown could ever work, period. My contention is that I think they can work and have. Take ebola, for example. Drastic lockdown measures have previously been taken to stop its spread and they HAVE worked. This is not to say that I think Covid is as severe a problem as Ebola and I'm not advocating for those sort of Ebola level lockdowns here. I'm just pointing out that lockdowns can be effective, if done correctly. It's just a matter of how seriously we take Covid, how drastic the measures would have to be to make a real dent, and whether or not those corresponding measures are deemed proportionally practical. But that's another discussion. Bottom line, I don't think we need such drastic measures to still make a real dent. I think that, at least for starters, simple enforcement of the rules we already have would get us a long way down the road. Sure, at some point a discussion about "the cure might be worse than the disease" might be warranted if ever more draconian measures appeared to be needed. But I don't believe that we're anywhere near that yet. So, you previously mentioned that you weren't against "doing something". If not lockdowns and mask and social distancing, what would be your alternative?
Post by svart on Nov 16, 2020 19:44:10 GMT -6
I was being a bit sarcastic with the partying thing since there had been the large numbers of folks in the streets for reasons and most of those were folks were the same lamenting our leadership, although our government response was similar in overall scope and breadth to the average of other countries. It seems that this would be a case of impossible implementation, and any subsequent failure would be blamed on "lax" something or other. 70% adherence would fail and someone would say it needed to be 75%, 99% needed to be 100%, etc. But we've heard this before during the beginning of the last wave of cases that didn't result in deaths too. I see no reason to expect this wave to be different. Though I might disagree, I could at least give some plausibility to the notion that no lockdown could ever be locked down enough. If yours is an argument of absolute impracticality, short of a "violators will be shot on sight scenario", that would at least hold some plausible water, though it would lead to another discussion about just how bad a theoretical virus "X" would have to be to warrant such drastic measures. My understanding was that you were saying no lockdown could ever work, period. My contention is that I think they can work and have. Take ebola, for example. Drastic lockdown measures have previously been taken to stop its spread and they HAVE worked. This is not to say that I think Covid is as severe a problem as Ebola and I'm not advocating for those sort of Ebola level lockdowns here. I'm just pointing out that lockdowns can be effective, if done correctly. It's just a matter of whether or not we think Covid is a serious enough matter to warrant lockdowns to that degree. But that's another discussion. So, you previously mentioned that you weren't against "doing something". If not lockdowns and mask and social distancing, what would be your alternative? First, I really appreciate the civility of this discussion. We might not agree on the methods, but I know we both agree that this virus is a travesty. But to your point, it's hard to say. I'd rather follow the data, but data is changing by the minute and certainly by whom collects it. A line must be drawn between personal freedom and overreaching policy too. A test-and-certify approach might be useful but being denied entry into businesses or similar locations sure to lack of "certification" reeks of HIPAA violations at best or 80's HIV stigma at worst, or can even cross gender/race lines. People balk at needing an ID to vote, just wait until they need a license to walk into a store.. Lockdowns affect everyone to some degree, even those at least risk of death or serious illness. They disproportionately affect the poor who need to work and at no point in history has government been able to handle resolving poverty, so it's surely not going to get fixed in a few weeks at this point. The only approach that at least tries to handle this situation with some equity is sheltering those that are at high risk, providing those with the necessary support and shielding them and their caregivers. We should figure out which rapid test has the lowest error rate and provide increased availability of it, also including the bias of ethnicity since in my area there is a lot of diverse ethnicity and a lot of people are very wary of government backed "testing". A doctor I know noted that as a free testing center, his clinic actually saw a decrease in patients, and one claimed that they had been told it was a way for government to find them for deportation. Luckily, my state, georgia, took a fairly big wave early on and had since enjoyed a very low case rate with most cases now being the locations that were geographically isolated, like the mountainous towns.
Post by svart on Nov 16, 2020 20:13:48 GMT -6
Also this.
