Post by kcatthedog on Oct 6, 2020 10:18:27 GMT -6
Mastering and tracking converters: nice!
Post by seawell on Oct 6, 2020 12:35:11 GMT -6
$3999 is steep but when you consider tracking through it, the analog limiter, the transformer options and using it as a master clock it would very well be worth it and replace several pieces of gear.
Post by Johnkenn on Oct 6, 2020 12:38:35 GMT -6
Well...that's expensive...but could be what a lot of people have been looking for.
Post by kcatthedog on Oct 6, 2020 12:46:45 GMT -6
Depends how you see it: mastering grade ad/da are an easy 2 grand, plus you have limiting, transformers and the Neve silk and other options?
Neve MBC
Oct 6, 2020 13:04:01 GMT -6
via mobile
Post by Deleted on Oct 6, 2020 13:04:01 GMT -6
This could be amazing. The only bad RND piece so far was the headphone amplifier.
Neve MBC
Oct 6, 2020 13:12:18 GMT -6
via mobile
Post by kcatthedog on Oct 6, 2020 13:12:18 GMT -6
I’m impressed !
Neve MBC
Oct 6, 2020 14:01:52 GMT -6
via mobile
Post by Johnkenn on Oct 6, 2020 14:01:52 GMT -6
Depends how you see it: mastering grade ad/da are an easy 2 grand, plus you have limiting, transformers and the Neve silk and other options? It’s a DA too?
Neve MBC
Oct 6, 2020 14:14:38 GMT -6
via mobile
Post by kcatthedog on Oct 6, 2020 14:14:38 GMT -6
Yup!
Post by kcatthedog on Oct 6, 2020 14:22:41 GMT -6
Side chain on the limiting too, he demonstrates that with the snare in one of the mixes, you can set the freq and the amount of limiting : heat and see it in the Leds!
Neve MBC
Oct 6, 2020 14:26:22 GMT -6
via mobile
Post by seawell on Oct 6, 2020 14:26:22 GMT -6
Depends how you see it: mastering grade ad/da are an easy 2 grand, plus you have limiting, transformers and the Neve silk and other options? It’s a DA too? I think it’s A/D only. I don’t see any analog outputs.
Neve MBC
Oct 6, 2020 14:28:02 GMT -6
via mobile
Post by kcatthedog on Oct 6, 2020 14:28:02 GMT -6
Their language is a little unclear if it is AD only that back to agreeing with John’s first point: a little expensive ?
Post by Johnkenn on Oct 6, 2020 15:33:42 GMT -6
Yeah - it's AD only...paying for the limiter...I'm sure it's really good...but the Dangerous Convert 2 AD+ has a transformer emphasis thing and is $1500 less. From what I could tell, the Warren Huard examples sounded good...but I'm not sure it's a feature I really want on a converter.
Post by nomatic on Oct 6, 2020 17:18:08 GMT -6
Gonna Get one I fear......
Post by ericn on Oct 6, 2020 17:34:42 GMT -6
Yeah - it's AD only...paying for the limiter...I'm sure it's really good...but the Dangerous Convert 2 AD+ has a transformer emphasis thing and is $1500 less. From what I could tell, the Warren Huard examples sounded good...but I'm not sure it's a feature I really want on a converter. But it doesn’t say NEVE!!! Have I taught you nothing😁 OK I admit my phone autocorrects never to Neve, but I’ll pass on this one. For the $ could probably buy a Mytek AD, a bunch of different transformer pairs and a decent limiter.
Post by guitfiddler on Oct 6, 2020 18:06:59 GMT -6
I was hoping it wasn’t that expensive
Post by peterhess on Oct 7, 2020 16:59:32 GMT -6
Ticks a lot of boxes for me, truth be told, since I’ve been thinking about better conversion anyhow... if the limiter is a little luscious, I might be even more trigger happy. Hmm.
Post by roundbadge on Oct 10, 2020 5:05:18 GMT -6
looks cool.gotta compare it to my AD+ sometime. agree with John.. $1500 more hmm..better be really great.
Neve MBC
Oct 10, 2020 7:50:28 GMT -6
via mobile
Post by nick8801 on Oct 10, 2020 7:50:28 GMT -6
This could be amazing. The only bad RND piece so far was the headphone amplifier. What don’t you like about the headphone amp? I have one and I really like it.
Neve MBC
Oct 10, 2020 9:40:10 GMT -6
via mobile
Post by Deleted on Oct 10, 2020 9:40:10 GMT -6
This could be amazing. The only bad RND piece so far was the headphone amplifier. What don’t you like about the headphone amp? I have one and I really like it. its too thin and overdamped. Plug a Sennheiser 600 or 650 into it and the low end is gone. It was worse than the headphone amps in a lot of higher end interfaces and the ones that cost about a hundred to two hundred from Schiit.
Neve MBC
Oct 10, 2020 16:58:24 GMT -6
via mobile
Post by nick8801 on Oct 10, 2020 16:58:24 GMT -6
What don’t you like about the headphone amp? I have one and I really like it. its too thin and overdamped. Plug a Sennheiser 600 or 650 into it and the low end is gone. It was worse than the headphone amps in a lot of higher end interfaces and the ones that cost about a hundred to two hundred from Schiit. I have not used it with any high end cans. Just my lowly krk’s. Definitely better than the Behringer headphone splitter I have!
Neve MBC
Oct 10, 2020 17:33:27 GMT -6
via mobile
Post by ericn on Oct 10, 2020 17:33:27 GMT -6
What don’t you like about the headphone amp? I have one and I really like it. its too thin and overdamped. Plug a Sennheiser 600 or 650 into it and the low end is gone. It was worse than the headphone amps in a lot of higher end interfaces and the ones that cost about a hundred to two hundred from Schiit. Matching headphone amps to various headphones is a PITA.
Post by Blackdawg on Oct 11, 2020 13:01:21 GMT -6
Looks awesome.
I kind of wish the word Mastering would stop getting thrown around so loosely though. No stepped controls so not as useable for mastering to me.
Still looks awesome.
Post by 79sg on Oct 11, 2020 15:58:18 GMT -6
Looks awesome. I kind of wish the word Mastering would stop getting thrown around so loosely though. No stepped controls so not as useable for mastering to me. Still looks awesome. Looks to be all stepped.
Post by Blackdawg on Oct 11, 2020 21:53:35 GMT -6
A detected potentiometer isn't quite the same. Nice. But not a stepped switch.
Post by johneppstein on Oct 11, 2020 23:41:12 GMT -6
detented?
