vox66
Post by vox66 on May 30, 2020 14:47:26 GMT -6
I just got a REDD mic and I need suggestions for an outboard compressor(s). I'll be recording mostly vocal and acoustic guitar.
The Black Lion Audio B172A looks interesting.
Post by the other mark williams on May 30, 2020 16:35:27 GMT -6
I just got a REDD mic and I need suggestions for an outboard compressor(s). I'll be recording mostly vocal and acoustic guitar. The Black Lion Audio B172A looks interesting. How aggressive vs. how transparent? There are a number of nice 1176 clones on the market these days, and a couple nice LA-2A-style clones, too.
Post by teejay on May 30, 2020 16:37:20 GMT -6
I don’t have a REDD, but my Audioscape Opto works wonders for my ADK Z-251.
vox66
Post by vox66 on May 30, 2020 17:01:06 GMT -6
I just got a REDD mic and I need suggestions for an outboard compressor(s). I'll be recording mostly vocal and acoustic guitar. The Black Lion Audio B172A looks interesting. How aggressive vs. how transparent? There are a number of nice 1176 clones on the market these days, and a couple nice LA-2A-style clones, too. I'm not well versed in compressors or other recording equipment as much as I should be but I do like character and musicality.
vox66
Post by vox66 on May 30, 2020 17:01:48 GMT -6
I don’t have a REDD, but my Audioscape Opto works wonders for my ADK Z-251. Thanks, I'll check it out.
Post by notneeson on May 30, 2020 17:46:30 GMT -6
I don’t have a REDD, but my Audioscape Opto works wonders for my ADK Z-251. Thanks, I'll check it out. Opto is generally a great option for starting out with compression. And most of them sound pretty sweet in my experience. Not really into compression on acoustic guitar, personally.
Post by hadaja on May 30, 2020 19:15:59 GMT -6
If you are wanting something with a bit of weight and colour the vari-mu compressor from Weight Tank (WT-Comp) is a great priced option. I like using this with my Chandler TG mic.
Post by Deleted on May 30, 2020 19:30:12 GMT -6
I don’t have a REDD, but my Audioscape Opto works wonders for my ADK Z-251. Thanks, I'll check it out. Can vouch. That compressor is one of the best I've ever heard.
Post by john on May 30, 2020 20:40:15 GMT -6
Would def save for a rs124.
Post by Martin John Butler on May 30, 2020 21:26:05 GMT -6
The REDD is arguably the finest new mic in production. I would bet the RS124 would be the best fit if you can afford it.
Post by Ward on May 31, 2020 6:54:07 GMT -6
I would recommend you start with a good opto or the audioscape V-Comp and then add a Bluestripe - which is the combination I tracked with yesterday. And the results are giggle-provoking. Yes, just that good.
Post by Ward on May 31, 2020 6:54:40 GMT -6
P.S. Everything is hot-linked above.
vox66
Post by vox66 on May 31, 2020 10:02:30 GMT -6
The REDD is arguably the finest new mic in production. I would bet the RS124 would be the best fit if you can afford it. I almost pulled the trigger on one last week but I do like the idea of running two different compressors together. Two Rs124s is too much dinero for me at this time. BTW.... Your video/recordings on the REDD mic was one of the determining factors in buying one!
vox66
Post by vox66 on May 31, 2020 10:12:12 GMT -6
I would recommend you start with a good opto or the audioscape V-Comp and then add a Bluestripe - which is the combination I tracked with yesterday. And the results are giggle-provoking. Yes, just that good. I'm definitely interested in these comps. Do you have any experience with the Black Lion Audio B172A? It looks like it might be a perfect 2 in 1 solution but I'm not familiar with their sound/build quality.
Post by aremos on May 31, 2020 12:23:43 GMT -6
The REDD is arguably the finest new mic in production. I would bet the RS124 would be the best fit if you can afford it. Yes, "is arguably the finest new mic in production". And I'd add the Upton 251 & the Josephson C725. Also, the U67 for the Neumann sound.
Curious about the Myburgh - have not used it.