Post by EmRR on Nov 17, 2020 0:16:33 GMT -6
I tend to think lockdowns work to reduce spread, and what we see in rising cases is the distributed timing of the end of lockdown, when a high enough percentage return to life as normal, all caution to the wind. Even in multi-tiered micro-lockdowns, the UK has a constant problem with illegal raves and street parties ignoring all advice - then those people blend back in to the general population. The UK population with any money to spend (or a package vacation they couldn’t cancel) appear to have all gone to the beaches in Portugal/Spain/Croatia as soon as they were allowed, and seeded the next wave quite well. It’s not just UK behavior, it’s general human behavior. A lockdown slows and flattens a peak, it’s never going to make it go away completely, it kicks future cases further down the road, which has great value from a medical patient load perspective. So many unknowns; i know people who’ve died, people who’ve been pretty ill, people who’ve had emergency room visits weeks after ‘recovering’, and two entire families in which one person in the house had it and 4-6 others never got it. None of it makes any sense yet. A quick glance suggests 3.75 million US births/year, 2.8 million deaths/year. What will the excess death percentage for the year appear to be? It seems significant, with 6 weeks to go, apparently heading into the biggest peak yet.
Post by Deleted on Nov 17, 2020 8:38:33 GMT -6
We refuse to apply the stick. $250 dollar fines is nothing for mask violators and it’s never applied. How about $2500 or jail time first violation? $5000 afterwards? You have to be draconian and mean it. Urban police departments have a limited quotas of people they’re allowed to arrest where I am mandated by corrupt and pandering politicians. They let illegal gun offenders out on nothing bails to go commit the crimes they had the illegal guns to commit. If people at illegal raves and parties were forced into house arrest on first offense and if they break it or offend again, get sent to go behind barbed wire for two to three weeks, they would obey the mandates. Make them live in a tent in the park like a hobo.
Post by Deleted on Nov 17, 2020 8:46:58 GMT -6
Though I might disagree, I could at least give some plausibility to the notion that no lockdown could ever be locked down enough. If yours is an argument of absolute impracticality, short of a "violators will be shot on sight scenario", that would at least hold some plausible water, though it would lead to another discussion about just how bad a theoretical virus "X" would have to be to warrant such drastic measures. My understanding was that you were saying no lockdown could ever work, period. My contention is that I think they can work and have. Take ebola, for example. Drastic lockdown measures have previously been taken to stop its spread and they HAVE worked. This is not to say that I think Covid is as severe a problem as Ebola and I'm not advocating for those sort of Ebola level lockdowns here. I'm just pointing out that lockdowns can be effective, if done correctly. It's just a matter of whether or not we think Covid is a serious enough matter to warrant lockdowns to that degree. But that's another discussion. So, you previously mentioned that you weren't against "doing something". If not lockdowns and mask and social distancing, what would be your alternative? First, I really appreciate the civility of this discussion. We might not agree on the methods, but I know we both agree that this virus is a travesty. But to your point, it's hard to say. I'd rather follow the data, but data is changing by the minute and certainly by whom collects it. A line must be drawn between personal freedom and overreaching policy too. A test-and-certify approach might be useful but being denied entry into businesses or similar locations sure to lack of "certification" reeks of HIPAA violations at best or 80's HIV stigma at worst, or can even cross gender/race lines. People balk at needing an ID to vote, just wait until they need a license to walk into a store.. Lockdowns affect everyone to some degree, even those at least risk of death or serious illness. They disproportionately affect the poor who need to work and at no point in history has government been able to handle resolving poverty, so it's surely not going to get fixed in a few weeks at this point. The only approach that at least tries to handle this situation with some equity is sheltering those that are at high risk, providing those with the necessary support and shielding them and their caregivers. We should figure out which rapid test has the lowest error rate and provide increased availability of it, also including the bias of ethnicity since in my area there is a lot of diverse ethnicity and a lot of people are very wary of government backed "testing". A doctor I know noted that as a free testing center, his clinic actually saw a decrease in patients, and one claimed that they had been told it was a way for government to find them for deportation. Luckily, my state, georgia, took a fairly big wave early on and had since enjoyed a very low case rate with most cases now being the locations that were geographically isolated, like the mountainous towns. Instead of protecting the elderly, retards like Cuomo and De Blasio moved covid patients into nursing homes killing them. They passed laws during epidemic to shield nursing homes and themselves from lawsuits. I doubt any of that will hold up. Post pandemic, their operators and the states will be facing billions in wrongful death lawsuits. then again we live in a country that let the Sacklers keep their wealth instead of letting them starve on the street with the junkies they created.
