Post by markfouxman on Mar 30, 2020 21:34:38 GMT -6
Hey folks,
I have here an old ProTools 7.4.2 LE on MacOS X. The Mac laptop I used to work with PT suddenly started giving me Audio Record Volume errors. I googled and found I have to go into Window, then Workspace and change Transfer Only to Record. But it won’t let me, saying ‘my HD cannot be designated as an Audio Record Volume because it is not a valid audio volume’. Any leads?
Best, Mark
Post by tasteliketape on Apr 1, 2020 23:32:53 GMT -6
Maybe this : Fix: Cancel out of the dialog and, from the Window menu in pro tools, select Workspace. This brings up a window that lists the available volumes (hard drives, etc.). Look at the "A" column associated with the suspect volume. It probably shows up as "T" (for transfer). Click on the "T" and, from the little pop-up menu, select "R" (for record).
Post by tourtelot on Jul 6, 2020 9:50:17 GMT -6
OT, but hi Mark. Good to see you here.
Some day, I will be able to record again and use your stunning VL373A.
Doug
Post by Johnkenn on Jul 22, 2020 17:10:34 GMT -6
Moving this to the Pro Audio section.
Post by notneeson on Jul 22, 2020 20:20:45 GMT -6
Hey folks, I have here an old ProTools 7.4.2 LE on MacOS X. The Mac laptop I used to work with PT suddenly started giving me Audio Record Volume errors. I googled and found I have to go into Window, then Workspace and change Transfer Only to Record. But it won’t let me, saying ‘my HD cannot be designated as an Audio Record Volume because it is not a valid audio volume’. Any leads? Best, Mark www.soundonsound.com/techniques/resolving-hard-drive-problems