Post by Martin John Butler on May 31, 2020 19:40:43 GMT -6
aremos, we're not talking about those mics. The topic is which compressor would be the best fit for the REDD.
Post by m03 on May 31, 2020 23:40:49 GMT -6
Is it too late to ask what the typical style of vocals and playing will be, and what the budget it?
Post by Ward on Jun 1, 2020 10:04:16 GMT -6
I would recommend you start with a good opto or the audioscape V-Comp and then add a Bluestripe - which is the combination I tracked with yesterday. And the results are giggle-provoking. Yes, just that good. I'm definitely interested in these comps. Do you have any experience with the Black Lion Audio B172A? It looks like it might be a perfect 2 in 1 solution but minot familiar with their sound/build quality. I have not had the pleasure yet. It could very well be. But I can definitely verify just how amazing the products mentioned are!
vox66
Post by vox66 on Jun 1, 2020 18:16:03 GMT -6
Is it too late to ask what the typical style of vocals and playing will be, and what the budget it? Vocal styling of Chris Isaak, Raul Malo and Roy Orbison. Music sounds Rockabilly, Americana and surf. I’ll be recording with vintage guitars and amps.
Post by m03 on Jun 1, 2020 19:27:08 GMT -6
Maybe BG-2, Sta-Level, or RS124 for somewhat reasonably priced options that fit with that aesthetic.
Post by Martin John Butler on Jun 1, 2020 20:17:55 GMT -6
Is it too late to ask what the typical style of vocals and playing will be, and what the budget it? Vocal styling of Chris Isaak, Raul Malo and Roy Orbison. Music sounds Rockabilly, Americana and surf. I’ll be recording with vintage guitars and amps. Probably an Opto then.
Post by drsax on Jun 1, 2020 21:26:37 GMT -6
I’ve used STA-Level, Vac Rac TSL3, AML54f50, UBK Tweaker, LA-2a, Atomic Squeezebox and others with the Chandler REDD mic. All great. For the vibe you’re talking about, the Sta-Level would be a great call. The Sta-Level/REDD Mic is a lovely combo
Post by audioscape on Jun 2, 2020 17:30:51 GMT -6
Based on your microphone and the genre's being recorded most often (CRUCIAL information to have when trying to help someone pick the right compressor for the job and their personal sonic preferences) I would have to humbly suggest that our V-COMP would sonically, slot RIGHT into the fold and make you a very, very happy person, FWIW! ;-) https://www.instagram.com/p/CAtbPJuB9Pu
vox66
Post by vox66 on Jun 2, 2020 21:06:37 GMT -6
Based on your microphone and the genre's being recorded most often (CRUCIAL information to have when trying to help someone pick the right compressor for the job and their personal sonic preferences) I would have to humbly suggest that our V-COMP would sonically, slot RIGHT into the fold and make you a very, very happy person, FWIW! ;-) https://www.instagram.com/p/CAtbPJuB9Pu You've peaked my interest! I might have to have you build one for me......hhmmmm.....
Post by teejay on Jun 3, 2020 7:57:21 GMT -6
Based on your microphone and the genre's being recorded most often (CRUCIAL information to have when trying to help someone pick the right compressor for the job and their personal sonic preferences) I would have to humbly suggest that our V-COMP would sonically, slot RIGHT into the fold and make you a very, very happy person, FWIW! ;-) https://www.instagram.com/p/CAtbPJuB9Pu You've peaked my interest! I might have to have you build one for me......hhmmmm..... FYI...they don't sell on a per-order/per-customer basis. They build limited stock and release for sale periodically. (Read through the image content AS attached.) If you're serious, subscribe to their Instagram account and you'll get notifications on when new product will be available. You can navigate to their site directly from IG and make your purchase. But be aware it is a first-come-first-served approach, so you need to be quick on the trigger. That's how I purchased my BUSS Comp and Opto. I had to stop following them for now, however, as I found myself tempted to buy every piece they make! ;-) Also, I've found their post-purchase communication and service to be second to none. They will answer your questions, give you insights, and take care of you.