Post by Ward on Nov 17, 2020 12:58:48 GMT -6
It reads more like they're caving to pressure, rather than following working policies. Again, most of europe imposed draconian lockdowns, some of the countries just barely getting out of the first one at this point, only to see logarithmic increases in cases again. Yet Sweden did no such thing and even if their cases are rising, the result would be the same as those who did lockdown. Svart, you appear to almost be alone but you are not! You have written 4 or 5 of the most eloquent replies in this thread and show common sense, deductive reasoning but also consideration for others. . . whilst not receiving the same consideration in return. Well done, my man, well done.
Post by svart on Nov 17, 2020 13:19:55 GMT -6
It reads more like they're caving to pressure, rather than following working policies. Again, most of europe imposed draconian lockdowns, some of the countries just barely getting out of the first one at this point, only to see logarithmic increases in cases again. Yet Sweden did no such thing and even if their cases are rising, the result would be the same as those who did lockdown. Svart, you appear to almost be alone but you are not! You have written 4 or 5 of the most eloquent replies in this thread and show common sense, deductive reasoning but also consideration for others. . . whilst not receiving the same consideration in return. Well done, my man, well done. Thanks. I know it's a hot topic and I know that because it is, it's hard to have a discussion that doesn't include feelings and desires. I understand that people want to believe that the government can and is doing something about all this because they personally feel powerless to change anything and need the comfort of belief in a greater power. I know it also drives folks to grasp at virtual straws and become emotionally invested in overly simple takes, like "if only we did X, things would be fixed". However, as a person of science I feel like I have to divorce the feelings and the desires and let the data drive the direction. Right now, the raw data says that there isn't anything we can do to "fix" this now besides shelter who we can and let immune systems do what they've evolved to do in the rest that have a low chance of mortality. Lockdowns create a LOT of pain, disproportionately for poor people, and they do little but stymie infection rates for short periods which is evident in every single country that had rigorous lockdowns yet are experiencing subsequent waves of infections. Arguments can be made for the percentage of adherence, but overall the aggregate result is that they do not work no matter who's tried them or how severe they were for COVID or actually for any of the related SARS/MERS waves we've had in the past few decades. Some of the top scientists in the world have seen these come and go and they always follow similar evolutionary cycles. The initial fear for covid was that it would be different, but it's followed textbook patterns. it just seems worse because the scope now encompasses more regions than before.
Post by Ward on Nov 17, 2020 13:40:14 GMT -6
svart, another little piece of 'science' that makes quite a few people upset and causes disbelief in what they feel is government propaganda and cover-up: Since COVID-19, it's like the regular seasonal Influenza has been completely cured. We know this is not the case, and we deduce that all seasonal flu, cold, pneumonia and in general all pneumonic disease has been labeled Covid-19. This amplifies the problem and creates with it new panic, hysteria and even mental illness. The toll this has taken on vulnerable people and children is immense and no one has even been begun to be measure yet. Musings.
Post by drbill on Nov 17, 2020 14:07:15 GMT -6
We refuse to apply the stick. $250 dollar fines is nothing for mask violators and it’s never applied. How about $2500 or jail time first violation? $5000 afterwards? You have to be draconian and mean it. No thanks. There are no guarantees in life. You can't mandate health or well being. If you are alive, you're taking a risk. Trump is not responsible if I get Covid. Biden cannot stop me from contracting Covid. The government is not responsible for my personal health. I'm the only one who can take measures to protect myself. Did we all forget that? I'd rather not live in the type of world that your reasoning implies. No offense.
