Post by jcoutu1 on Aug 14, 2020 20:10:25 GMT -6
Edit: Here is the final product.
I've got a session tomorrow for a live, in-studio production. Hired film crew is coming in to handle the video and I'm running the audio. 1 performer playing acoustic guitar, 1 female vocalist. I want to try being unobtrusive for the video production aspect, but want a great sound as well.
Pop act, not folky vibes.
I'm thinking of either a single or pair of BeesNeez SDC's close on the guitar and a Telefunken M80 for the vocal. I'll also have my usual Vanguard V44s set up across the room in mid-side.
Anything else that I should consider? I assume a LDC on the vocal will have bleed issues.
Also, I expect that they probably haven't spent much time rehearsing, so I'm not expecting them to blend their own volume well like a bluegrass band would.
Post by Johnkenn on Aug 14, 2020 20:17:39 GMT -6
Blumlein?
Post by jcoutu1 on Aug 14, 2020 21:37:24 GMT -6
Love the idea, but don't have a matched pair of multipattern mics, other than my ceiling mounted stereo mic. Also, worried about their voice/guitar balance.
Post by Johnkenn on Aug 14, 2020 21:52:35 GMT -6
I actually meant M/S...could you use it as a compliment to mix in to get a real stereo taste?
Post by Ward on Aug 15, 2020 6:10:57 GMT -6
The M80 is an excellent mic for the application you are describing. An LDC will have bleed but it can be pleasant and useful. Both U87s and U89s have beautiful off-axis sound like a KM84. The consideration here is how it looks on camera. Do you want it to look live performance or in-studio? If it's supposed to look in-studio, then use an LDC. What do you have on hand? Do you have your Heiserman H47 tube yet?
Post by jcoutu1 on Aug 15, 2020 7:24:42 GMT -6
I actually meant M/S...could you use it as a compliment to mix in to get a real stereo taste? I've got the m/s setup in the back of the room ready to go for capturing the realism.
Post by jcoutu1 on Aug 15, 2020 7:39:21 GMT -6
The M80 is an excellent mic for the application you are describing. An LDC will have bleed but it can be pleasant and useful. Both U87s and U89s have beautiful off-axis sound like a KM84. The consideration here is how it looks on camera. Do you want it to look live performance or in-studio? If it's supposed to look in-studio, then use an LDC. What do you have on hand? Do you have your Heiserman H47 tube yet? I've got a Flea47 and a BeesNeez Frank, that both look and sound rad, but are huge. I guess I could put a Samar ribbon close on the guitar and the BeesNeez in Fig8 close ish on the vocal and stick each performer in the null of the pattern.
Post by Ward on Aug 15, 2020 10:56:06 GMT -6
The M80 is an excellent mic for the application you are describing. An LDC will have bleed but it can be pleasant and useful. Both U87s and U89s have beautiful off-axis sound like a KM84. The consideration here is how it looks on camera. Do you want it to look live performance or in-studio? If it's supposed to look in-studio, then use an LDC. What do you have on hand? Do you have your Heiserman H47 tube yet? I've got a Flea47 and a BeesNeez Frank, that both look and sound rad, but are huge. I guess I could put a Samar ribbon close on the guitar and the BeesNeez in Fig8 close ish on the vocal and stick each performer in the null of the pattern. You know, that's a smashing idea!
Post by jcoutu1 on Aug 15, 2020 11:27:26 GMT -6
I've got a Flea47 and a BeesNeez Frank, that both look and sound rad, but are huge. I guess I could put a Samar ribbon close on the guitar and the BeesNeez in Fig8 close ish on the vocal and stick each performer in the null of the pattern. You know, that's a smashing idea! I wish mdmitch2 had gotten a pair of those Type19 mics in my hands already! #want #need #musthave
Post by Vincent R. on Aug 15, 2020 11:27:41 GMT -6
I've got a session tomorrow for a live, in-studio production. Hired film crew is coming in to handle the video and I'm running the audio. 1 performer playing acoustic guitar, 1 female vocalist. I want to try being unobtrusive for the video production aspect, but want a great sound as well. Pop act, not folky vibes. I'm thinking of either a single or pair of BeesNeez SDC's close on the guitar and a Telefunken M80 for the vocal. I'll also have my usual Vanguard V44s set up across the room in mid-side. Anything else that I should consider? I assume a LDC on the vocal will have bleed issues. Also, I expect that they probably haven't spent much time rehearsing, so I'm not expecting them to blend their own volume well like a bluegrass band would. The bleed is only an issue if the room is horrible, or if she can’t sing and will need tuning. You could do figure 8 on the vocal to really narrow the field and null the guitar. A good dynamic isn’t necessarily a bad idea though for something like this.