Post by Ward on Nov 17, 2020 15:04:04 GMT -6
We refuse to apply the stick. $250 dollar fines is nothing for mask violators and it’s never applied. How about $2500 or jail time first violation? $5000 afterwards? You have to be draconian and mean it. No thanks. There are no guarantees in life. You can't mandate health or well being. If you are alive, you're taking a risk. Trump is not responsible if I get Covid. Biden cannot stop me from contracting Covid. The government is not responsible for my personal health. I'm the only one who can take measures to protect myself. Did we all forget that? I'd rather not live in the type of world that your reasoning implies. No offense. Makes perfect sense to me. We are responsible for ourselves. God forbid we live in a molly-coddled welfare state.
Post by Tbone81 on Nov 17, 2020 15:14:04 GMT -6
Of the studies I know of, the one thing that has continually proven to prevent infections is hand washing. All other measures are pretty disappointing. Masks can definitely help too, but when they’re utilized the way we are using them, their effectiveness is pretty poor. Again, according to the studies I’ve seen.
Post by Quint on Nov 17, 2020 16:26:14 GMT -6
Well, as Svart mentioned, this HAD been a civil conversation until Ward felt the need to come in and start throwing bombs ("whilst not receiving the same consideration in return") and riding the coattails of other's arguments he is either unwilling to or incapable of making himself, all while doing it in his usual passive aggressive manner...
Svart and I were having a perfectly civil conversation. I'd like to keep it that way. Thanks.
Post by Quint on Nov 17, 2020 16:44:50 GMT -6
Though I might disagree, I could at least give some plausibility to the notion that no lockdown could ever be locked down enough. If yours is an argument of absolute impracticality, short of a "violators will be shot on sight scenario", that would at least hold some plausible water, though it would lead to another discussion about just how bad a theoretical virus "X" would have to be to warrant such drastic measures. My understanding was that you were saying no lockdown could ever work, period. My contention is that I think they can work and have. Take ebola, for example. Drastic lockdown measures have previously been taken to stop its spread and they HAVE worked. This is not to say that I think Covid is as severe a problem as Ebola and I'm not advocating for those sort of Ebola level lockdowns here. I'm just pointing out that lockdowns can be effective, if done correctly. It's just a matter of whether or not we think Covid is a serious enough matter to warrant lockdowns to that degree. But that's another discussion. So, you previously mentioned that you weren't against "doing something". If not lockdowns and mask and social distancing, what would be your alternative? First, I really appreciate the civility of this discussion. We might not agree on the methods, but I know we both agree that this virus is a travesty. But to your point, it's hard to say. I'd rather follow the data, but data is changing by the minute and certainly by whom collects it. A line must be drawn between personal freedom and overreaching policy too. A test-and-certify approach might be useful but being denied entry into businesses or similar locations sure to lack of "certification" reeks of HIPAA violations at best or 80's HIV stigma at worst, or can even cross gender/race lines. People balk at needing an ID to vote, just wait until they need a license to walk into a store.. Lockdowns affect everyone to some degree, even those at least risk of death or serious illness. They disproportionately affect the poor who need to work and at no point in history has government been able to handle resolving poverty, so it's surely not going to get fixed in a few weeks at this point. The only approach that at least tries to handle this situation with some equity is sheltering those that are at high risk, providing those with the necessary support and shielding them and their caregivers. We should figure out which rapid test has the lowest error rate and provide increased availability of it, also including the bias of ethnicity since in my area there is a lot of diverse ethnicity and a lot of people are very wary of government backed "testing". A doctor I know noted that as a free testing center, his clinic actually saw a decrease in patients, and one claimed that they had been told it was a way for government to find them for deportation. Luckily, my state, georgia, took a fairly big wave early on and had since enjoyed a very low case rate with most cases now being the locations that were geographically isolated, like the mountainous towns. I agree. I've also appreciated the civil discourse you and I've had. As is always the case when it comes to this sort of thing, social cost and tradeoffs are at the heart of the discussion. I'm generally with you on the personal freedom thing, though I would point out that we already make similar tradeoffs in other areas of our life with things like enforced speed limits on highways. The cost is that we can't all drive as fast as we possibly can, but that comes with the benefit that we aren't dying at much higher rates due to many more fatal wrecks. The public is generally supportive of this trade-off. In a nutshell I'm just simply pointing out that we don't live in a world where either end (absolute freedom versus absolute safety) of the the scale applies. It's a sliding scale so, in the end, it just comes down to where that sweet spot between the two lies. In my opinion, at this point, we are about in the sweet spot as far as lockdowns, masks, etc. are concerned. I would just like to see them actually enforced. The issue with rapid testing as a substitute for lockdowns and mask is that, as you pointed out, they can often provide false negatives. So now we're back in the same boat of people having a false sense of security. At least with masks and lockdowns, you are eliminating some of the potential avenues of transmission, regardless of who is or isn't positive and who does or doesn't know about it, again assuming that these policies are actually enforced. In a perfect world, I think I would tend to agree with you on the testing being a better avenue. But there are just too many false negatives with our current testing methods, unfortunately. And, as you pointed out, it's also difficult to know who is actually negative, not to mention the civil liberty concerns. Just of note though, I would add that we similarly enforce proof of vaccination for kids to go to school. It's not an unprecedented concept or something that is complete anathema to the public, at large. What frustrates me the most about all of this is that, as a society, I'm fine with having these sort of cost to benefit analysis conversations, provided that we are all intellectually honest with one another about where the goal posts lie and what the parameters are. The problem is that we (our society, not you and I) are not having an apples to apples comparison when science is villified by certain groups just because it doesn't fit their narrative. I say we all follow the facts and take them where it leads us. However, 8kun and Qanon are not arbiters of peer reviewed science, last time I checked. Svart, from what I can tell, I think you and I have a similar understanding of the scientific method and can probably agree on a lot.
Post by johneppstein on Nov 17, 2020 17:19:01 GMT -6
Their numbers in Sweden are spiking and they're going to make a policy shift because of it. I read it as simple as that. I think it's pretty simple. Keeping (or forcing) people apart from one another will reduce or eliminate avenues of infection. That's an easily understandable fact, not requiring any sort of study. If you're not around anyone who is infected, you won't get infected yourself. So, if "lockdowns" have been implemented, but infection numbers haven't moved in the intended direction, that's an indictment of poor adherence and/or lax enforcement, not of the concept of a lockdown itself. So if high numbers are indicative of people not adhering to lockdowns, then they must be absolutely partying in the streets.. oh wait. I digress. I'd believe small upticks were from some non-social distancing, but not massive numbers. But then again, if masks worked we'd not need the lockdowns. People see what they want in all this, that it's as simple as wearing a mask and everyone is safe and everything will be fine. Same for lockdowns, they want to believe that their suffering is for a greater good. The data says that neither is true because nothing works against something that is biologically evolved to do exactly the thing it's doing. Massive numbers are caused by massive public gatherings with essentially zero concern for protection.
I don't understand why this is so difficult for some people to comprehend.
As I keep having to point out, California is a living example. In the south people have been largely ignoring state mandated protections and the virus is surging. In the North compliance is MUCH greater and the virus is more or less flat.
Nothing works when people are so totally pigheaded that they refuse to protect themselves. And others.
Post by Ward on Nov 17, 2020 21:10:28 GMT -6
Post by johneppstein on Nov 17, 2020 21:56:49 GMT -6
As I keep having to point out, California is a living example. In the south people have been largely ignoring state mandated protections and the virus is surging. In the North compliance is MUCH greater and the virus is more or less flat. [/div] Nothing works when people are so totally pigheaded that they refuse to protect themselves. And others.