Post by jcoutu1 on Aug 15, 2020 11:31:58 GMT -6
I've got a session tomorrow for a live, in-studio production. Hired film crew is coming in to handle the video and I'm running the audio. 1 performer playing acoustic guitar, 1 female vocalist. I want to try being unobtrusive for the video production aspect, but want a great sound as well. Pop act, not folky vibes. I'm thinking of either a single or pair of BeesNeez SDC's close on the guitar and a Telefunken M80 for the vocal. I'll also have my usual Vanguard V44s set up across the room in mid-side. Anything else that I should consider? I assume a LDC on the vocal will have bleed issues. Also, I expect that they probably haven't spent much time rehearsing, so I'm not expecting them to blend their own volume well like a bluegrass band would. The bleed is only an issue if the room is horrible, or if she can’t sing and will need tuning. You could do figure 8 on the vocal to really narrow the field and null the guitar. A good dynamic isn’t necessarily a bad idea though for something like this. The biggest worry about bleed is her voice being too loud in the guitar mic.
Post by jcoutu1 on Aug 15, 2020 11:49:46 GMT -6
If anyone is interested, this is what we're recording. Her new EP just landed today and she is recording an acoustic version of the songs.
Post by drumsound on Aug 15, 2020 12:02:02 GMT -6
Since you don't have to worry about looking at the audience, don't assume they need to face the same direction. I've done things like this and put the performers at a 90º angle to one another. So one performer had a figure 8, and the other a cardioid to take advantage of the nulls.
Post by notneeson on Aug 15, 2020 12:16:28 GMT -6
I would either get a handle on the clients visual expectations or have multiple setups standing by, ranging from best sounding to least visually intrusive.
I would not be shocked to have a video crew show up in a recording studio still expecting to use shotguns and lavs. Then the question becomes: who has final say?
Post by Ward on Aug 15, 2020 19:54:45 GMT -6
You know, that's a smashing idea! I wish mdmitch2 had gotten a pair of those Type19 mics in my hands already! #want #need #musthave Ahem . . . wait your turn
Post by Vincent R. on Aug 15, 2020 20:50:38 GMT -6
The bleed is only an issue if the room is horrible, or if she can’t sing and will need tuning. You could do figure 8 on the vocal to really narrow the field and null the guitar. A good dynamic isn’t necessarily a bad idea though for something like this. The biggest worry about bleed is her voice being too loud in the guitar mic. Boy do I understand that. That’s definitely a tricky one.
Post by jcoutu1 on Aug 18, 2020 19:53:21 GMT -6
Post by jcoutu1 on Aug 29, 2020 8:05:28 GMT -6
Here's the final...
Post by Martin John Butler on Aug 29, 2020 9:16:21 GMT -6
The sound on the video is excellent, as good as it can be I think. The camera work is superb. Can't say I feel the same way about the music.
Post by Ward on Aug 30, 2020 6:42:25 GMT -6
The sound on the video is excellent, as good as it can be I think. The camera work is superb. Can't say I feel the same way about the music. I felt exactly the same way. The audio is stellar and I love her voice. Her singing voice. I would love to hear her sing something with much broader appeal.
Post by jcoutu1 on Aug 30, 2020 8:57:19 GMT -6
The sound on the video is excellent, as good as it can be I think. The camera work is superb. Can't say I feel the same way about the music. I felt exactly the same way. The audio is stellar and I love her voice. Her singing voice. I would love to hear her sing something with much broader appeal. This is probably the most broadly appealing song we've done...
Post by tkaitkai on Aug 30, 2020 10:03:55 GMT -6
jcoutu1 Sounds great man! Any processing on the acoustics? Love the way those came out.