[/quote] You mean places like Portland? St. Louis? NYC? DC? Chicago? Democrat cities where they are being looted and burned down by 'protestors'? It's almost as if they think protesting is the cure for COVID19. But I might be mistaken in my observations . . . and perhaps all those cities aren't protesting after all. It always amazes me how dangerous a church service is compared to 50,000 people shoulder to shoulder, peacefully celebrating the overthrow of a president. But I digress . . . www.axios.com/riots-cost-property-damage-276c9bcc-a455-4067-b06a-66f9db4cea9c.htmlwww.newsbreak.com/news/2061916952025/nolte-blm-riots-are-officially-the-most-costly-manmade-damage-to-american-property-in-history[/quote][/div]
You can't be serious.
That's all propoganda, as I'm sure you're well aware.
The "protesters" causing all the trouble in those areas are out of state right-wing militia members and the like being bussed in to cause trouble.
BLM protesters don't carry arms. Right wing neo-nazis do - and they use them.
You need to lay off the "Kool-Aide".
And, of course, you deliberately misconstrued and took out of context my statement. However, if you really need clarification, my statement "Nothing works when people are so totally pigheaded that they refuse to protect themselves. And others." referred to people who are too stupid to protect themselves by wearing masks and not congregating in massive herds without proper protection. When you do that no amount of mandates on masks and social distancing will help, because it's impossible to help people who are too stupid to help themselves.
The mandates work. Northern Cal is living proof. And Southern Cal is, unfortunately, the control group.
Post by drbill on Nov 17, 2020 22:22:24 GMT -6
BLM protesters don't carry arms. Right wing neo-nazis do - and they use them.[/quote][/b][/i] You're right - BLM protesters (many) don't carry arms. But they do seem to carry bricks and have been prone to burn out businesses in many cities across the country. To call them right wing militia is a joke. I think maybe it's YOU who have been drinking the kool aide. When BLM protestors were bussed into our small town from 100+ miles away, they were met by my NEIGHBORS - none of whom are Neo-nazi's - just peace loving folks who believe in justice, and a fair and very conspicuous police force. My neighbors do happen to be gun carrying 2nd amendment enthusiasts, and since we are a concealed carry and open carry state - they were perfectly legal and within their rights to show up fully strapped and loaded alongside the protesters. Guess what? Officers had very little to do. The BLM folks could see the resolve and essentially backed off their agenda. Unlike so many other states and cities that burned with lack of police or a legally armed populace, they became a HUGE deterrent against the planned vandalizing and looting. What was set up by outside our town forces for burning and chaos ended up essentially a standoff. Both sides made their message very well known. Not a shot was fired or a brick thrown, and to my knowledge, no one got arrested. To call those armed folks "Neo-nazi's" is an insult to my neighbors, my town, and the country that I love. Don't paint everyone with the same nazi brush John.
Post by Blackdawg on Nov 18, 2020 0:18:03 GMT -6
I think you all need to stop drinking the koolaid from both sides personally.
Post by Ward on Nov 18, 2020 6:13:31 GMT -6
I think you all need to stop drinking the koolaid from both sides personally Ok, then give us the distilled non-kool-aid version of the facts please. Clearly you do think it is, so I (for one) welcome your input. And as much as my stance is 180º different to John's, I respect any contrary POV.
Post by Ward on Nov 18, 2020 6:23:11 GMT -6
Just a couple of points you may have missed, johneppstein Haven't you noticed, those who are hysterical about the spread of CV19, raise no warnings about group gatherings when it suits their political agenda? Here I point out that I am human, fallable, and may be mistaken . . . and maybe the legions of doom have risen from the dead. I don't know. I'm sick of propaganda as well. And here: I offer both an EXTREME LEFT-WING (first) and a CENTER-RIGHT take on things, for balance.
